Question Gimx Adapter
Discussion in 'Direct Drive Wheels' started by Artistichalo, Oct 21, 2017.
  1. Artistichalo
    Artistichalo Member
    South Florida
    511Coins
    Anyone ever use the Gimx adapter on OSW direct drive wheels ? The person that sent me the link to purchase it is using it with a Accuforce wheel and playing Forza 7 . His wheel is getting FFB and working with no issues.
  2. Gadget999
    12,132Coins
    i have a gimx and run it with a logitech wheel and a ps4
    basically you use a pc/laptop to convert the signal from one format to ps4 format
    it works pretty good but is a pita to get going
    i am building my own version of osw and will use the gimx if needed
  3. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I use gimx with an Accuforce V2. It works fine with games like forza or wrc7 which my wheel didn't previously work with. All in all it took me a few days to figure out. I was lead to believe that you needed 2 pc's or raspberry pi to run it, but you don't.
  4. Gadget999
    12,132Coins
    are you using it on a PS4 ?
  5. Sarge
    - 181Coins
    I'm using it solely on PC. Some trial and error involved to begin with, but it works flawlessly now.
    All I did was make the adapter (followed the wiki), enclose it in a case, and plugged both the usb's straight into my main PC.
    I think I was mainly confused because I never knew it could be set up in such a way.
  6. Genghis
    Genghis New Member
    239Coins
    Hi Sarge, i keen to understand what you mean by plugging both USB's in? I have just ordered their adapter (GIMX) but just wanted to get a heads up on how to connect this up, im using an Accuforce wheel, and have my shifter and pedals plugged in using a USB hub. Any suggestions or advice would be most welcome
  7. Sarge
    - 181Coins
    Hi, The adapter has 2 usb connectors. I just plugged them both into my pc then created a custom config once the firmware was loaded onto the board. I needed to install old logitech drivers for mine to work though. It took me a couple of days to get my head around it but once you've played with it for a while, it starts to make some sense.
  8. Gadget999
    12,132Coins
    with mine you need to plug the gmx, the steering wheel and the ps4 handcontroller into a usb hub
  9. Sarge
    - 181Coins
    If you are just using gimx on a pc, you don't need a ps3/ps4 controller.
  10. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi just built an adapter got it working as you said with 1 pc both end pluged into the pc working with WRC 7 however im getting the FFB dropping off after a few minutes of rallying any ideas?
    regards
    Dag
  11. Gadget999
    12,132Coins
    i suggest you go to the gimx website for help - you should be able to work out why it drops FFB there
  12. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi its ok i think ive sorted it now :thumbs
  13. Gadget999
    12,132Coins
    what was the problem ?
  14. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Well i made 2 changes at once so not sure which,
    1/ My Mmos degrees of rotation was higher than the ingame so i think if i rotated past the ingame setting the ffb would drop (ie big steering to get back on track) so i increased in game to match Mmos
    2/I decreased all ffb settings in game because it was to strong anyway OSW wanted to hurt me lol
    seems fine now run loads of stages without a problem.
    regards
    Dag
