Help with Arduino code + SimTools
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pedro Pablo, Nov 21, 2017.
  1. Pedro Pablo
    Pedro Pablo Active Member
    Software Developer
    Valparaiso, Chile
    599Coins
    Hi
    I've got 2 DC motors like this and a circuit board of 4 MM connected like this, also 2 5K pots with bolts to hook it to the motor shaft. For now the motors are not mounted to any base so obviously the pots are not mounted to the motors. After I configure SimTools using this guide and using this Arduino Code by RacingMat i was expeting to manipulate the motors on SimTools to test the output with the games, but I couldn't.
    For example, I turn on the arduino and the Monster Moto and the motors starts to move because on the code they need to put the potentiometer at 512. The problem is when I start the
    output testing on the motors acts the same, even when I move the slide the motors keeps their position as before, it only moves then i handle the potentiometer
    So, i was wondering if there's another code, another tutorial or another way to keep trying the motors. For now I don't have an idea to make an structure for use the motors, I only want to make the motor work
    153,764Coins
    +11,149 / 57 / -2
    It is a bit hard to tell from your description if you have successfully completed all the steps to set up @RacingMat's code.
    If you are looking for alternate code try the SMC3, as it has a handy graphical application to ease setup: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    You did not say which version of SimnTools you are using. The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
    You can ignore b settings, as you wont need them.
  3. Pedro Pablo
    Software Developer
    Valparaiso, Chile
    599Coins
    Thanks for your answer. Yup, im using simTools 2, and I didn't know about that change. I'm going to read about SMC3 and if something happends i'll post here
  4. Pedro Pablo
    Software Developer
    Valparaiso, Chile
    599Coins
    Hi
    Before continuing with SMC3 I wanna configure SimTools with the RacingMat's code. I've got everything connected and working, for example the code does a calibration setting the potentiometer at 512, so when I move them (assuming that are not mounted to the motors as i've said before) the motors starts to turn. Also in the post RacingMat offers some hex values to try at the Serial Monitor of Arduino, and using some values the motors starts to move until I move the potentiometer to a position where they stop (if its pitch i move both pot at the same direction, if its roll I move one clockwise and the other counter-clockwise)
    The problem is that i still don't get them work at SimTools. As i've said im using the version 2 and im following the tutorial posted on the documentation of this site, but even using L<Axis1a>R<Axis2a> and the other variables from the quickstart the motors didn't work
    And in besides, i've tested SMc3 but also it's kinda confused for me. I've flashed the arduino with the code and i started the SMC3Util but i cannot manage to move the motor
    153,764Coins
    +11,149 / 57 / -2
    You will need to post pictures of all of your settings on the SMC3 side and SimTools side.
  6. Pedro Pablo
    Software Developer
    Valparaiso, Chile
    599Coins
    Well, i was messing around with the guide made by RufusDufus about SMCUtil, at least the motor moves but it's kinda hard to measure correctly if the pots are not mounted to the motors.
    For now I can post the settings of Simtools, keep in mind that is configured based on RacingMat's guide, again, I can't do so much without the motors properly working with the potentiometers.
    I'll keep the tests, I have a friend who can make me the brackets to mount the motors with the pots but it will take his time, for now this is only that i can do :/
    153,764Coins
    +11,149 / 57 / -2
    You need to mount your pots before fiddling with SimTools.
    SMC3 Interface Settings for Simtools 2:
    [A<Axis1a>][B<Axis2a>]
    Set for 10bit binary output
