value1
Codemasters F1 2017 plugin 2.0.0.0
SimTools plugin for Codemasters F1 2017
  1. value1
    14,267Coins
    Codemasters F1 2017 plugin - SimTools plugin for Codemasters F1 2017
    • Winner Winner x 3
  2. leonaikikai
    leonaikikai Member Gold Contributor
    45Coins
    big thanks i try this today :thumbs
  3. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, compatible with SimTools 1.3 thanks
  4. yobuddy
    51,657Coins
    @bruno1210
    There will be no new/fixed SimTools v1.3 plugins buddy.
    All our effort is focused on SimTools 2.0.
  5. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
  6. Djules
    Djules New Member
    - 175Coins
    DC motor, Arduino, 4DOF
    thanks for the plugin
    But my motors vibrates with this game ??
    but work very well with other o_O
    Do you have this type of problem with this plugin?
    154,388Coins
    +11,179 / 57 / -2
    Do you mean that other plugins work for you but this one does not?
    If so do you have a 32 or 64 bit system, as the patch path is different for each with Codemaster games: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
  8. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    611Coins
    2DOF, 3DOF
    Thank you and Kudos to you super fast
    merci et super rapide bravo à vous.
  9. Djules
    Djules New Member
    - 175Coins
    yes I put it in the right directory
    I used already f1 2016 and dirt 3
    the engines move well according to the movements but vibrates constantly as if the car was touching the track ...:(
    and I have no problem on project car ...
  10. yobuddy
    51,657Coins
    @Djules,
    Have you tried capturing new Min/Max settings for your sim?
  11. Djules
    Djules New Member
    - 175Coins
    I make new tets and I realize that the surge and sway pose problem
    Roll and pitch work very well ...
    I tried with new capture and reloaded the plugin it's the same
    the values are unstable in motion
    I am the only one to have this problem?
    154,388Coins
    +11,179 / 57 / -2
  13. Djules
    Djules New Member
    - 175Coins
    Hi Noorbeast
    This my setting
    154,388Coins
    +11,179 / 57 / -2
    You seem to have an unusually high Axis Allocation for surge and you mention pitch being OK but it is not shown in your settings. If pitch has an axis allocation then the total for all allocations is too high, as it is already well over 100% with just sway, surge and roll.
    I also am not clear what you mean by this, "values are unstable in motion". Do you have a video that can show what the problem is?
    I would suggest that you redo your profile one Axis at a time, following these steps: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  15. Djules
    Djules New Member
    - 175Coins
    Hello
    Here is the video I made.
    we can see big vibrations in braking and acceleration
    I just put the surge in effect has 50% without filter and tunning center at 7
  16. yobuddy
    51,657Coins
    My guess is that you need to re-capture your max/min settings for the game.
    Also, consider adding one DOF to the axis assignments at a time.
    Once that one feels good, adjust it to 0% for output (so it is off) and add another.
    Once all effects feel right, turn them all on and adjust percent's as needed.
    This way you will find and eliminate your problem buddy,
  17. Leandro Kemp
    Brasil
    - 10Coins
    "Heave" vibrates even with the car stationary. "Surge and Sway" are also unstable. It vibrates a lot.
  18. Leandro Kemp
    Brasil
    - 10Coins
  19. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    @Leandro Kemp for capturing min max you should do a clear round without crashing and then fine tune one dof per time and then mix them all and fine tune them a bit again.
    i see you are running the game in window mode. there was something similar reported from a member here for dirt rally too. could be the same bug for the f1 2017 https://www.xsimulator.net/community/threads/codemasters-dirt-rally-plugin.6823/page-4#post-78802
    http://forums.codemasters.com/discussion/6550/dirt-rally-erratic-annd-jittery-motion-telemetry
  20. Leandro Kemp
    Brasil
    - 10Coins
    Hello. I already tried. Even with little movement, everything is shaking. Only pitch and roll are good.
