Question SimTools 2.2?
Discussion in 'SimTools Pro & Entertainment Version' started by Zed, Aug 12, 2017.
  1. riton
    riton Active Member
    1,006Coins
    Oh! I just saw my mistake!
    sorry! Simtools, Simvibe ...
  2. yobuddy
    51,541Coins
    We only had a small sound test really.
    As it took me forever to get the sound working correctly for WinXP thru Win10.
    It's really close to where everyone can beta test it thou.
    I have finished all of the profiling and GUI work to where it all works and is useable.
    What I have left to do, is to:
    - Play with each effect one last time to make sure it works as i want it to.
    - 3D cassis mode, I think i have made a even better bump detection, but need more testing.
    - Add 3D to the Collisions, so the bumps happens where the collision happens. (may come after the beta has started thou.)
    - play with a few ideas on bump detection.
    - Adjust some timings.
    - Final bug test.
    - Move some tones to internal tones (so if people delete a note it does not break the app, may come after the beta has started thou.)
    It's hard to know exactly when I will feel it is "finished", but I believe the GUI is done (as far as completely usable).
    And everything we need is there.
    It's hard to Not keep adding things i see as' required features', as people will ask me for them anyway. (I would)
    And I would like to release something, that is as close as to the tool I imagined as possible.
    It's just nice to hit the stage where it is mostly fine tuning!!
    Anyway, how about some pics,
    Main GIU: Profile Editor
    Main GIU: Volume Settings
    Sound Card Settings
    Vibe Creation (Sound Effect editor)
    GameVibe: Tuning Center (looks familiar , right?)
    Anyway, there is a quick peek at the progress that is being made.
    And maybe a hint of how it will all works.
    Take care guys!
    • Winner Winner x 8
    • Like Like x 5
    153,920Coins
    +11,156 / 57 / -2
    Exciting times ahead @yobuddy, thanks for the detailed update for everyone.
  4. Zed
    USA
    5,845Coins
    That looks great! I will have to wait until I try it to have any suggestions, but it looks beauty!
  5. Zed
    USA
    5,845Coins
    Hehe. I was getting the names mixed up too so don't feel bad. I was just pulling yer leg. :grin
  6. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    Exciting ! it's the beginning of the end for simvibe ! ;)
    :thumbs
  7. Qlittles
    Qlittles Active Member
    Union City, California, USA
    226Coins
    wow- really excited for this, as i don't have the $$ for simvibe - thank you yobuddy!
    153,920Coins
    +11,156 / 57 / -2
    I think you mean Game Vibe, which is part of the SimTools Pro License.
  9. Qlittles
    226Coins
    ah, i see -- i need to pay to get the Simtools Pro License, which has Game Vibe.
  10. yobuddy
    51,541Coins
    Or upgrade your DIY license to Pro...
  11. riton
    riton Active Member
    1,006Coins
    but for the moment it is not yet available ;)
    ( is it possible to have in his avatar the type of license that we have?
    it would be interesting to see who has what license )
  12. yobuddy
    51,541Coins
    It would be a ton of work as SimTools.us and XSimulator.net are separate entities and not tied together.
    (They don't share info internally)
  13. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    we can ask @RaceRay if he can add some check boxes for the type of license we have in our profile
  14. Zed
    USA
    5,845Coins
    Or people can just put it in their signature?
    I am not sure but think most with a Gold Contributor banner will be running Pro? Maybe an admin can comment. May be others running Pro too. Probably those without a Gold banner and a low post count or that don’t have build threads will have the trial version if they have it at all?
    But why the need to know what everyone else is doing? There is a features table at the downloads that shows what the various versions get you. I really wanted GameDash and GameVibe so it was a no-brainer. I needed Pro.
  15. RaceRay
    Hamburg, Germany
    23,884Coins
    It would be much easier if one just uses the signatures. We can not connect directly both system without a lot of work.
    User with a Gold Contributor badge own a unlimited download plan. This does not mean that they are using SimTools Pro Version in any case. Its highly likely but not dead certain and can not directly deduced from ones gold supporter badge.
    oh mate, i had the hope you would finally start with removing out XP support:D Such workarounds are error prone only and will give just you more headache in the future:p
    Anyway, looking forward to the new releasehug:
  16. yobuddy
    51,541Coins
    It may have been an option, should Direct3D have worked for any OS besides XP lol.
    It actually does work on other OS's, but the overall volume is limited to about 30%.
    After looking up the problem, I found some older published games also have this problem.
    So i started over with XAudio2 (a newer sound api) and it corrected the problem for the other OS's.
    But since I already had both versions, may as well make plugins for both and have GameVibe load the right one when its launched.
    Anyway, that's how that happened lol.
    • Informative Informative x 3
  17. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,945Coins
    Looking forward to this. Is it only suited to driving though? Any relevance to flying prop aircraft maybe? I saw afterburners.
  18. yobuddy
    51,541Coins
    No, it will work for all kinds of games.
    But I do need to make sure the notes play right for the incoming data type.
    You see, how you make sound from the incoming data can change.
    For example, with RPM, you make sound depending on the input value itself.
    But for bumps, you make sound when the value changes quickly.
    And with gear change, you make sound only for X amount of millisecond after the change.
    Allot of it is trial and error, as far as what really works and what does not.
    This is what I have so far:
    Chassis (FL, FR, RL, RR)
    Road Detail (Heave)
    Collision L/R (Sway)
    Collision F/B (Surge)
    Rpm (Rpm)
    Turbo (Turbo)
    Afterburners (Afterburners)
    Gear Shift (Current Gear)
    Turbulence (Speed)
    My idea is turbulence is really for airplanes, where you have a white noise simulating wind going over the body of the plane at high speed.
    You can use the rpm for planes to, although it would be configure to be more of the hum in the background than a 'rip' of a engine rev like a car.
    And Afterburners can be configured also.
    @Spit40
    Maybe you could look at game dash as to what kind of data you get from Flaps and Landing Gear?
    As we will want both of those also.
    My guess is they both go from a 0 (off state) to a 1 (on state)?
    But do they 'flutter' when doing so, or is it just a 0 to a 1?
    It may be worth adding Gunfire also?
    Although I don't know of any game that outputs that data yet?
    In the end its written in a way that we can add the ones that make sense.
    (can be used with multiple games)
    Chat soon,
  19. riton
    riton Active Member
    1,006Coins
    what do you think of driving a Butikiker with an Arduino board and a PWM / audio conversion?
    have there been any tests?
  20. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,945Coins
    Thanks @yobuddy I'm getting the picture now as to how this works. I guess there will be a soundfile library that will grow over time and people might contribute to with tips and techniques. It sounds like it will be fun exploring options.
    I'll try gamedash to see what data is coming through. I'm not sure if the default plugin provides everything available from FS2's SDK or just the things that @value1 hooked into.
