Kermit Kong's 6DOF Project
Discussion in 'DIY Motion Simulator Projects' started by kermitkong, Jun 15, 2016.
  1. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,239Coins
    I’d select the DC80.148 version, the biggest one.
  2. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    Awesome Thanks
  3. kermitkong
    1,239Coins
    now its time to show up the next milestone for the Actuator.
    The tube is made of PMMA, fully transparent.
    here a quick video which shows the stuff in action.
    • Winner Winner x 3
    152,373Coins
    +11,076 / 56 / -2
    Your actuator looks amazing, a real testament to the work that has gone into it!
    • Agree Agree x 3
  5. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    Looks great, I like the clear a lot better then the translucent PVC that I have on mine. I was looking into using clear cast acrylic tubing, boy is that stuff expensive though.
  6. kermitkong
    1,239Coins
    now i had time to assemble more actuators. 4 out of 6 actuators were assembled and pretested.
    The rest 2 actuators will be completed next weekend.
    • Like Like x 6
  7. Zed
    USA
    5,844Coins
    Those PMMA tubes are beautiful! What a way to show off the actuator mechanisms! Very nice work!
  8. simupp
    simupp New Member
    murcia
    - 89Coins
    Motion platform
    Wonderful !. It look like easy but you're working hard !. Cheer up ! ;)
  9. Aussie
    Aussie New Member
    Australia
    187Coins
    Good Morning Mate. Excellent design. I've being following your Linear Actuator design for the past weeks .
    I'm going to build mine with a 1kw Servo motor for my 6DOF Simulator with my Thanos Kickstarter controller. Can I ask if you can send me the CAD or designing files of the design in case I need to change something on for for the different motor. The one I'm after is the Actuator Motor side mode mounting plate being made from Aluminum . Thanks Aussie
  10. kermitkong
    1,239Coins
    Hi @Aussie
    I will share my drawings soon.
    A 1KW ( one kilowatt) motor is too much I would say. Do you have motor controller to drive these monsters ? Normally 250-400w is ideal for motors. Please keep care of the motors stall current. If it’s more than 100A I wouldn’t use it.
    Most of motor drivers cannot handle this.
  11. Aussie
    Aussie New Member
    Australia
    187Coins
    Thank You for the reply.I will be using Thanos AMC1280USB Delux controller. I might change to a 750w AC servo motor instead.
  12. thecures
    thecures New Member
    68Coins
    but the battery of car is much of 1.3 A
  13. kermitkong
    1,239Coins
    That’s right, I found out that the Regen energy (in my setup) in terms of power (watt seconds) is relatively low, so the smaller batteries are OK.
  14. llluis
    Quebec
    1,631Coins
    What are you using for feedback? I can't see any belts inside the tube.
  15. kermitkong
    1,239Coins
    • Informative Informative x 3
  16. SeatTime
  17. kermitkong
    1,239Coins
    Not yet, it’s the 1st time I used this.
    Don’t know how it works. Hopefully we’ll enough. I will report it when I start with function tests. Stay tuned !
  18. thecure
    thecure New Member
    - 91Coins
    it's possible to how you built the actuator.....tks
  19. SeatTime
    :confused:.First read the thread and then have a look at the sites FAQ and other actuator threads, more then enough information there.
  20. dlxodud1719
    dlxodud1719 New Member
    korea
    141Coins
    ac servo can use simtool?
