Resolved Wrong data from those plugins which import telemetry via UDP packets.
Discussion in 'SimTools Plugins' started by jamesdio, Jun 11, 2014.
  1. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SimforceGT, Motion platform, 4DOF
    ※ This method expired, because of the compatibility issues for NTLEA.
    So, I'd like you to use the new program,Locale Emulator on the URL below.
    <Local Emulator usage>
    http://www.xsimulator.net/community...emetry-via-udp-packets.5550/page-2#post-59843
    updated on Aug 18 2014
    I found a better solution using NTLEA (NT Locale Emulator Advance).
    1. Download NTLEA (url below) and extract it where you want.
    http://ntlea.codeplex.com/releases/view/125356
    2. run "ntleasWin.exe" then follow the steps below.
    3. Make Shortcuts.
    4. Voila!! you can see the shortcut under your selected folder right before this step.
    This method can use the OS default settings on your control panel for those who uses unicode languages to avoid language compatibility issues with other applications.
    @yobuddy Please edit the faq. Thanks in advance. :)
  2. RacingMat
    21,088Coins
    I have updated the FAQ ;)
  3. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    Thank you very much, RacingMat.
  4. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
    I found more stable application than NTLEA for changing locale settings.
    The application is Locale Emulator.
    You can download it from the url below.
    https://github.com/xupefei/Locale-Emulator
    ※ Some antivirus software detects Locale Emulator(LE) as a virus but It's actually not a virus only misdiagnosis. please read the related issue for this problem below.
    The setting method is almost same as NTLEA's
    * Make a new profile.
    - launch LEFUI.exe under the location LocaleEmulator is installed.
    * Method 1. Create shortcuts for launch.
    ※ Create shortcuts for both GameEngine.exe and GameManager.exe.
    - Step1.
    - Step2.
    * Method 2. Run SimTools directly without shortcuts.
    Here are my experiences that NTLEA CAN NOT execute both files, GameEngine.exe and GameManager.exe, at the same time and NTLEA is NOT working properly on my some other PCs.
    So, I recommend that you guys use Locale Emulator instead of NTLEA.
  5. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    And connection
    I'll test
    Hi, thanks. Your posts,
    Very useful to me, I'll test the "Chinese"
  6. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Two software without success
    I used your first scheme
  7. jamesdio
    jamesdio Member
    Seoul, Korea
    767Coins
  8. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    I was doing this
  9. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    LFS data becomes normal,
    PC to control panels, communications failure!!!
    Later my videos
  10. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    I have just saw a post:
    If I have Finnish date and time format in windows (the bottom right clock shows now 9:41 18.10.2014) that problem occurs. If I change it to English (9:41 18/10/2014) it starts working! It can be tested by going to Control Panel->Clock, Language, and Region->Change the date, time or number format and put it to Finnish. And then launching SimTools again. Thank you for this motor driver!
  11. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
  12. yobuddy
    51,664Coins
    fixed in v1.3 - there should be no need to change the date time anymore...
  13. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    The new V1.3. I am very happy. Thanks yobuddy:thumbs
  14. eXntrc
    eXntrc Member
    636Coins
    I have a fix for the screen corruption issue that does not require you to change your DPI settings. Hopefully the SimTools devs can look at fixing this in the code, but I have a patch available for now. Please see this post for more info and to download.
  15. JayceTeng
    JayceTeng New Member
    非政府组织的专业软件测试员
    - 86Coins
    2DOF, DC motor, SCN6, Arduino, Joyrider, Motion platform, 4DOF, 6DOF
    My language is Chinese in windows 10,And I used SimTools V2,So I need to set the language to English in Language LEFUI?Or I don't need to do anything?
  16. noorbeast
    154,412Coins
    +11,181 / 57 / -2
  17. Grizus
    Grizus Member Gold Contributor
    Warsaw PL
    349Coins
    I have a problem with "locale emulator" on windows 10 :( I get this error:
    does anyone know this problem? :( :( :(
  18. fzxj520
    fzxj520 Active Member
    1,341Coins
    The same question, is there no solution to this problem?
    My system windows_10_ltsc_2019
  19. yobuddy
    51,664Coins
    Local region is fixed in SimTools v2.4 and above.
    So this should not be needed anymore.
    Take care,
  20. wyh0607b
    wyh0607b New Member
    173Coins
    AC motor, 6DOF
    I used SimTools v2.0 DIY also encountered the same problem, I changed the current system locale to English (US), and it is normal.
