value1
Tom Clancy's H.A.W.X. Plugin 2.0.0.1
SimTools plugin for Tom Clancy's H.A.W.X.
  1. noorbeast
    153,830Coins
    +11,151 / 57 / -2
    You really need to start your own project thread and fully detail your hardware and the code you are using @morteza, as your base settings are really odd. That way members can help you sort the fundamentals.
  2. morteza
    morteza New Member
    - 37Coins
    My problem is not hardware for now the problem is when i run the game simTools recognize the game but i can not get telemetry data roll, pitch... on the Tuning Center, only Yaw goes to -180 and all others are 0.
    my game is Tom Clancy's H.A.W.X not the second edition.
    I am not sure where is the problem ,Is it from the plugin or me?
    153,830Coins
    +11,151 / 57 / -2
    The problem is yours @morteza.
    Setting up a plugin and motion profile is a final step. The first is that SimTools needs to communicate with the hardware and it is impossible to give advice if you are unwilling to detail the fundamentals of what hardware and code is used to connect that with SimTools.
  4. morteza
    morteza New Member
    - 37Coins
    Hello
    OK this is all of my settings please check theme.
    I do not have any Hardware for now but in the next i will use a PLC which 2 AC motor connected to it.
    My hardware interface is serial.
    GameManager Settings:
    GameEngine settings:
    Axis Assignments:
    Interface Settings:
    I test serial output on serial terminal, all thing work fine.
    Output Testing:
    works fin.
    And when i run game :
    nothing work and in serial terminal i see 127,127(for zero 8 bit data)
    Thank you for your time.
      126.4 KB
      811
    153,830Coins
    +11,151 / 57 / -2
  6. morteza
    morteza New Member
    - 37Coins
    do you test this plugin @noorbeast ? Or Is any body here who get telemetry data from this plugin?
    my problem is i can not get telemetry data and view theme on tuning center.
    i think my settings for interface and Axis management is right but them not my problem for now.
    thank you.
  7. Sijmen
    Sijmen New Member
    131Coins
    Morteza,
    Did you found out what the problem is/was? I think I have the same issue. My setup works fine with Falcon BMS and NFS 2005. but when I start HAWX, I only get YAW at 0% in virtual axis, just like you.
    I use the original HAWX on Windows 10 (64bit). I does not ask for a path for patching.
