  1. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,313Coins
    If you mean that pin 9 is either always on or always off then that is not correct - it should be PWM unless the motor feedback is exactly in the correct target position.
    I use the BTS7960 and the wiring in the first post. It's been a long time since I was in the details but I'm pretty sure I wanted it to run in drive/brake (or maybe it was drive/coast) mode hence the wiring config and the special code for MODE2. In whichever mode it was I was trying to achieve, only one H-Bridge PWM signal is driven with PWM output as noted by the wiring diagram.
    If you are happy to run the motor in drive/coast mode then you could use MODE1 and connect the PWM signal to both H-Bridge EN pins and connect the ENA and ENB to each of the H-Bridge PWM pins. Although if it's not working I would say something else is wrong as there are others using these h-bridges with SMC3.
  2. Gadget999
    12,035Coins
    thank you :)
  3. CaptBluescreen
    CaptBluescreen New Member
    131Coins
    Hi at all,
    first of all: @RufusDufus awesome work!!!
    I got it to working with my Arduino Mega2560. I have tested around with my own code to understand the BTS7960. Then, I have modified the SMC3 v1.
    In the SetOutputsMotor1() from Mode2, I had to replaced
    OutputPort &= ~(1 << ENApin1); // Unset Motor2 In 1
    throw
    digitalWrite(ENApin1, LOW); for unset or digitalWrite(ENApin1, HIGH); for set
    and removed the PORTD = OutputPort;
    because the pin mapping PORTD will not work on an Arduino Mega, so I did it manually with digitalWrite();
    I did also a change in the MyPWMWrite() function. We use the MyPWMWrite in the SetOutputMotor1-3 to send the PWM signals to the motors, but I found in this function the if else statement:
    if (val == 0)
    digitalWrite(pin, LOW);
    else if (val == 255)
    digitalWrite(pin, HIGH);
    else
    uint16_t regLoc16 = 0;
    uint16_t top;
    switch(pin)
    case 9:
    sbi(TCCR1A, COM1A1);
    regLoc16 = OCR1A_MEM;
    top = ICR1; //Timer1_GetTop();
    break;
    case 10:
    sbi(TCCR1A, COM1B1);
    regLoc16 = OCR1B_MEM;
    break;
    tmp=(tmp*top)/255;
    _SFR_MEM16(regLoc16) = tmp; //(tmp*top)/255;
    I didn't really understand this one - I got only a on or of signal - if val==0 or if val==255. But I thought, that I get the val from the PID controller...
    I added a new state,
    else if (val > 0 && val < 255)
    analogWrite(pin, val);
    and after that, it works. With MODE2, EN_R&EN_L are always activated (which is needed for the BTS7960), on PWM i get the PWM signal and on ENApin1 i got on or off for the direction.
    I will test it this evening with our chair...
  4. Gadget999
    12,035Coins
  5. Michael Paleo
    Michael Paleo New Member
    Uruguay
    96Coins
  6. Gadget999
    12,035Coins
    The ibt-4 works by powering itself from the 12v supply and 2 pins for direction pwm.
    I was unable to use it because i am running 24v.
    I tried it on a different project and it seems to work fine :)
  7. George Dobransky
    Hungary
    - 43Coins
    Hi There,
    I have already built my 3dof, 2 x 12v motor system with smc3, with 12v mmShield.
    Now I'm planning to change to 3 x 24v motor system to simnulate heave also.
    Can anybody help me with a tutorial link about the motor controllers and the
    wiring of 24v motors to arduino?
    Thanx,
    George, Hungary
  8. Gadget999
    12,035Coins
    Hi George - how is your 3dof wired up ?
    which motor drivers did you use ?
  9. George Dobransky
    Hungary
    - 43Coins
    Gadget999,
    It's a classic, mode1 wiring and setup, means I'm using MonsterMoto shield:
    This shield is only for 12V motors.
    The mode 1 wiring is also on the first page of this tutorial.
    Thanx for help,
    George
  10. George Dobransky
    Hungary
    - 43Coins
    Hi Guys,
    If I wire the two Monster Moto output drivers together to drive a single motor using SMC3, as @Pit's wiring, like this:
    If I short c. B1-A2, will I get 24v 15A from A1-B2?
    Cheers,
    George
  11. Pit
    30,498Coins
    no, you will damage the MM....the MM doesn't support 24V.
  12. George Dobransky
    Hungary
    - 43Coins
    Pit,
    So, that is not the same as you connect 2 same batteries in line resulting the volts added?
    George
  13. Pit
    30,498Coins
    no
  14. shresans
    shresans New Member
    USA
    9Coins
    Hello @RufusDufus, I recently bought a commercially available 3DOF motion simulator. upload_2017-10-27_10-8-28.png
    I will be using it for research and was wondering if there was a way to control the RPM of the motors using the SMC3.io arduino code. I tried adjusting the value of Ki hoping that would reduce the RPM but it makes the motion jerky. My intent is to use the output testing in simtools to adjust the Roll, Pitch and Yaw and I would like to know if there is a way to adjust the speed of the motors. I won't be using the simulator with a game at all.
    Appreciate any help on this from the members. I have read through the entire thread and couldn't find any information for this particular adjustment.
  15. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    I connected the HBridge driver to a single motor, but it is returning peaks in the power supply.
    Has anyone gone through the same thing?
    When using the SMC3 in sinusozo movement, it does not read the last 10% upwards
  16. terry wells
    terry wells Active Member
    retired military
    minnesota USA
    717Coins
    3DOF, Arduino
    Is there a wiring diagram on connecting the IBT-4 controller board to the arduino? I am currently using the IBT-2 and I think one is bad.
    Terry.
    152,553Coins
    +11,087 / 56 / -2
    I can't recall anyone having reported testing it yet.
  18. noorbeast
    152,553Coins
    +11,087 / 56 / -2
  19. Martin.Berger
    Martin.Berger Member
    216Coins
    i wahr to use SMC3 on my 2dof Seatmover. Unfortunatly ScUtil says"connection error abort or ignor".
    com ports are set correct.
    Any ideas?
    Martin
  20. Juandi
    Juandi Member
    Engineer
    Mexico
    202Coins
    2DOF, 3DOF, DC motor, Arduino, JRK, Motion platform
    Hi everyone,
    After roasting a couple of chinesse MM boards I have tried these H-bridges from POLOLU:
    https://www.pololu.com/product/2994
    They are able to handle 25Amps in continuous mode and 60 amps peaks no heat sink needed, I have play them quite hard this weekend and they are still alive. I will post more details on my building thread, but if some one is looking for MM alternatives using SMC3, this ones worked for me.
    MM are cheap and work good, but the delivery time and the faulty rates made me consider some other options. Pololu customer support is great and they recomended me these boards.
    As far as I notice seems that no one have tried them before, so here is my little aportation.
    Juan
