Lesson Preventative Maintenance, THE Necessity
Discussion in 'DIY Motion Simulator Projects' started by Brett Horton, Nov 11, 2017.
  1. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Hey guys,
    Just a public service announcement...
    I was in the process of installing some custom CNC Pot brackets this morning and when I disassembled the old brackets it was very evident that my POT's (Bourns) while would turn, were very tight. I cleaned and lubed them lightly with a synthetic oil and it free'ed them up just fine. I also at this time lubed all pivot points and rod ends for good measure.
    So.... when things are working great for months at a time, please do not forget to spend the time and perform some PM... Your machine and your wallet will thank you later!
    Oh forgot...
    Here is a picture of my POT brackets
    • Agree Agree x 4
  2. Tim McGuire
    Canada
    2,222Coins
    3DOF, DC motor
    I can second this, one of my hall effect pots bound up on me recently, killing one of my drivers and bending the connecting rod. After cleaning it out and re-lubricating the shaft it's all back to normal.
  3. Andy Booth
    Andy Booth Active Member
    Malaysia
    430Coins
    My regular preventative maintenance is to check and re-tighten the grub screws of the flexi links between the pot and the motor.
    While I'm sure these connections shouldnt come loose, I have lost the link between the pot and the motor causing the motors to drive hard over to the extremes of movement.
    But I hadn't thought of lubricatingthe pots. I have some spray lube and contact cleaner somewhere at home. Better pull that out and give each of the pots a little squirt.
    Andy
  4. Brett Horton
    Tampa FL
    118Coins
    Yeah, I was surprised at how tight the little pots where, almost could not turn them by hand.... Cleaning and lube got them going perfect again.
  5. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    They are the sexiest pot brackets i have ever seen. I assume you made them? Be a good product to offer to the public... aka me :)
  6. Brett Horton
    Tampa FL
    118Coins
    lol.... Thanks, Yes I drew them and had a machinist at work cut them for me.
    They would be expensive .... They where hard to hold in the machining jig while cutting.
    I certainly can post the .stp files though, see attached
