My 2 dof motion sim
Discussion in 'DIY Motion Simulator Projects' started by Schopfer, Aug 18, 2017.
  1. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Hi I'm Kant . I will build 2 dof motion simulator
    Now I've started doing modeling before actually motion simulator
    Now there are some obstacles, I will try to do it.
    Sorry for my English
  2. Schopfer
    Schopfer Member
    Thailand
    86Coins
  3. Ned
    Ned Member
    fixed operations manager
    melbourne
    714Coins
    Looks great well done regards Ned
  4. Schopfer
    Schopfer Member
    Thailand
    86Coins
    MY SMC3 and Simtools Test
    Center position of Simtools is not correct.Simtools was't start at center of Pot motor and Motor 1 was jerk.
  5. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    you should not run Simtools and SMC3utils at the same time.
    first configure SMC3utils and close it and then run Simtools alone.
  6. Schopfer
    Schopfer Member
    Thailand
    86Coins
    lised
    Yes i closed smc3 before start simtools
    Motor 1 out put
    foward 7.57 V
    backward 3.35V
    Motor 2 out put
    foward 7.72 V
    backward 6.74V
  7. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    the volts from your measurement don't look good if you have a 12v psu and motors
  8. Schopfer
    Schopfer Member
    Thailand
    86Coins
    It's start 45 degree clockwise from center of Pot(surge output 0)
    and can't move over in this way (Surge 0,-30 is freeze in start )
    at Surge 0 to 30 it move to 45 degree counterclockwise
    I use car 12 v batterry for motor drive
  9. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    before going into simtools configuration you have to set SMC3utils first. do you have proper movements in SMC3utils. and again my opinion is that you have a faulty MM but provide some clear screenshots with your wiring to see if something is wrong (watched your vid again and i think your pots are wrong but can't see it clear in the video)
  10. Schopfer
    Schopfer Member
    Thailand
    86Coins
    May be this problem from resolutions of mini motor or Monster Motor drive is't match with mini motor.
  11. Schopfer
    Schopfer Member
    Thailand
    86Coins
    I try with big motor it's not has problems.
    Correct position and work well.
  12. Zed
    USA
    5,844Coins
    I think that's going to depend on how he measures the voltages, though. Most DVMs integrate a bit to help reject ambient AC so it would be measuring both the voltage and PWM duty cycle at the same time and showing a kind of an average for the output of the H bridges. You'd need a scope or something that can grab peak voltage to see that the output was truly banging to 12 volts during the on period of each pulse.
  13. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    i think if he adjusts the PWM max to 255 which is the highest value he can put, he probably will get 12v measurements but not sure.
  14. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Update project
  15. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Probrem in SMC3 is work fine but in simtool is not smooth and incorrect start position same SMC:(
  16. yobuddy
    50,747Coins
    Please try this to make sure its not a windows thing...
  17. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Thank you very much. It’s work. I’m forgot to change it for new windows.
    Today test with 1 motor
    Pot has broken 1.I will full test later.
    :thumbs
  18. Schopfer
    Schopfer Member
    Thailand
    86Coins
  19. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Lfs test
  20. BS21
    BS21 Sim Tutorial: www.youtube.com/BSGamingSimulator
    Indonesia
    193Coins
    DC motor
    Hello, what motor used on this project?
