Question LFS plugin works perfectly /DCS plugin 2.0no DATA
Discussion in 'SimTools DIY Version' started by jpdesvals, Sep 22, 2017.
  1. jpdesvals
    jpdesvals New Member Gold Contributor
    new-caledonia
    134Coins
    Hello ,
    I finaly get LFS plugin to test the output data on tunning manager and virtual axis with the interface configured as advised when no motion sim or motors connected : works perfectly.
    DCS plugin , same interface setting and same axis configuration : no output data on virtual axis and tunning manager .NO DATA .plugin installed and check , game running blue color ..
    Very frustrating , i would like to know if there is something to see with the export.lua of the DCS plugin and if there is another DCS plugin to test with .
    I assume everything is well configured (axis manager and interface settings) otherwise LFS would not work .
    Thanks for helping i will put pictures of the settings tonoight .
  2. jpdesvals
    new-caledonia
    134Coins
    Update : tested with cliff of dover plugin and CLOD game , output data are present and virtual axis working ..
    Very strange ..
    There must be something with DCS plugin
  3. value1
    14,239Coins
    I downloaded the plugin from here, patched the simulation (C:\Users\<me>\Saved Games\DCS) and flew the A-10C, SU-25T and TF-51D. It almost made me puke but I have data in GameEngine and TuningCenter.
    What path have you used for patching?
  4. jpdesvals
    new-caledonia
    134Coins
    Hello ,
    Yes that is where i did download the plugin from value1 , and the right path to apply the patch ( i did checked that the .lua was created in the script forlder ).
    I did a test with IanBFF software for 6 dof motion platform and get all the telemetry output..
    i did try unpatch , clear the folder , repatch ..nothing
    Very strange when i get telemetry from CLOD and LFS ..so that should not be a pb from my simtools setup ..
    I will continue investigate otherwise i will have to use ian BFF sofware ..
    Ty for replying .
    JP
  5. jpdesvals
    new-caledonia
    134Coins
    OKI solved !!
    It was the Windows decimal separator problem as my pc is in french had to dig a little bit !!
    What a ... Dcs uses this decimal and not the other game
