Attaching heatsinks to Jrk 12v12?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Roonster, Apr 29, 2014.
  1. Roonster
    Roonster Member
    GTA Ontario
    609Coins
    How have you guys been mounting your heatsinks on the Jrk's?
    Spring clips or thermal adhesive?
    Thanks,
    Paul.
  2. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    I used thermal paste, drop of super glue un corners.
  3. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    I've seen one mounted with a cable tie.
    I was thinking of using a spring clip like the ones used on CPU heatsinks and have it screwed to a backing board of some kind where the JRK is mounted. It night have to be bent into shape though as the capacitors are in the way.
  4. eaorobbie
    20,486Coins
    I use heat sinks from my local jaycar shop that come with thermal tape. Stick and forget.
  5. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    Can anyone suggest a suitable heatsink or does it really matter? I'm thinking that I'm just going to end up buying a square copper northbridge heatsink and cutting it up to fit the JRK chips.
  6. eaorobbie
    20,486Coins
  7. Roonster
    Roonster Member
    GTA Ontario
    609Coins
    Thanks, I used your technique and it worked out well. The heat sinks were cut from a larger CPU heatsink with a hacksaw.
  8. Aribaz
    Aribaz New Member
    - 8Coins
    2DOF, JRK
    Hello, and they worked as heatsinks? Get very hot to the touch? Sorry for the bad english...
    152,373Coins
    +11,076 / 56 / -2
    JRKs do get hot and need both a heat sink on the main chip, plus a cooling fan. Most buy a standard heatsink but nothing wrong with creative modding as @Roonster has done.
  10. dmk90
    dmk90 New Member
    Brisbane, Australia
    258Coins
    Id imagine you can do the same for the monster moto boards????
    152,373Coins
    +11,076 / 56 / -2
  12. dmk90
    dmk90 New Member
    Brisbane, Australia
    258Coins
    Thanks for the link noorbeast, looks good!
  13. Nick Moxley
    No you dont have to cover the little chip's, but i had a whack load of little sinks, just needed to slice them in 1/2 or 1/3 with the band saw.
  14. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    Hi to all! I'm thinking about how to cooling JRK. For space reasons I want to make traditional way (heatsink+fan). I've received today the heatsink and I was really happy about my order...but now seems very little and not very tall... It's only my stupid worry or I should order another thing? Height is 0,5 cm.
    Because if I see photo of other's heatsink seems very big, but maybe it's only something regarding proportions..
    I've bought this because it has glue and thermal paste incorporated. This is the product:
    Code:
    https://www.amazon.it/Aukru-Raffreddamento-Alluminio-Dissipatore-Dissipatori/dp/B00ILK6DMA/ref=sr_1_1?ie=UTF8&qid=1503508987&sr=8-1&keywords=raspberry+heatsink
    Thank you so much.
  15. Nick Moxley
    The BIG 1" tall sinks aren't really needed. You should be fine with those.
  16. mirkobastianini
    informatic
    italy
    1,300Coins
    Thank you!
    I've found in my house another solution, so I can choose between that little heatsink in the previous post (wich has adesive thermal paste) and...this:
    Those are 15mm x 15mm x 15mm. I can use with this thermal paste:
    Maybe it's a better solution of cooling? I can choose, I have already this item in my house.
    The only question will be how to fix this heatsink to jrk, maybe with this:
    152,373Coins
    +11,076 / 56 / -2
    You can get double sided adhesive thermal tape on eBay.
  18. mirkobastianini
    informatic
    italy
    1,300Coins
    It's not better to use thermal paste instead of adesive? :)
