Cousin of OSW (Open Sim Wheel)
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Sep 23, 2017.
  1. Gadget999
    12,053Coins
    So today i started a budget Direct Drive wheel project :)
    all of it has been built from parts i have laying about so it has cost me nothing !
    Parts List
    280W 24V DC motor (from an electric go kart) (may be a 350w motor after all)
    IBT-2 h bridge controller
    Arduino Mega
    360 p/r shaft encoder
    Steering wheel (from electric go kart)
    i have got the wheel attached to the motor and have drilled out the back of the motor to attach the shaft encoder
    hope to get it wired up tomorrow and try it out
    next job is to find some arduino code and program the board
  2. Gadget999
    12,053Coins
  3. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Nice work. Will be following with interest.
  4. Gadget999
    12,053Coins
  5. Gadget999
    12,053Coins
  6. Gadget999
    12,053Coins
    just ordered a TM1638 to allow the wheel to display information
    a vid of it here --
    and here
  7. Gadget999
    12,053Coins
    i have made some progress with the wheel
    it turns out i needed pull up resistors on the encoder channels and the laptop i was using already had some chip programming software that conflicted with the Arduino leonardo drivers.
    it is a 24v motor that i am running at 12v and already it feels pretty powerful
    i wanted to check i have the correct settings for the pwm
    the options are
    pwm
    pwm+Dir
    pwm +/-
    vnh5019
    I am using a IGBT-2
    i have PWM selected - is this correct ?
  8. Gadget999
    12,053Coins
  9. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    PWM+/- with NPN - Transistor
  10. Gadget999
    12,053Coins
    Some progress :)
    The wheel is set to 180 degrees movement
    The stop is trying to prevent rotation at full movement.
    I have tried the wheel with lfs Live For Speed - but there is no feedback
    What software should i be trying ?
  11. Fernando Igor
    Fernando Igor Member
    Programmer
    Fortaleza, Brazil
    913Coins
    DC motor, Arduino
    Live for speed use Constant force, try using the Constant bar other than 0% (maybe 100% :grin).
  12. Gadget999
    12,053Coins
    It works !
    It works pretty good :)
    So far i have tested it with 12v instead of 24v and at around 8 amps - nowhere near its operating limits
    You can feel quite a lot of feedback with understeer reducing force and the rumblestrips for example.
    So far its the best feedback wheel i have ever tried (i own 6 now !)
    Next step some pedals and paddles/switches etc
    Thank you everyone for your help. The biggest problem was a laptop that would not recognise the board !
  13. Gadget999
    12,053Coins
    ok some more progress
    logitech G25 pedals are fitted (with simple brake pedal mod)
    power supply is a 930 w 12volt 77 amps ! power supply from a server £5 from ebay :)
    this wheel is awesome, i have never tested the osw but what i have now is a very powerful direct drive wheel with good feel
    I set the wheel to 180 degrees of movement and turned it to the stop - the strength at the end is very impressive and i was not able to push past this without a large amount of effort and 2 hands ! much more powerful than a real car
    i think i will be turn turning the force down to around 40%
    next job it to tidy up the electronics and wiring and fit it into a nice neat box and fit a 3 phase encoder rather than the 2 phase encoder.
    • Winner Winner x 3
  14. Limongi
    Limongi Member
    Vancouver, Canada
    - 7Coins
    Great work, happy it was a success. Where did you net out total cost of you don't mind ?
    Also with the ample torque do you have plans for a full 350mm wheel?
  15. Gadget999
    12,053Coins
    No plans for a bigger wheel, this is going to be fitted into a formula 3 carbon fibre tub
    The whole thing has mostly been built from bits i had lying about like the motor and steering wheel. The parts i needed to buy were
    Ibt-2 motor driver £14
    Arduino leonardo £9
    Shaft encoder £12
    Server power supply £5
    A new motor should cost around £30
    The pedals are from a g25, you could reuse a set from any driving wheel.
    The brake pedal is quite ingenuous, you fit a o ring to the plastic body and the pedal becomes a sealed unit requiring more effort the more you push !
  16. SeatTime
    For members Information. I have this mod, here is the instructional video from 2012 that showed me how to do it.
  17. Limongi
    Limongi Member
    Vancouver, Canada
    - 7Coins
    Great shopping list Gadget, thank you for putting that all together like that. I'm assuming this would be a correct motor to buy to follow your footsteps: http://s.aliexpress.com/67J3mAF7
  18. Gadget999
    12,053Coins
    yes that is the exact same motor i have - there is a 450w, 500w and 600w version if you wanted to try more power !
  19. Gadget999
    12,053Coins
    the wheel got a workout today at full power(and so did I !) and after a while it got quite hot
    i drilled some holes in the front casing to let the heat out
    will give it another go when i find some more time
  20. sim2go
    sim2go Member
    Operator
    Lithuania
    337Coins
    2DOF, Motion platform
    Great thread. Wish you did more "testing". What about 900 degrees of rotation? Drifting mode and how fast motor spins back?
