Question GameManager and Engine wont start fine.-net framework buggy
Discussion in 'SimTools DIY Version' started by qstyle, Oct 1, 2017.
  1. qstyle
    qstyle racing just for fun
    130Coins
    2DOF, SCN5
    Hi guys,
    after updating Win10 both Simtools progs wont start fine and my sim is now out of order.
    by starting one of the simtools following message pops up ( see screen)
    clicking on details the complete message :
    System.ArgumentException: The path is not of a legal form.
    at System.IO.Path.LegacyNormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
    at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)
    at System.IO.Path.GetFullPathInternal(String path)
    at System.IO.DirectoryInfo.Init(String path, Boolean checkHost)
    at System.IO.DirectoryInfo..ctor(String path)
    at SimTools_GameManager.frmMain.If_StartWithWindows_Checked()
    at SimTools_GameManager.frmMain.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2053.0 built by: NET47REL1
    Assembly Version: 0.2.1.0
    Win32 Version: 0.2.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    xdFZySjlJvJuSyJCrKNFqiOVuiS
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.2053.0 built by: NET47REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    i cant solve the prob.
    i have tested clean up netframe ,
    delete gamemanagerprofiles in c:user:appdata/local/...
    nothing worked fine for me...maybee one of you got the same prob and can help me to fix the prob..
    installed simtools 2.1 under win10
    bought project cars2 but cant play it for now !!!!
    tnx for your time and a nice sunday
    daniel
      108.6 KB
      723
  2. yobuddy
    51,525Coins
    Hi Buddy, you wrote to me:
    What all did you reinstall?
    What was the cleanup tool you used buddy?
    How did you clean the registry, what tool.
    Just trying to catch up on what you have done so far is all.
    It's sounds like .net is not installed correctly thou?
  3. qstyle
    130Coins
    2DOF, SCN5
    Hi yobuddy,
    wow tnx for the quick reply !!!
    first i have uninstalled simtools.
    net frame deactivaton was :systemcontoll/devicemanager/progs and feature uncheck the box for installed net4.72 ( 3and 3.5 are unchecked too). i think my machine only running 4.5? under servicepack kb ?????? with the winupdate because it is a part of win 10.
    then i have used the cleanup net tool from a german pc expert to check if i have done it right (http://www.chip.de/downloads/NET-Framework-Cleanup-Tool_81722032.html)
    now i have used the regedit to search for all componets of simtools (also the registry of simtools) and cleaned it manually.
    restarted the machine ----finished with a cleanup with the prog ccleaner ( all id keys clear)
    after this i installed simtools again ......same bugreport.
    greetz
  4. yobuddy
    51,525Coins
    (Just so everyone knows, SimTools does not use the registry.)
    Please try to install .net 4.0 client and see what happens buddy.
