Question Getting different output data
Discussion in 'New users start here - FAQ' started by Niklas, Oct 20, 2017.
  1. Niklas
    Niklas New Member
    Sweden
    173Coins
    Getting different output data depending on source.
    1# If I'm using the built in Output Testing as shown in the picture 1.
    100% and -100% on the sliders represent 32767 and -32767 in the Tuning Center.
    My Arduino then gets a perfect 0 - 255 where 127 is middle for both axis.
    2# But if I play play LFS the data in the Tuning Center is like 0.0 - 4.5 or something like that. As shown in picture 2.
    My Arduino gets stuck at 127 or 245 and tilts in between these two values when I turn the wheel. (L=127, R=255) (L=255, R=127)
    I have tried to set Axis Limiting and Axis Assignments at different % values.
    But I'm only getting a slight change of value in the max-value, like 245 instead of 255.
    What am I doing wrong?
    And isn't SimTool suppose to handle these kind of different data-sources and output the same data?
  2. Niklas
    Niklas New Member
    Sweden
    173Coins
    So no one can answer my question?
    Can anyone at least check if you have the same or a different sort of "Game Data - Output" in Tuning Center for the game Live For Speed as I do? Look at Picture 2.
  3. value1
    15,007Coins
