project seat-mover 2dof of Nickrift
Discussion in 'DIY Motion Simulator Projects' started by Nickrift, Jan 9, 2016.
  1. Nickrift
    Nickrift seat-mover 2DOF
    france
    - 33Coins
    hi everybody, it's me Nickrift and am currently building my first dynamic simulator
    the aim will be to modify my existing Playseat
    I registered on the forum or PCSHM I found all the necessary bases for the construction
    I also own a G25 steering wheel + a parking brake 205 + an Oculus Rift DK2
  2. Nickrift
    france
    - 33Coins
    here is a picture of my simulator before the amendments
  3. Nickrift
    france
    - 33Coins
    I have welded Start, HERE Photos:
  4. Nickrift
    france
    - 33Coins
    Good evening everyone, to give more details, here is my current pc config, which will upgrade with arrival of CV1 of Oculus Q1 2016:
    AMD FX8350 8core 4Ghz, ASUS motherboard M5A78L-M / USB3, 8GB of DDR3 ram G Skil 1866, SSD 120Go, HDD 1To, power supply cooler master 750 w, gtx 970 video card MSI OC
  5. Nickrift
    france
    - 33Coins
    Here are more photos
  6. Nickrift
    france
    - 33Coins
    here is some info about motors and the electronics:
    2 engines 120W 24V 40rpm
    1 Arduino UNO
    1 Sabertooth 2x32
    1 power supply 24V 20A
    in fact I plan to buy a kit wanegain and his team on the site PCSHM
  7. Nickrift
    france
    - 33Coins
    Here is a map of the new kit motors
  8. Nickrift
    france
    - 33Coins
    I also recovered an empty box of pc power supply to put the Arduino and Sabertooth
  9. Nickrift
    france
    - 33Coins
    here is a "scheme" provisional disposition with new engines made with paint (I have not Sketchup)
    the scales are not well respected, but it gives an idea of the result
  10. Nickrift
    france
    - 33Coins
    I have finished welding the structure, it remains the welded corner braces
    152,977Coins
    +11,116 / 56 / -2
    Nice compact job so far.
    You will likely need more robust bracket for engine mounts, as the motors generate quite a bit of force.
    • Agree Agree x 3
  12. Nickrift
    france
    - 33Coins
    yes, I was made the remark, I must strengthen engine mounts
  13. Wanegain
    Wanegain Active Member
    Bruxelles
    2,013Coins
    As you know weld, a strengthening of the support should not be too complicated for you. Or you can use 2 brackets by motor.
  14. Nickrift
    france
    - 33Coins
    oui wanegain, je pense souder des renforts sur le coté de mes fixations moteur
    je pense faire ca le weekend prochain
    wanegain yes, I think welded reinforcements on the side of my motor mounts
    I think next weekend to ca
  15. GiovanniWig
    GiovanniWig Sir
    Engineer
    New York
    - 50Coins
    2DOF, 3DOF, Motion platform
    Its looking good, why you didnt used the 150 rpm motors?
  16. Wanegain
    Bruxelles
    2,013Coins
    Because it's much more expensive :D
    These motors are used on 120° instead of 180° to gain enough speed :thumbs
  17. Nickrift
    france
    - 33Coins
    Hello everyone
    here are some news from my simu
  18. Nickrift
    france
    - 33Coins
  19. Nickrift
    france
    - 33Coins
    these are the new simukit potentiometer mounts
  20. Nickrift
    france
    - 33Coins
    ils s' adaptent sur les moteurs 120w , tres facile a monter, une petite clef est fournie pour le serrage des potentiometres
    they fit on the 120w motors, very easy to assemble, a small key is provided for tightening the potentiometers
