Question XP11 X-Plane 11 no data coming through SimTools
Discussion in 'SimTools DIY Version' started by SixDegreesOfFlight, Oct 5, 2017.
  1. SixDegreesOfFlight
    SixDegreesOfFlight Well-Known Member
    Secondary Teacher: Systems Engineering & Computing
    Melbourne, Australia
    2,222Coins
    Simulator
    Commercial or DIY: DIY
    DOF (Number of axles ): 6DOF
    Actuators (DIY, SCN5 etc.): DIY
    Interface (Arduino, SCN, Mega, DIY etc. ): Arduino Uno
    SimTools
    Version Number: v2
    Game Plugin where the error is happening: X-Plane
    Settings (Relevant settings)
    I have setup the axis correctly in that I can control roll, pitch, heave etc via the Output test window of SimTools.
    SimTools Manager reported that X-Plane 11 was successfully patched. However, I haven't managed to get Tuning Center to receive any data from the sim.
    SimTools Manager reports the game running before XP11 main splash screen takes over the screen.
    SimTools Engine crashes immediately once XP11 starts. If I restart it once the game is loaded, it doesn't crash again.
    XP11 Data Output screen shows ticks in the 'Network via UDP' check boxes (see image) and the IP Address is showing 127.0.0.1 Port 4123
    Any help would be appreciated.
    152,373Coins
    +11,076 / 56 / -2
  3. SixDegreesOfFlight
    2,222Coins
    @noorbeast
    Thank you for posting the link so quickly :thumbs
    Hooray - its working now with X-Plane 11
