Compilation plugin non fonctionnel
Discussion in 'SimTools Plugins' started by Fredymilou, Nov 19, 2017.
  1. Fredymilou
    Fredymilou New Member Gold Contributor
    Electronique , mécanique
    134Coins
    Hello ,
    I tried for 3 days to compile a plugin for SimTools 2.1 with the examples proposed in the guide, at first without modifying it, the only one that passes without problem is the LFS V3.
    But when I install it (with plugin updater) it is not present in the plugin repeater of simtools and not seen by GameManager: ... \ AppData \ Local \ SimTools \ GamePlugins
    In fact I would like to customize the plugin Pcars2 to use other channels EXTRA1 2 3 ..
    I'm using Visual Studio 2017 and I'm running on W10 PRO64.
    Someone would have a functional source, even an old version will go to me, it is to experience the different aspect and future performance of my simulator.
    Thank you in advance.
    152,373Coins
    +11,076 / 56 / -2
    Can you please verify which version of SimTools you are using, as the demo version will not display anything but the pre-installed LFS plugin, which is supplied for testing purposes.
  3. Fredymilou
    134Coins
    Thank you ,
    I have version 2.1 with the DIY license.
    The pCARS2 2.0.3.3 plugin @value1 works well.
    I removed the original LFS to try the one I compiled, but nothing to do.
  4. Fredymilou
    134Coins
    I found, I had named it LiveForSpeed_Plugin
    instead of LiveForSpeed_GamePlugin.
    Thanks again, now I have to make it work with Pcars and everything will be fine.
    152,373Coins
    +11,076 / 56 / -2
    Good to hear you got it sorted.
  6. Fredymilou
    134Coins
    But it's not good LOL. ARFFF
    Plugin simply compile without changes.
    GameManager does not start anymore, except that I removed plugin.
  7. Fredymilou
    134Coins
    I receive this message :
    And the detail:
    I tried with the three examples it's the same.
  8. Fredymilou
    134Coins
    I just saw that @vthinsel certify the incompatibility between V1 and V2.0 on another post.
    I will test with V1.3 and it works.
    Would it be possible to see an example for V2.0?
  9. yobuddy
    51,112Coins
    Hi @Fredymilou
    This means you have old game plugin code.
    Here is a v2 GamePlugin how-too, and new examples.
    https://www.xsimulator.net/communit...ugin-for-simtools-2-0-api-documentation.9107/
    You will need to remove the invalid plugin.
    And you may need to goto:
    C:\Users\admin\AppData\Local\SimTools\GameManager\GameProfiles
    and delete the folders;
    LastUsed
    Profiles
    to get it worken again.
    take care,
  10. Fredymilou
    134Coins
    LOL, I had seen this post to my first visit to the forum, but I stayed on my blocked V1.0.
    It is on that it works better like that.
    Thank you @yobuddy
