rFactor Profiles - 100mm SCN5 - by Master Yoda
Discussion in 'X-Sim² profiles' started by MasterYoda, Feb 18, 2009.
  1. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Game: rFactor
    Intended Sim Hardware: 2 SCN5 Frex-Style design (On-Road)
    Actuators: 100mm
    25% Limiter: Yes
    Math Plugins Used: 1:1 G-Force, Smooth washout
    Designed for Specific Vehicle: Yes - F1 MMG
    Includes Program Settings: No
    Includes Gauges: No
    Speed / Acceleration Values: 16911 / Accel: 601 (Fixed on Synaptrix)
    http://www.youtube.com/watch?v=2wQ4xQc-ing
    Disclaimer: It's simple. If one of these profiles harms you or your equipment, I am sorry but am not liable in any way. Use this profile / setting combination at your own risk. Do NOT use these profiles if your 25% limiter is not enabled.
    Well this is my first try to make a profile... So, be kind and say it is nice! :mug1:
    I was trying to make a profile that would me make fell the G forces of the F1, without too much of lateral movement.
    With this profile I can feel all track bumps, etc... gear changes, good brake and acceleration, and cornering forces (not steady).
    Some will say this is too tough, but that is exactly what I was looking for as I used to use Pure G force on Frex SCM.
    This is even stronger than that, but, this is a F1 car, not a kids toy guys! ;D
    Hope you guys enjoy. My neck is completely destroyed after this profile testing...
    This is just a Beta and will be improved.
    Thanks to Bvillersjr for all his help and profiles from where I learned how to start! :highfive:
    Cheers,
    Edit 2009-02-18 -> Corrected Speed/Accel values on description.
    Edit 2009-03-17 -> Uploaded a new profile with corrected lateral accel. values.
  2. viper221w
    viper221w New Member
    Technical Architect for Accenture
    333Coins
    I have everything setup as stated, however I had a question.
    Is there anyway to get more lateral motion, the frex software in pure g mode moved alot more from side to side under cornering. I would like the same capability in x-sim?
    In addition there is less vibration than frex when you rev the engine the car doesn't vibrate as much, how can I change this?
    Thanks,
    Paul
  3. mrpio
    mrpio New Member
    0Coins
    First of all, thanks MasterYoda for placing your profile, without it I would have no idea where to start. But, as I mentioned in another thread, I was far from happy with how it worked for me.
    I am still working on my profile, so not ready to post it here, which I will do, but I do have a few words of advice for viper:
    1. Try removing all the washout lines in math (to whatever noobs may be reading this - remember that you have to make any changes to BOTH actuators) - they introduce a strange counter-realistic effect. For example, when I stop accelerating (coast on clutch), the seat goes to front quite a bit, and then only back to center. I have deleted it, and it absolutely clarified the forces for me, and somehow lateral forces became alright now.
    2. Try reducing the vertical movement influence - in MasterYoda's profile (50%!) ride is extremely bumpy, bumps dominate over the whole experience and they obscure other forces, especially with the movement range being so limited. I suggest trying 10-20%.
    3. Remember that, unlike with FREX, you are using a 25% range limiter here, so the forces will never be quite the same unless you want to take the risk of taking out all the stops.
    4. You can also try swapping the 100% and 80% influence rates between longitudinal and lateral forces. Hell, experiment with 100% for both, you shouldn't break anything I hope. It seems that MY chose to focus on forces other than lateral, you may choose otherwise. I havent tried that yet, only occurred to me as I wrote this.
    I am now playing with different acceleration and speed values in the SCN5 setup, will try to develop some math to make movement smoother while still effective, although I suspect that task may be beyond the potential of myself and of the software. I think I know how to develop a Frex-style custom gradation, but I'm hoping that something better is achievable after all.
  4. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Not at all. But making profiles needs some experience which you are gathering right now. In the end it is no rocket science, and you will be able to make brilliant profiles for yourself. Though personal preferrences are differing obviously.
    I am no friend of washout effects for racing simulations as well, btw.
    The goal is to have a big bunch of different community profiles available. So dont hesitate to work out profiles, and talk about pros and cons of different settings.
    We need alot more group knowledge regarding this issue.
    Once you have comprehended the basics, it is really easy to build new profiles. I am able to build a basic profiles within a few minutes, though I cant yet, because without direct actuator feedback it is not possible actually.
    Regards
  5. egoexpress
    422Coins
    In case you are not able to get that effect due to finetune the profile settings, then you simply could mix in ForceFeedback effects additionally.
    The engine and curb rumble FF effects are capturable with Yoda.
  6. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    I've just uploaded a corrected profile.
    There was one of the actuators with a wrong input lat. accel. values.
    I believe the smooth wash out filters are required due to long straights where you don't want your seat to be always full backwards and end up with no range to anything that may happen in the middle. This is more evident on the F1, too much forces, but should not be an issue with a GT car.
    This profile is specific to the F1, the way I like to feel its ride...
    Cheers,
  7. egoexpress
    422Coins
    Where is the file?
  8. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
  9. mrpio
    mrpio New Member
    0Coins
    But the seat if fully backwards only in the rare circumstances of max acceleration, 1st or 2nd gear!
    Personally, I am liking the logarythmic scaler now. Still experimenting.
    Cheers
  10. viper221w
    333Coins
    Something rather strange happened tonight, firstly Profiler seemed to stop passing a signal to the actuators even though everything seemed to be fine. Upon opening Profiler it would reset to the center position, however upon loading rfactor or any other plugin there would be no signal. Anyhow after spending over an hour messing around and not getting things to work I decided to re-install X-Sim2 and then re-load masteryoda's plugin. I then changed the G-Force settings so each axis was set to 100% and removed all the washout filters.
    Anyway now when I run an F1 car in rFactor I get much better movement, I even noticed on one highspeed righthand corner the seat appeared to bottom out at the bottom of the actuator and yet the 25% limiter is applied in the SCN5 plugin. I have to say this feels much better than what I had before, I will upload a video for you guys to see, I am sorry to say my brother who shot the video did not turn on the light so it's still a little dark.
    http://www.youtube.com/watch?v=TcVdxbupTXQ
  11. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Cool! :clap:
    I can see you shaking around pretty good! :lol:
    It seems you had some sort of handshake problem with your converters which was fixed after reinstalling X-Sim. I noticed that sometimes if you settings for timings are extreme they may work intermittently.
    BTW, which Silverstone version were you using? Link?
    Cheers,
