Question No option for Pitch for Axis 1 on DOF 3 Dropdown
Discussion in 'SimTools DIY Version' started by 9xclubchamp, Aug 18, 2017.
  1. 9xclubchamp
    9xclubchamp New Member
    Woodbury
    311Coins
    I have a Prosimu T1000 5 Motion simulator. I'm trying to set Axis 1 to Pitch in the Force drop down in DOF 3 but I'm only getting Yaw, surge extra 1 ,2,3 options. I do see the option for pitch in each of the other Axis 2 - 5. Any ideas on how to correct this
  2. yobuddy
    51,667Coins
    Can I get a Screen shot buddy?
  3. 9xclubchamp
    Woodbury
    311Coins
    sure thing here you go
  4. 9xclubchamp
    Woodbury
    311Coins
    sorry it's Axis 2 that I cant get the Pitch dropdown
    154,484Coins
    +11,184 / 57 / -2
    It is a lousy photo but my guess would be that it is already allocated on that axis, hence pitch won't show in subsequent drop downs.
    As an aside you should not be using the DIY license with a Prosimu rig, as it is a commercial simulator, you need the Pro SimTools License and I suggest you PM @yobuddy about upgrade arrangements.
  6. 9xclubchamp
    Woodbury
    311Coins
    totally agree about the license, I only used my previous license from my frex rig. Patrick is supplying a commercial license as part of my purchase. thanks for the link on the profiles.
  7. yobuddy
    51,667Coins
    You read the axis from Left to Right.
    So if you have used it already, then it won't be available to use again.
