Showroom My first project 2DOF simulator for Playstation 4, from Chile (2017)
Discussion in 'DIY Motion Simulator Projects' started by santanadany, Sep 7, 2017.
  1. santanadany
    santanadany Member
    Chile
    605Coins
    32 mm, Today, a friend (who weighs 88 kg!) has gone up and everything has worked well ;)
  2. santanadany
    santanadany Member
    Chile
    605Coins
    @Alexander Reichl , Total Weight : Playseat : ( 19,8 Kg) + Subwoofer (1 kg) + Logitech G29 ( 5,35 kg)= 26,15 Kg
  3. GRONEXP
    GRONEXP New Member Gold Contributor
    chile
    105Coins
    2DOF, 3DOF, DC motor, SCN5, SCN6, SimAxe, Arduino, Motion platform
    hola @santanadany por fin alguien de mi tierra, soy de copiapó te cuento tambien estoy tratando de realizar un simulador 2dof, he tenido algunas complicaciones conexion ya que estoy trabajando con software sintools 1.3, no he podido recibir datos de telemetria con arduino. si me puedes ayudar con algunos tips seria genial. solo he realizado pruebas con sim3Utils v0.6 con motores de pruebas funcionan correctamente.
    e usado varios datos configuracion interface <Axis1><Axis2>
    Gracias
  4. GRONEXP
    chile
    105Coins
    hello @santanadany finally someone from my land, I am from copiapo I am also trying to make a 2dof simulator, I have had some complications connection since I am working with software sintools 1.3, I could not receive telemetry data with arduino. if you can help me with some tips would be great. I only ran tests with sim3Utils v0.6 with test engines working correctly.
    e used various data configuration interface <Axis1> <Axis2>
    (attached SMC3UTILS video working with correct motors)
    (https://www.youtube.com/embed/uRzq6Kx6Va8)
    (test engines with simtools 1.3 axis test without stock)
    (https://www.youtube.com/embed/4yyDr1xKgIo)
    Thank you
    Traductor de Google para empresas:Google Translator ToolkitTraductor de sitios web
    153,027Coins
    +11,116 / 56 / -2
    It should be like this:
    [A<Axis1>][B<Axis2>]
    Set for 10bit binary output
  6. GRONEXP
    chile
    105Coins
    thanks for the indications, ask at the time of testing the axis testing should turn on the Tx and Rx lights of the Arduino or RX only and how can I run simtools and sim3utils at the same time to check engine work.
  7. GRONEXP
    chile
    105Coins
    thank you friend, the tests are a success and we will soon be contributing and giving the avace of the project to develop.
  8. santanadany
    santanadany Member
    Chile
    605Coins
    @GRONEXP great!
    well, whatever you need and can help you, just tell me.
    here are many people who help and know more than I ;),
    You will not believe me !!, jajaja. I studied at the "ETP", and I was in Caldera at the last weekend!, now I live in Stgo.
    Well, tell us how you are develops your project.
    I recommend this:
    https://www.xsimulator.net/communit...-and-2-pins-direction-hbridge-motomonster.67/
    and
    https://www.xsimulator.net/community/threads/from-atoz-2dof-arduino-wiper-playseat.4616/
    look at my simtools interface settings.
    best regards copiapino como yo!!
  9. creazyrider
    creazyrider Active Member
    france
    850Coins
    Hi Santanadany,
    could you send me the code for the arduino to make it working with servomotors only (like with your barbie chair) ?
    I build a small model too.
    153,027Coins
    +11,116 / 56 / -2
  11. santanadany
    santanadany Member
    Chile
    605Coins
  12. creazyrider
    france
    850Coins
    thank you.
    I'm working on it
  13. santanadany
    santanadany Member
    Chile
    605Coins
    Final Test in Mexico F1 2017 UDP !! ( Thanks @vthinsel ) with excellent Sway
    https://photos.app.goo.gl/XWwZc5IcuTWNBWYi2
    @noorbeast final photos with reinforced structure
    with my new lap top given by my wife :blush
    Now to burn the motors of the wipers, hopefully it will help me to improve my times in real life ..:(
    Thanks a lot !:p:D:D:D
  14. santanadany
    santanadany Member
    Chile
    605Coins
  15. creazyrider
    france
    850Coins
    Very nice ! I was closed to sell my PS4 pro to buy a computer, so now I will wait a little. Do you know if PC2 will work in VR ?
  16. santanadany
    santanadany Member
    Chile
    605Coins
    All Games with UDP is Only in Cinematic version (Similar to 226" TV, it's like playing in a movie theater), the feeling is fascinating
    Gran Turismo Sport, they have a small section in VR mode, very realistic and Drive Club VR, it is 100% VR but it is more an arcade than simulation, so far both do not have UDP, it would be a good project for @vthinsel
    regards
  17. simupp
    simupp New Member
    murcia
    - 89Coins
    Motion platform
    Hi !. Do you know if is this possible with PS3? Games with udp + PS3 + VR + pc + arduino. Thanks. Regards.
  18. santanadany
    santanadany Member
    Chile
    605Coins
    I do not know, if Project cars or Assetto Corsa works with UDP in play station 3, if you can corroborate that, it should work
    regards.
  19. santanadany
    santanadany Member
    Chile
    605Coins
    Playstation VR is only for Play station 4
  20. simupp
    simupp New Member
    murcia
    - 89Coins
    Motion platform
    Thanks for yours answers. Even if Playstation VR is only for Play station 4 I am interested in Ps3 with UDP.
