Question SimTools V2 Dual PC
Discussion in 'SimTools DIY Version' started by tadythefish, Oct 20, 2017.
  1. tadythefish
    tadythefish Active Member
    Process automation engineer
    Slovenia
    679Coins
    Hi all!
    I have a question about the new SimTools 2 and a dual PC setup. I purchased the license and now I'm wondering how do I use the license on a Dual PC setup.... Do I use it on the PC running the Game manager or Game engine?
    I haven't started installing anything.
    Thank you!
    153,758Coins
  3. tadythefish
    Slovenia
    679Coins
    Ok I understand that I get one license.. I'm asking if I install game manager on one PC and game engine on the other. On witch PC do I need to input the license? In shot witch PC is going to be latched to? The one running Game manager or the one running Game engine?
    Thank you
  4. yobuddy
    51,525Coins
    @tadythefish License both PC's with the same license number.
    Register both with the same license.
    Take care,
    edit: be sure to set the correct ip address in both the GameManger and GameEngine.
    Both found in the tools section of each app.
  5. tadythefish
    Slovenia
    679Coins
    Thank you!
    I was thinking of doing that but I was stuck at the idea that the license would latch only to one pc...
    Yes IP.. That is not a problem.. I was running 1.3 on a dual PC setup before...
    I really don't want to ask all these stupid questions. But the licesne is one time and if I f**k up.. Well you know what I mean:))
    I was thinking of using the license on a regular PC. On that PC I would run only the Game engine (maybe embed that PC to my sim) .
    In short I thought that only the Game engine needed the license.. Not both
