Piece of metal connecting the motor shaft to rod end joint
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Lol4, Sep 10, 2017.
  1. Lol4
    Lol4 Member
    Australia
    - 115Coins
    153,764Coins
    +11,149 / 57 / -2
  3. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Thanks for that.
  4. Nick Moxley
    i Highly suggest running nylon nuts and running a Standard nut as a "jam nut" having the Axel/lever loosen off the motor isn't something you want happening. (Also Dont go crazy tightening the axle shaft, You Can damage the motor if you go nuts)
    Also if you have a welder or access to one, CRANK down on the 2 nuts pinching the 5mm flat bar lever and tack those nuts to the Lever itself.
  5. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Thanks for the advice and your detailed build post. I am off to get some nuts this morning. Perfect timing. Good to know you used 5mm flat bar as I was not sure on a suitable size.
