2DOF12V to 3DOF 24V
Discussion in 'DIY Motion Simulator Projects' started by lemaitre, Sep 13, 2017.
  1. lemaitre
    lemaitre Member
    - 111Coins
    Two years ago, I had made one 2 DOF quite mobile, he(it) worked very well but engine of windscreen wiper 12 volts Are one can light For an any motive(mobile).
    I put afterward a Tub, lighter siége and more sport
    Here I removed the basis for its transformation into 3DOF. I keep the upper part with the gimbal
  2. lemaitre
    lemaitre Member
    - 111Coins
    Here is the base(basis) which has an axis on rotation in front and wheels coated with teflon. They rose in bow(arc) with regard to(compared with) the axis before. The simulator will revolve of 10 ° to the right and 10 ° to the left approximately.
  3. lemaitre
    lemaitre Member
    - 111Coins
    And here are wheels
  4. lemaitre
    lemaitre Member
    - 111Coins
    And here is the axis before with its rotation
    I have to adapt the new motor supports
  5. lemaitre
    lemaitre Member
    - 111Coins
    For the noise of travel of the simulator, wheel teflon are great, but for a comfort total I is of use to me as a carpet anti sliding of load used on heavy trucks
    Or under washing machines among others
    For the mechanics, I had this idea with the possibility of regulation, I made that this after noon(south) after the work[​IMG]
    I have a travel(movement) max of 17 cms of every quoted(esteemed), what makes a travel(movement) of 10 ° to the right and 10 ° to the left.
    Wheels run(drive) great well and the axis also, practically no strength to move the whole
    I painted in matt black
  6. lemaitre
    lemaitre Member
    - 111Coins
    I printed on my printer 3d home-made cogwheels
    I drew 3d and printed with my printer 2 support(medium) for sabertooth 2x32.
    I installed(settled) them in the new casket, because I began again everything to have more place(square) for connection the casket is in part and linked with different taken[​IMG]
  7. lemaitre
    lemaitre Member
    - 111Coins
    I made my first test with simtools demo, because I still have no license(Bachelor's degree). I have either no game(set,play) " live for speed ".
    With the test mode of axes, everything move, please, great satisfied
    Still the finish has to make
    • Like Like x 5
  8. lemaitre
    lemaitre Member
    - 111Coins
    Thank you very much for the licennce
  9. lemaitre
    lemaitre Member
    - 111Coins
    my dof finsh
    • Winner Winner x 3
  10. hannes27
    hannes27 New Member
    Linz
    275Coins
    Hello lemaitre
    Your simulator look really fine.
    I am an absolute beginner.
    Would you tell some think about the Motors please.
    And othef specs would be also interessting.
    Thank you!
  11. lemaitre
    lemaitre Member
    - 111Coins
    this is 24VDC truck wiper motors,
    because 12V car wiper motors aren't enough strong for supported a full motion simulator and they break easily.
    Now with 24V motors, it's work well, and for now they didn't break
  12. hannes27
    hannes27 New Member
    Linz
    275Coins
    looks really fantastic!
  13. lemaitre
    lemaitre Member
    - 111Coins
    I installed harnesses
  14. lemaitre
    lemaitre Member
    - 111Coins
    I would like to know if we can move the simulator on a video
  15. lemaitre
    lemaitre Member
    - 111Coins
    hello..
    can we move the simulator on any video with
    Ride Video Player
  16. creazyrider
    creazyrider Active Member
    france
    850Coins
    I think you can use it with a rollercoaster simulator but I don't know if it can work with a movie, you'll need a plugin for each movie with the data of surge, heave, ....
  17. yobuddy
    51,524Coins
    The Video Ride Creator allows you to script a telemetry file for use with a video.
    it's better suited for reformatting the telemetry file of an existing ride film currently.
    But you can script a video telemetry file by hand should you have the time.
    Eventually I want to be able to sync captured video with a captured telemetry file.
    But it's not quite there yet.
  18. lemaitre
    lemaitre Member
    - 111Coins
    Thank you for your answers
  19. lemaitre
    lemaitre Member
    - 111Coins
    I want to install the key of license, but do not work any more, because j changed hard disk
    I installed him on test pc for 2 other projects of simulator, but pc was not rather powerful
    Is that why I do not draw to install him any more
    153,758Coins
    That is a matter you will need to take up here on the SimTools site: https://simtools.us/contact-us/
