Elite Dangerous Horizons Plugin (Non VR Version) [Deleted]
Discussion in 'SimTools Plugins' started by value1, Dec 22, 2014.
Thread Status:
Not open for further replies.
  1. noorbeast
    152,373Coins
    +11,076 / 56 / -2
    You are correct, there is no point rebuilding a plugin when further game updates are expected and are likely to break the plugin again.
    See the following re plugin development:
    https://www.xsimulator.net/community/faq/how-to-write-a-plugin-for-simtools-api-documentation.131/
    https://www.xsimulator.net/community/faq/a-brief-introduction-to-using-cheat-engine.236/
    https://www.xsimulator.net/community/faq/cheat-engine-youtube-tutorials.242/
  2. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    Ok thanks I'll take a look
  3. SilentChill
    20,593Coins
    I always wait until final release as the last beta version may differ to the actual release so all the memory locations would be wrong again.
    Dont worry I will update it if the plugin is broken when the update lands ;)
  4. baykah
    Toulouse - France
    414Coins
    great ! thank you =)
  5. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    929Coins
    3DOF, Arduino, Motion platform, 6DOF
    Eagerly awaiting a new ED plugin!. I've just recently upgraded my simchair motors from 50w wipermotors (which worked really well since January when I first built it) to 150w wheelchair motors. Works great now (smc3 and half-bridged monstermotos), but been in joystick mode since the last ED update. Many thanks in anticipation Craig.
    Kev
  6. legolas003
    legolas003 New Member Gold Contributor
    Computer Network Teacher
    Charleroi, Belgium
    167Coins
    Hello SilentChill,
    I just bought the latest version of Elite Dangerous Horizon (the 2.4 I think) but the plugin does not work with.
    Do you think you can upgrade?
    I want to collaborate even if I never developed a plugin ;-)
    Thank you :)
  7. cedric33
    cedric33 New Member
    - 118Coins
    Hello !
    I have Elite Dangerous, not Horizon. It is necessary ? The plugin doesn't work with my version 2.4.03
    Thank you for your answer.
    Best regards
  8. cedric33
    cedric33 New Member
    - 118Coins
    Hello ! :) Look at this picture and tell me your opinion. Only the roll is operated.
    Administrator mode ok for game engine and game manager. When i launch the game the motion plateform moove only in roll mode in right and stop. In game any movement. Heave, pitch, Surge, Sway and Surge are activated in 20%. I play with assetto corsa and the plugin work perfectly. Can you help me please ? Thanks
  9. SilentChill
    20,593Coins
    Plugin is broken at the moment due to the game update. I have not had chance to make a new one I've been way too busy.
    Also the plugin will when updated only work with ED:Horizons
  10. George Dobransky
    Hungary
    - 43Coins
    Hi THere,
    Due to the continous updates and the fact we still don't have a working API output from the game, for those, who has got more than 1 usb connected joysticks or want some more programmed movements in the game I can offer you an alternate method to get movement with ED.
    Maybe it isn't new info to some of you, but maybe I can help to some.
    Joystick plugin only can manage 1 joystick input, so if you have stick, thrust and pedal separatelly with 2 or 3 usb inputs, you can use the software called vJoy, a virtual joystick device. you can download from here:
    https://sourceforge.net/projects/vjoystick/files/Beta 2.x/
    There is several versions, the new ones has a chance to get an installation problem with win7, or win10, in this
    case you can try an older version. I have spent some hours with that fcking issue....:(
    You need also a remapper utility, for new versions of vJoy there is UCR, link:
    https://github.com/evilC/UCR
    For older versions of vJoy, you can use UJR:
    http://evilc.com/fil...hk/vjoy/ujr.zip
    With these utils you can easily set up multiple joys or usb input into one, and a lot of advantages
    there, like you can program some movements to buttons, axes, etc. For example you can program any
    movement to landing gear down, or hyperjump, etc.
    Hope it helps you in these unhappy days....
    Cheers,
    George
  11. cedric33
    cedric33 New Member
    - 118Coins
    Thanks, i buy horizons on steam and i wait your update :thumbs
  12. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    After a few months, my elite chair is ready to play and running well. After some hours trying get the plugin working, i found this thread. For 2.4 (since september) there is no plugin. This breaks my heart :oops: Can we do anything else?
  13. noorbeast
    152,373Coins
    +11,076 / 56 / -2
    It will continuously break with updates unless the ED devs implement a suitable API. Members here have been lobbying the ED team to do so and the SimTools dev @yobuddy has even supplied example code. But so far the ED devs have yet to provide a stable API.
    Hence plugin updates have to be done each time ED is updated and as the plugins are done by volunteers it gets done when they have some free time.
    You can use the generic SimTools Joystick plugin, it is not as good as the dedicate motion plugin, but better than nothing for short term use while waiting for a plugin update.
  14. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,239Coins
    Hi @SilentChill
    what do you think, when its time for update the plugin ?
    Currently my rig is in the upgrade process from servo to actuator type.
    so i'm not needed right now. But i guess there're other uers out there who need this.
    Best,
    Kermit
  15. SilentChill
    20,593Coins
    This resource has been removed and is no longer available for download.
Thread Status:
