Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Hardware malfunction? Not likely - here is why. I am able to move both sns5s in xsim conventer.
    here is the pic of it with 2 scns found and running. I close x-sim converter and start SimTools. This is what happens. One com is blank, the other com4 is visible and the seat moves. So both scns are fine I guess
    I define both coms in ST21 and hit save - than I restart ST21 and the blank is still on
    Somehow I was successful to start both scns5s and fired the iR but ST stopped working - such a window popped up - so do you still think this is hardware problem?
    UPDATE - It is not a hardware malfunction for sure - I downloaded new Lince 2.0 trial and it works flawlessly.
  2. yobuddy
    51,008Coins
    Select the "-" for interface 1.
    Then close and restart SimTools and re-setup interface 1 for the missing SCN.
    Click save and restart SimTools again.
    They both should center.
    let me know how it goes,
  3. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    I did it before - after some tries I am able to run both actuators with SimTools 2.1 but when I start iR ST 2.1 sort of crash and info pops up - program stopped. It works perfect with the newest Lince 2.0 by Logykal.
  4. yobuddy
    51,008Coins
    try this,
    See if this help buddy.
  5. Ruckasroo
    Ruckasroo New Member Gold Contributor
    Australia
    73Coins
    3DOF, Motion platform
    hi all.. first time poster so please if something is incorrect, let me know. I'm having issues with simtools 2.1 GAME MANAGER only.
    For some reason i am getting the below error (see image), which i never had up until the weekend. No major changes to anything. SimTools Game Engine and Plug In both open fine and i can assign my JRK's and load DOF values etc. I have uninstalled and reinstalled simtools couple times, but still have this error. once the error appears, SimTools_GameManager.exe deletes from the SimTools folder (c:|Program Files (x86)\SimTools\)
    There are no issues with resources. Looking at task manager etc, i am not exceeding any CPU or memory (again, no changes to hardware and worked fine up until weekend).
    Any pointer would be much appreciated.
  6. yobuddy
    51,008Coins
    What antivirus are you running @Ruckasroo ?
    As it could have updated maybe?
    Maybe try uninstalling your antivirus and then reinstall it.
    My guess is its a "Adaptive learning" update that happened.
    Others with odd problems have been told to reinstall the AV to reset the "Adaptive learning" client.
    So that's what I would try.
  7. Ruckasroo
    Australia
    73Coins
    thanks yobuddy. using McAfee. will give that a try. appreciate the suggestion.
  8. yobuddy
    51,008Coins
  9. Ruckasroo
    Australia
    73Coins
    thank you @yobuddy
    removed AV and re loaded Sim 2.1 and works again. Much appreciate the assistance.
  10. cruzebabuze
    cruzebabuze Active Member
    135Coins
    ok everyone, I have been using 1.3 for a long time and love it, so I decided to buy a pro licence of version 2. I installed the new software and now my sim is down and does not move anymore. I am using smc3 and it still work just fine in the smc3 software but when I go into the new xsim 2, it does not work anymore. I used the same interface settings than on my 1.3 version???? please I need some help, I am getting a little frustrated. thank you in advance
  11. cruzebabuze
    135Coins
    ok forget my last post I figured it out. you have to add a next to your axis. thank you
  12. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hi, did you download the new version of the games plugin you use? Plugins for 1.3 are not compatible with 2.0.
    Ciao
  13. cruzebabuze
    135Coins
    yes I did thank you, it was because I needed to add A to the axis. it works now. thank you
  14. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Have you the new plugin for the new SimTools version?
    The old plugin not work with new SimTools... :thumbs
    152,027Coins
    +11,062 / 56 / -2
    You can purchase a Pro license: https://simtools.us/license/
    But uprading is also possible from a DIY license to Pro. You can upgrade a DIY license to Pro for $29.99.
    Log into SimTools.us: : https://simtools.us/member-login/
    Use the email you purchased the Licenses with, and if you don't have a password, click reset password.
    There you will find an upgrade path for a DIY license to Pro.
  16. noorbeast
    152,027Coins
    +11,062 / 56 / -2
  17. yobuddy
    51,008Coins
    yobuddy updated Motion Simulation Software SimTools with a new update entry:
    SimTools v2.2
    Read the rest of this update entry...
    • Like Like x 5
  18. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    Sounds good, thumbs up cheers!:thumbs
  19. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Great christmasnews !! Tks. Simvibe are functional?
  20. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    "All support for GameVibe completed and tested extensively!"
