2DOF Trimension Swivelchair – first questions (German)
Discussion in 'DIY Motion Simulator Projects' started by GeneralDiDi, Jun 24, 2017.
  1. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Oh nooo. Such a small stupid mistake. I read it with mode2, but not correctly understood. Hours troubleshooting - solved in 1 second. I am such a noob :think
    Thanks for the hint. You are my HERO hug:
  2. Joao Neto
    Joao Neto Mucilon
    Computer engineer
    Salvador - Brasil
    310Coins
    I did the same thing. I only understood when I was the Arduino code.
    It happens
    • Friendly Friendly x 3
  3. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Now found a short time to get a piece further ;) next Step:
  4. armpit
    armpit Active Member
    Software Engineer
    SC, USA
    - 8Coins
    Wow looks like you're getting some really nice movement with it. Glad to see it in action with a successful test!
  5. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Thank you. Only time is the limiting factor o_O
    As guide: pictures of the ground isolation - FEBI Bilstein 37619
  6. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Update:
    Everything attached to the chair, bent a threadedrod, threadstretcher to precisely adjust the position.
    Testdrive is coming soon
    • Old Old x 1
  7. armpit
    Software Engineer
    SC, USA
    - 8Coins
    Oh man you can't tease us like that!!! Everything looks put together and ready to move, what's left to make a video?
    Do you have any protection for runaway motors if the potentiometers fault? I'm guessing if that happens the motors will just stall against the mountings that hold the pots.
    Love all the small attention to detail, looks so good! Are those circles covered in vinyl or are there cooling fans or something there?
    Looking forward to the video!
  8. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Thanks for feedback. :thumbs There is still a lot to do, but at least it works. So here is the first test. Still without finetuning.
    For the motor protection I still have to do something. Definitely a killswitch and a temperature monitoring with shutdown for the motors.
    Whether the Motors are too hot I can not say yet. If necessary, I will install coolingribs. Ventilation cooling without coolingribs is not efficient. We will see ;)
    The metal parts are covered with shrinksleeves ( in German: Schrumpfschlauch ) and do not rattle. How durable is this, I'll see ..
    The movements are not as high/big as with some other simulators, but it should also be a lightweight. To move it around und should not need a whole room :rolleyes:
    So next to do is a fastening down to a rotationring, which then makes the turning/rotation-movement over a motor.
    • Like Like x 8
    151,991Coins
    +11,061 / 56 / -2
    Excellent craftsmanship, it is really great to see your sim in action :thumbs
    When you get into the tweaking and refinement try adding a bit more heave, it will liven things up considerably.
  10. armpit
    Software Engineer
    SC, USA
    - 8Coins
    Am I understanding this correctly - you are making this into a 3DOF by adding a yaw axis under the chair?
  11. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Yes, I think about it. Have to find a suitable solution ;)
    • Optimistic Optimistic x 1
  12. Thomas T.
    Thomas T. Impact
    Seller
    Austria
    134Coins
    Are the Motor enough strong for a 2 DOF ?
    CU
  13. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Strong enough is relative. Depends on the stroke you want to realize. The motors are OK - standard. Not stronger than other wipermotors. I think there are certainly better motors for larger applications.
    Rotationring - We'll see what's going to happen ;)
  14. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Doing the rotationring mount and a wipermotor with a Module1.5-gear. A potentiometer and emergency stop. There is still a lot to do.
  15. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    ...and the video. Everything has yet to be brought together. Sometime :rolleyes:
  16. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    next step.
    Now mounted the ring with the chair. Also done a connection-terminal for Power and USB.
    • Like Like x 5
  17. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Get today a bit further. Build the X56-Stick in a more compact format so that it can also securely and stably attach to the armrest. More coming soon... i hope ;)
    a short vid:
  18. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    The stick is mounted and is also stable. Have installed a potentiometer to set the rotary movement not only by software but also manually. Going well so far.
  19. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    I dared to the X56 Throttle to reduced the housing significantly. It was not that easy, because the mechanics need a lot of space and there are a lot of boards in it. Was a bit more elaborate than expected. But now it fits. Some buttons have been dropped, but I have 6 (4 fingers / 2 thumbs) integrated new buttons in the small case. Made a short video with a small project review.
    151,991Coins
    +11,061 / 56 / -2
    I am a real fan of the compact minimalist approach, you have been really creative in cleanly incorporating a lot of gear and refinement into a compact design :thumbs
