F1 Motion Simulator // 5th monitor
Discussion in 'DIY Motion Simulator Projects' started by foppaul, Sep 28, 2017.
  1. foppaul
    foppaul Member
    Nederland
    198Coins
    Sneak preview of the last post:
    A few weeks ago I started to build a Simulator. It's just a trial so I dont want to spend to much. That is why is started a thread here so I could try the software for free. I will keep updating this thread. If anyone has any questions I will try to help, but my English isn't very well.
    Paul
    • Like Like x 6
  2. Limongi
    Limongi Member
    Vancouver, Canada
    - 7Coins
    That's a very nice bit of aluminum fabrication, you must have a great combination of low weight and stiffness. Did you weigh the upper frame ?
    152,373Coins
    +11,076 / 56 / -2
    Nice work, I will look forward to following your updates.
    There is an eligibility criteria for a free license, which includes length of membership and progressing your build thread: https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.262/
    That looks to be a CV joint used for the pivot, if it allows lateral rotation then you will need to add a panhard style rod between the top and bottom frame to prevent torsional twist
    With wiper motors you need to ensure they are ground isolated: https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
  4. Paddy1970
    Paddy1970 New Member
    Durham
    374Coins
    Some fantastic fabrication skills on display there, very nice work.
    • Agree Agree x 4
  5. foppaul
    foppaul Member
    Nederland
    198Coins
    @Limongi No sorry I didn't weigh the frame. But i need to take it appart before painting so I will weigh it then.
    @noorbeast Homokinetic joint don't allow lateral rotations so I should be fine. Thanks for the advise!
    Yesterday I mounted the pots and finished up the wiring. Should be ready to test the motion in a few days. Just hoping the motor's are strong enough. I used the point of mass for my cv joint, but when the seat turn forward the point of mass moves so the motors have to come up with a lot of force.
    I will post some photo's later.
  6. creazyrider
    creazyrider Active Member
    france
    850Coins
    The upper frame looks very nice ! Did you weld it with a TIG ?
    Why did you double the bottom frame ? to limit torsion ?
    Nice work.
  7. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Your upper frame looks great! Superb craftmanship
  8. foppaul
    foppaul Member
    Nederland
    198Coins
    Thanks guys!
    @creazyrider I've seen some simulators who lift their own feet while moving the seat from left te right. To prevent this I decided to make the frame stiff. Another plus side is that I can use the space between the square tubing frames to mount all the electronics.
  9. foppaul
    foppaul Member
    Nederland
    198Coins
    Quick update, mounted the pots to test the system.
  10. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I got the same connectors yesterday, for 7 contacts each.
  11. foppaul
    foppaul Member
    Nederland
    198Coins
    I've also got some connectors with 8 pins (4 pins on the ones used in the picture). But I decided to use a different connector for each component. This makes is easier to changes some parts easily when necessary (update or a broken part).
  12. foppaul
    foppaul Member
    Nederland
    198Coins
    Hi Guys,
    Just a short update, i'm in the middle of my school exams so unfortunately I won't be making any progrogress soon. Just recieved the diy license, thanks a lot!! And started figuring it out. Also mounted everything on the simulator and started testing with just Arduino software and codelines to make the motors move to check the connections and polarity. Thinking about buys two more montiors when everything works haha. I'll post some pictures of the testing later.
    • Like Like x 5
  13. Limongi
    Limongi Member
    Vancouver, Canada
    - 7Coins
    Looks so good, I'm excited to see the results in motion. Aluminum really takes it up a notch in aesthetics. I assume by position you're going for an open wheel feel?
  14. foppaul
    foppaul Member
    Nederland
    198Coins
    @Limongi Yes, that is correct!
    Just 3D printed some parts. Those prints are for a RGB RPM bar. The larger bar is used to mount the 8-bit ledbars and the smaller box is used to protect an Arduino Nano. I need to brush the plexiglass to make it a bit more blurred as an experiment. If it doesn't look good I will cut a clear one.
  15. Muscled_Dog
    Muscled_Dog New Member
    217Coins
    Whoahh! Really cool! Congratz!
  16. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    looking good!
    good job!
  17. foppaul
    foppaul Member
    Nederland
    198Coins
    Connected the circuits, installed the software and this is the result:
    I used Simhub to sent a signal to the Arduino Nano
  18. foppaul
    foppaul Member
    Nederland
    198Coins
    First some pictures:
    Finished the build a few days ago and started testing the setup. But i've runned into some issues... when i connect the arduino to my notebook and send some lines of code by the arduino serial monitor the seat starts to move. So I was really happy. I've connected everything right haha. But, i can't figure out how to setup simtools. I've used all available guides and it just won't move.
    When I start the simulation by starting to test outputs the motors turn to their home point (the middle). But when I move those bars with roll and pitch, nothing happens.
    Can anyone help me with this problem? I'll provide every sreenshot needed, but I can't right now because i'm posting this from school haha.
    Thanks a lot, Paul.
    152,373Coins
    +11,076 / 56 / -2
    Hard to take anything but a stab in the dark, as you have not said what code you are running. If it is SMC3 then the Interface Settings for SimTools 2 should be like this:
    [A<Axis1a>][B<Axis2a>]
    Set for 10bit binary output
  20. foppaul
    foppaul Member
    Nederland
    198Coins
    Sorry for the late reaction..
    I am indeed running SMC3 tested the output with the untility tool and it works fine. I'll try your settings.
