Question Arduino not receiving any serial data from Game Engine.
Discussion in 'New users start here - FAQ' started by Niklas, Oct 14, 2017.
  1. Niklas
    Niklas New Member
    Sweden
    173Coins
    My Arduino is not receiving any serial data from the Game Engine.
    The Arduino speaks to com5 9600 BPS 8 Data Bit None Parity 1 Stop Bit.
    Ive reinstalled all Windows updates containing .Net Framework via Windows update since .Net no longer can be reinstalled or uninstalled on Windows 10.
    Ive searched the forums for a solution and seem to have tried everything by now.
    What am I doing wrong?
    In Picture:
    My Arduino Serial Monitor should be receiving incoming data but only returns -1
    152,373Coins
    +11,076 / 56 / -2
    In the Interface Settings instead of axis defined like this <Axis1> it is now has designate grouping for a or b for each axis assignment, like this <Axis1a>
  3. Niklas
    Niklas New Member
    Sweden
    173Coins
    Thanks, I tried that and unfortunately no luck. Nothing changed. Any more suggestion?
    152,373Coins
    +11,076 / 56 / -2
  5. Niklas
    Niklas New Member
    Sweden
    173Coins
    Didn't wanna give up that easy and I found out that I couldn't have a serial connection via Serial Monitor because it came in conflict with Simtools serial connection to the Arduino. I have no idea if this is suppose to work, but it doesn't and Simtools don't warn me that there is a conflict either. I found that out because I tried to make a serial connection via Putty to my Arduino. Putty then complained about a conflict with Simtool.
    So my solution for the debugging problem was to lcd.print the serial data to a display instead.
    In other words, it worked just fine as it was, i just couldn't see the data.
