value1
Tom Clancy's H.A.W.X. Plugin 2.0.0.1
SimTools plugin for Tom Clancy's H.A.W.X.
  1. value1
    15,075Coins
    Tom Clancy's H.A.W.X. Plugin - SimTools plugin for Tom Clancy's H.A.W.X.
    152,541Coins
    +11,085 / 56 / -2
    And the supported games list gets ever longer...nice one @value1 :thumbs
  3. mrbeginner
    What ever come in my way
    Finland Niinisalo
    - 10Coins
    Do you know will this work in hawx2?
  4. value1
    15,075Coins
    That would be pure luck. I don't think so.
    Hawx2 has very poor reviews so I didn't bother.
  5. mrbeginner
    Finland Niinisalo
    - 10Coins
    Thanks for fast answer. I download Hawx 1 to try it out. Thank you for this plugin!
  6. brucewang
    brucewang New Member
    China
    195Coins
    The Game is amazing!
  7. Ali Khaleghi
    Ali Khaleghi Engineer
    161Coins
    3DOF, 4DOF
    I Cannot get telemetry data from this game. I run GameManager and Gameengine in admin mode, also i used the game folder for patching. the game is running in the Gameengine but it sends constant data. what is the problem?
  8. mrbeginner
    Finland Niinisalo
    - 10Coins
    Have you try different views?
    I found that it work only back view not cockpit mode
  9. Ali Khaleghi
    161Coins
    3DOF, 4DOF
    three views were selectable (including non cockpit mode) but unfortunately non provided telemetry data.
    any other suggestions??
  10. Mudaser
    Mudaser New Member
    25Coins
    2DOF, Motion platform
    I am new to simulator and integration, can you guide me on the basics of acquiring data from running game. Should I be accessing a database, scanning memory or using APIs to get car/plane telemetry data and other coordinates. thanks
    152,541Coins
    +11,085 / 56 / -2
    SimTools and plugins do all the heavy lifting, here is how they are used: http://www.xsimulator.net/simtools-complete-documentation/
    If you mean you are interested in creating plugins then here is the basics of how it is done: http://www.xsimulator.net/community/faq/how-to-write-a-plugin-for-simtools-api-documentation.131/
  12. Jamshaid
    Jamshaid Jamshaid Gold Contributor
    Hobbiest
    Pakistan
    280Coins
    i can't also capture th telemetry data of game with this plugin can anyone help?
  13. value1
    15,075Coins
    This resource has been removed and is no longer available for download.
  14. Jamshaid
    Hobbiest
    Pakistan
    280Coins
    so you just deleted the plugin to my fav game :oops::oops::oops::oops::oops:
  15. value1
    15,075Coins
  16. morteza
    morteza New Member
    - 37Coins
    Hello
    I had install SimTools in windows 10 64 bit and Tom Clancy's H.A.W.X. plugin but i cant capture any output data. i want to know this plugin is compatible with 64 bit windows and could you specify step by step how to use of this plugin like where to install game...
    thank you
    152,541Coins
    +11,085 / 56 / -2
    Can you explain a bit more of what you have done.
    First, does your simulator work in Output Testing with SimTools?
    Did you use the Plugin Installer app?
    What patch path did you use?
  18. morteza
    morteza New Member
    - 37Coins
    Hello
    Yes I installed plugin with Plugin Installer App but i did not patch it because it was patched at first and could not select any path for patch i think it knows game from it's process name.
    but when i run game simtools recognize it but i cant any changes on Tuning center
    in the below picture when game is running i just -180 in yaw.
    thank you
      95.5 KB
      823
      95.5 KB
      807
      95.5 KB
      831
      139.9 KB
      842
    152,541Coins
    +11,085 / 56 / -2
  20. morteza
    morteza New Member
    - 37Coins
    Hello
    this is Interface setting pictures and I checked output testing and it worked properly with tuning center.
    Thank you.
