My 2-3DOF Scale build Basics - get up and running?
Discussion in 'DIY Motion Simulator Projects' started by John458, Feb 9, 2016.
  1. John458
    John458 Member
    Retail
    Brisbane
    393Coins
  2. SixDegreesOfFlight
    SixDegreesOfFlight Well-Known Member
    Secondary Teacher: Systems Engineering & Computing
    Melbourne, Australia
    2,224Coins
    @John458
    Those were the motors I was originally going to get. With the 31A draw current it is just within spec of the 2x32 which is designed to work with motors up to 32A continuous but can cope with peaks double that. The advantage of that motor is that it would be easier to mount than the one I used because you won't have to cut out the 80mm hole for the fan. I used a 24V one with a 2x60 to 'over engineer' the issues that @SilentChill had reported with his rig using 2x32. The disadvantage is that if they are driven hard they may get hot and you will need to prepare for some fans to cool them down - something that my ones have built in. This is a critical decision as there are all kinds of 'knock-on' effects once you choose and buy them. Using batteries is cumbersome with weight, wiring, space etc. Not sure if my reply really helps but you need to consider all the constraints before taking the plunge.
  3. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hi @noorbeast @Pit @RufusDufus or anyone else that may be able to help.
    I have attached SMC settings as well
    Just had a quick question, been searching around for game engine settings as I have been testing my rig for the first time today with LFS.
    So just testing my 2DOF with live for speed and using the sway or extra1 setting and everything moves but it never goes back to centre.. for example if you turn left the motors move left but then stay there they don't return to physical center..so the move you turn left it the more it keeps moving the platform left until you run out of physical limits.
    How do I get the motor to move left and then when the turn is finished in the game it centers back?
    I have been playing around with washout and smoothing but cant figure it out
    Cheers
    153,938Coins
    +11,158 / 57 / -2
    If it is a 2DOF just use sway.
    Can you please post pictures of your all your SimTools settings.
  5. Pit
    30,510Coins
    First check SMC3 only if manual moving works. PWMmax=30 is very low, too low for my motors at least. If SMC3 shows no issue you can shift to SimTools.
  6. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hi @Pit and @noorbeast
    Thanks so much for your quick response, yes I have checked it in SMC3 at PWMmax=30 (its not really carrying a load at the moment) so it moves slowly but no problem back and forth, and I am only testing 1 motor at a time as I go to remove any potential errors from me. I have three motors setup and they all work (well expect I have blown one side of my monster moto on one motor so it only goes one way at the moment, so I have switched to the second motor to play with first whilst I solder up another moto later)
    So it also goes back and forth (manually by me) when I test it using the simtools engine with the output testing DOF on.
    so it must be in the axis setup I think...
    here are my setups (one motor and one DOF sway) I had the filters on zero and then tried some random settings on washout and smoothness to try and figure out what Im doing wrong. so here ya go :)
    153,938Coins
    +11,158 / 57 / -2
    Can you confirm if it moves ok in output testing.
    LFS has to be run before patching. If you did not do so then unpatch, run a lap or two in LFS, close it then repatch.
  8. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    ok @noorbeast that might be the problem ill give that a go with re-patching :) cheers
    Not sure what you mean about confirming in output testing... I can get it to move through simtools output testing by moving the slider with my mouse?
    in the meantime also here is a simple design pic of my rig...saw another person do this with a centre wheel under the whole system..it has 2 support wheels as well (not depicted with no motors attached)
    So basically I have centered the wheel physically and then have been expecting it to go left or right with the sway DOF and then always come back to the centre. but if you turn left.. it moves left then stops and then if you turn left again it moves even further out etc... it only starts to come back if I go right..but 3 left turns and its all over ha ha.
    Do i need to attach some sort of sensors?
    plan to use it for flying as well like a simple rudder feeling left and right
    153,938Coins
    +11,158 / 57 / -2
    If you go into Output Testing and start it you should then be able to move the axis with the slider.
  10. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hi @noorbeast
    Cheers ok I have done that - here are the results
    Under DOF Output testing when I move the sway slider to the left and right of centre it moves left or right like it should.. however..
    not sure if this is anything but if I move it to say to the left -21 (for example random number) and let the slider go... it moves a bit then stops, it doesn't just continue to move to the left forcing me to stop it with the "CLR" button like the axis testing does
    When I test under Axis output a - it moves left and right no problem and will continue to move unless i stop it with the slider going back to "0" or clicking on the "CLR" button
    Hope that makes sense
    153,938Coins
    +11,158 / 57 / -2
    If it moves in Output Testing then it is most likely LFS was patched without first being run. Running LFS first generates some file that are needed.
  12. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    hmm... I did what you suggested before and unpatched LFS .. launched LFS and then did a couple of painful keyboard laps ha ha... then repatched ... same problem.
    i'll give it another go thou, i might have missed shutting down the game manager and client after unpatching.... failing that I brought a Sim tools licence and registered it as well, so I will try x-plane as well and see what happens.
  13. Pit
    30,510Coins
    Short comment about SimTools, don't use washout for now, especially if you don't know what to do with it, I suggest not to use any filters as long as you don't get your rig properly working.
  14. Pit
    30,510Coins
    Addendum: just test axis output only.
  15. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hi @Pit @noorbeast
    axis testing works fine the wheel goes back and forth.
    Next unpatched LFS launched it ...then repatched using "sway" the wheel moves left and right as it should but doesn't automatically go back to the center point after turning.
    Not sure if I explained this centering issue very well and maybe I am expecting it to do something automatically that it doesnt do.
    So for example the seat rolls left as you are turning left..which is fine and then stops when you stop turning which is fine, but I need it to automatically always return the seat to the original physical center postion everytime after it moves left or right.
    Hope that makes sense... in the mean time i will try xplane :)
  16. noorbeast
    153,938Coins
    +11,158 / 57 / -2
  17. John458
    John458 Member
    Retail
    Brisbane
    393Coins
  18. noorbeast
    153,938Coins
    +11,158 / 57 / -2
    Traction loss is for the wheel you mentioned, as I gather that is what it is.
    You can use filters such as Washout for bringing an axis back, but I really don't get what you are trying to do, as you would not normally do that for a race game with sway, though you would do that with a flight game for roll.
  19. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hmm yes I am trying to do what your saying with the roll function.. have it come back to the centre. for example after say rolling to the right in a plane.. the wheel returns back to the centre (of my rig) and you then you can roll right again without running out of the physical limits of the system. (as it keeps putting you back to centre) or if you are doing a 360 roll.. the motor wheel rolls right (so you feel the roll to the right) and then when you stop rolling the physical rig returns to center again ready for the next roll.
    With the driving I'm trying to do the same thing with say you go around a corner in real life and the car forces you to the left (or right) in the seat. Thats what the wheel should do roll left or right an inch or 2 so you feel like you have been forced to the left or the right.
    and then when you finish the turn the rig (motor wheel) should return to centre of the rig ready for the next corner.
    Hope that makes a bit more sense..
    153,938Coins
    +11,158 / 57 / -2
    When properly set up sway will return when the game data dictates, there is no need to use the likes of Washout.
    For flight you can use Washout and Smoothing also works pretty well.
