SimTools Presets 2DOF JRK seat mover, big worm gears
Discussion in 'Game Engine axes presets' started by bsft, Nov 6, 2013.
  1. bsft
    ok then, try as suggested , put in one force at a time, fiddle with tuning centre numbers, then once that force is right, set it to 0%, then set the next one, work with that force, change motor direction if need be to get it leaning correctly.
    I know my sim can sit level on game menu, but when I go onto the track, if the track has camber, the sim leans. I know Brands Hatch is very pitch and rolly with lots of camber. So I did each force separately until it sat right, then I mixed then all up.
    Give that a run .
    Dave.
  2. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    Hello, Now I did what you said. The forced individual are good but mixed up it still leans a little bit to the right/left on a straight road. Also the heave don't work. The tuning center registrates heave between 1.1 and 0.9 now i like to set the min max to a number below 1 but it cant... When i put in the number 0.5 and save the settings it make it 5... I hope you can help me out :)
  3. bsft
    back space the numbers till they are gone and type in 0.5
  4. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    Is that really the solution? I want to check directly but i am at work for 6 more hours :p
    Is there a matrix to see what happens when max is 10 instead of 1 and min 10 instead of 1 what really happens with the car, like gears shifting etc.?
  5. bsft
    Thats all I do, I delete the number by highlighting it and backspace thats in there and I type in what I want. It works for me and others.
    With gear shift feeling, I get that from surge force, hence a smaller number in max and a larger number in min.
    Did you read the document? is there something i havent made clear?
    I tried to write a simple doc to help people get going.
  6. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    Your doc is perfect. Only the numbers don't work, ill get back for this later today to communicate the results :) I hope it works because heave is a important aspect for the feeling of the car i think...
  7. bsft
    did you click after pausing the game "capture max min" box? Then try to change the numbers? the click "save settings".
    I have moments of stupidity and forget that step myself.
  8. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    I start the tuning center, then click capture min max, drive around, pauze or shut down the game, fill in the numbers, and click save settings, then stop capture capture and start the game again...
  9. bsft
    Pause, dont shut down the game
  10. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    Ok, iracing does not really have a pauze function because its online. So stopping the car is also good?
  11. bsft
    iracing, sorry, havent played it, that might be a problem.
    You can dig into the files directly in simtools folders and change it manually.
  12. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    Really? So the file where the numbers are stored is editable? Where can i find this file? :)
    Here: C:\Users\Your Name\AppData\Local\SimTools\GameEngine\MaxMinProfiles map ?
  13. bsft
    C:\Users\yourname\AppData\Local\SimTools\GameEngine\MaxMinProfiles , yep, thats the spot, open the file with notepad, adjust, save, rinse repeat!
  14. Roel
    Roel New Member
    454Coins
    2DOF, JRK
    Hello, changed in the file it to 0.05 and no reaction at all... i am hopeless now... :(
  15. CoachKalk
    CoachKalk Member
    970Coins
    I don't mean to hijack a thread, but I stopped in here to get some ideas on my settings and I have a question. I have been trucking along thinking my %'s had to total 100%, but based on the examples shown here my "thinking" has once again been shown to be whacked. Each motion can be set from 0 to 100%?
  16. bsft
    its recommended that each force in the axis assignments have a percentage total of 100% , so if you have 5 forces, they are supposed to total 100%, meaning , 20 % surge, 20% sway , 20% heave, 20% pitch, 20% roll.
    However I have found that some forces need to be set higher, granted it brings the total up above 100%.
    Its recommended that each force is worked on separately , so @Roel , put all other forces to 0 , and set heave only at 20% as a start, try then finding a smaller number to give you the desired effect. If 0.05 is too low, move it up a bit, say to 0.1. If you get some slight movement, then try setting percentage higher.
    In Dirt3, for me, my heave is 65 % , because I simply cannot get a decent movement even with tuning centre number changes. My totals in the dirt3 profile are 140% I think. Its because with my sim, some forces at 20% did not feel right. So I needed to bring the tuning centre number higher and the force % up to suit me.
    I really dont know about iracing, maybe @eaorobbie can help with a profile setting for that game, I recall he plays it.
  17. riton
    riton Active Member
    1,006Coins
    I have a question:
    where to limit? in the% of the axis next to the force, eg: Roll 100%, or in the Boundary filter?
  18. noorbeast
    152,373Coins
    +11,076 / 56 / -2
    The % is the Axis Allocation for each force and should total around 100%, see here for an overview for creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Leave the Boundary and other filters alone until the basics are right in the motion profile. The filters are for tweaking the profile and you need to know what each does.
  19. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    how many NM worms motors working?
  20. Sebj
    Sebj Active Member
    Canada
    492Coins
    iRacing
