value1
pCARS2 Plugin 2.0.5.4
SimTools game plugin for pCARS2
  1. value1
    15,026Coins
    or Project CARS 2 since update to 2.0.2.2
  2. Vboull
    Vboull New Member
    181Coins
    can I do a manual installation of the plugin because I do not find the dll file in the directory of the games. I specify that the game is not installed on the disk c:
  3. franccac
    franccac New Member Gold Contributor
    Barcelona
    32Coins
    Good news, I have it Working, I tried it two times.
    I think that the problem is in the launching protocol o something like this. If open Simtools and after open the game, it don't work, but if i minimize the game and close completely and open again the GameManager and Game Engine it start to work. I have Shared Memory in ProjectCars2 option, I haven't tried it in Project Cars1 shared memory type again.
    what do you thing?
    while It don't works correctly is an option to use it.
  4. value1
    15,026Coins
    Use the off and on button of GameManager instead:
  5. franccac
    Barcelona
    32Coins
    I try it several times to use the Axis testing and doesn't work, I had to shut down Game Engine and restart it. After restart the GameEngine the sim starts to work inmediatly without touching anithing.
  6. Andy Booth
    Andy Booth Active Member
    Malaysia
    430Coins
    OK here is my problem with the interaction between simtools, PCars 2 and my Renovatio
    SRD-M3 SLI display.
    I get this message up when I launch PCars 2 from the SRDM3 screen:
    So I go into PCars 2 and set the shared memory but I then get this pop up
    I think because of this mismatch, it prevents the motion rig from operating. PCars 2 still works fine.
    If however I launch PCars 2 on its own (not through the launcher), PCars 2 works fine with motion but obviously, I dont have my SLI display.
    I think I'm using the latest plugin.
    Anybody got any ideas?
    Andy
  7. Vboull
    Vboull New Member
    181Coins
    If i lauch simtool after the game it's work :thumbs
  8. value1
    15,026Coins
    Hi Andy
    Can you please run this plugin and share a screenshot of Tuning Centre and of the plugin message box about the memory version mismatch? Thx!
  9. Andy Booth
    Malaysia
    430Coins
    Hi value1,
    I will try tonight and report back to you.
    Andy
  10. Andy Booth
    Malaysia
    430Coins
    Hello again value 1.
    Did as you asked and got the same result of no motion. Images attached.
    Sorry images are poor and I couldnt seem to reduce the size, sorry.
    Any ideas?
    Andy
  11. Andy Booth
    Malaysia
    430Coins
    Thanks John, I'll give it a try. I didn't try initially because of the command from the SLI Display, but hey, Ive got nothing to lose.
    It's just really annoying that I cant get the display to work with PC2 because they way I have the FOV to seem correct, I cant see any dashboard.
    Andy
  12. Phil Barnes
    Phil Barnes New Member
    - 104Coins
    Morning all
    I am using Sim Pro Tools v2 and this plugin to run my wind mod.
    Been working fine after a few hiccups (mostly self inflicted to be honest) and now it is ok, a new problem has come up.
    Private practice, online practice and qualitfying it works a dream. Then, we I get sent to the grid to start an online race, the fans no longer work...?
    This only happens in online races only. And only when I get sent to the grid......
    Anyone else had this? Any ideas what it could be? Thanks in advance....
    Phil.
  13. Phil Barnes
    - 104Coins
    ........and now I cannot get it to work at all properly.
    Sometimes the fans just come on full whack...and that is it.
    Tried resetting the ardino and uploading the sketch I know works. No joy.....
    Very frustrating!
  14. Andy Booth
    Malaysia
    430Coins
    Hi Phaze11111,
    Tried what you suggested (switching shared memory to Project Cars 2) with no change.
    Without the SLI display, motion is fine. With The SLI on, no motion.
    Could it be something to do with the shared memory information only being able to go to one other device?
    Im clutching at straws obviously.
    Andy
  15. michael haertsch
    michael haertsch Member Gold Contributor
    - 206Coins
    Who i can find the Pcars 2 API daten for the XSimPlugin.
    XSim havent a Plugin.
    XSim Developer need Api daten??
    I musst search but i cant find.
    Simtools have a Plugin,
    this have Api daten for PCars 2.
  16. noorbeast
    152,003Coins
    +11,061 / 56 / -2
  17. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Just bought the DIY version of Sim tools last night and installed ver. 2.1, I've read through every post I believe and still can not for the life of figure out why I have no motion. All games are patched and turn blue, all in games settings are set for motion but none have worked.
    I've tried pcars 1 & 2 and also dirt rally. I've spent more than 10 hours and I'm all but defeated at this point. HELP!!!! LOL
  18. noorbeast
    152,003Coins
    +11,061 / 56 / -2
    Please start your own thread and post pictures of all of your settings.
  19. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    pCARS 2 update 3.0 pc just came out today and I have no in game motion. Everythings set in game properly or as it was before update. Game manager turns blue when starting game but no motion and also unable to capture motion. Anyone else having trouble since game update? Thanks.
  20. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    UPDATE..... It's now working. I change the in game shared memory setting to pc1 and got it working. I had it set on pc2 which did work before todays game patch. Maybe someone else can also verify this. Thanks
