unable to patch ??
Discussion in 'rFactor' started by Gadget999, Aug 17, 2017.
  1. Gadget999
    12,035Coins
    i have tried to patch RF
    i have installed the plugin using the manager
    when i go to select the installation directory in thr game manager it tells me it cant patch
    "Game did not patch"
    any suggestions ?
  2. Gadget999
    12,035Coins
    i uninstalled rfactor and then installed to c:\rfactor
    the game has now allowed me to patch
    however .net is now crashing :(
    152,373Coins
    +11,076 / 56 / -2
    Did you try this: https://www.xsimulator.net/communit...einstall-now-not-connected.10528/#post-136211
    Or repairing .Net?
    • Close all running software applications.
    • Go to Windows Start Menu -> Control Panel -> Add or Remove Programs or Program and Features.
    • Select Microsoft .NET Framework 4 Extended.
    • Click Change/Uninstall, Remove or Repair.
    • Select the Repair option, click Next.
    • The wizard will perform a repair on the .NET Framework installation.
    • It is suggested to restart the Computer.
    Or try re-installing .NET: https://www.microsoft.com/en-us/download/details.aspx?id=17718
  4. Gadget999
    12,035Coins
    Hi noorbeast
    thankyou for your help and support
    unfortuntately .net is not in my list of installed programs
    however i may have been able to fix this another way
    i have un installed RF
    then installed to c:\RF
    then modified the directory so all users have full access and none of the files are 'read only'
    it has worked on my laptop - hope to try it on the sim tomorrow
    152,373Coins
    +11,076 / 56 / -2
    You need to have .NET installed, it is required for SimTools.
  6. Gadget999
    12,035Coins
    It is part of the operating system - i dont have the option to install or repair it
  7. erivx
    erivx Member
    Ecuador
    206Coins
    2DOF, Arduino, 4DOF
  8. Sento Siete
    Sento Siete Member Gold Contributor
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    hi, I've the same problem.
    Reinstalled Windows and Simtools and it's impossibble to patch rFactor 2.
    Reinstalled .net but got the message:"it's part of the W10 not needed to install" or something so.
    Done all what I've found in the web, but not success.
    ¿What else can I do? Thanks
  9. Gadget999
    12,035Coins
    Where is rfactor installed ?
  10. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    C:\Program Files (x86)\Steam\steamapps\common\rFactor 2
  11. Gadget999
    12,035Coins
    What else is installed on your pc that may use .net ?
    152,373Coins
    +11,076 / 56 / -2
    Have you tried running the Patch Utility as Admin?
  13. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    Yes
    I don't know how can I see this
  14. Gadget999
    12,035Coins
    Do any other sim programs work ok ?
    What else have you got patched ?
  15. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    AMS2, AC and ACC patched and working normally
  16. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    ¡Solved!, I've just forgotten to create the "plugin" folder in to the Bin32:(
  17. glenche
    glenche DarkMan
    Sydney, Australia
    38Coins
    Hi Sento,
    I have the same issue with patching rfactor2 that installed under the steam directories.
    Can you please explain what you mean bu your last comment "Solved!, I've just forgotten to create the "plugin" folder in to the Bin32:("
    Much appreciated.
    So far I've got LFS working with no issues but having issues with rf2
    Hoping I don't need to remove and reinstall rfactor again.
    Glenche
  18. Sento Siete
    Valencia (Spain)
    304Coins
    2DOF, SCN5
    You have to create a folder called “plugin” into the “Bin32” folder in the root of the rFactor 2, like the one that exists in the “Bin 64” folder
