Question Extreme Axis Movement
Discussion in 'Ready, set, go - Start your engines' started by Brett Horton, Nov 23, 2017.
  1. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    I need your collective help.
    I have been fighting this problem for a couple months now and am certain it is a configuration issue...
    ONLY in PCars 2 and Dirt Rally (Not in AC EVER) Using the exact same JRK settings (Obviously) I will be driving up or down a steep hill (Pitch) or steep banks (Roll) and my sim will go to the extreme extents, sometimes even opposite of the intended input actually. Until the input event has decreased below what ever value that stops it (I don't know) Anyone ever seen this? I have included screenshots of both Rally and PCars 2 as well as my axis setup and JRK settings.
    Odd thing is it does not happen every single time in the same turns or hills. I assume I am just taking a slightly different line causing this. But why is my machine jumping to extreme limits. It actually hurts as it is a very abrupt input (Running 25:1 PSaw) Kills the experience as well!
      243.2 KB
      778
      221.7 KB
      782
      224.9 KB
      776
      228.9 KB
      769
      225.3 KB
      739
      149.7 KB
      792
      243.6 KB
      775
      183.8 KB
      818
      132.2 KB
      774
      132.1 KB
      774
      147.2 KB
      785
      178 KB
      813
      130.8 KB
      739
      127.3 KB
      772
      147.6 KB
      782
  2. Brett Horton
    Tampa FL
    118Coins
    In Dirt Rally currently, I cannot get enough (IMO) pitch because I have to turn "UP" the value in the tuning center just to keep the pitch axis from jerking to its extreme. I currently have it set to "8" in pitch, and it does not have much range of motion but also does not jump tp its extreme. As soon as I turn up the pitch to "9" the jerking almost completely goes away, but I do not have very much pitch movement at all then...
  3. Zed
    USA
    5,845Coins
    Hey Brett, one of your motors has an absolute minimum greater than the minimum. Intentional?
  4. Brett Horton
    Tampa FL
    118Coins
    yeah, I have been playing with those settings..... hummm....
    Not saying that isn't it partially, but both motors go to extreme limits as described above...
  5. Brett Horton
    Tampa FL
    118Coins
    Since I had to change one of the JRK's a few months back (actually sorta when it started lol) I guess it would be advantageous to completely go through setup again...
  6. Brett Horton
    Tampa FL
    118Coins
    But would still like advice on why it is doing this if possible
  7. Brett Horton
    Tampa FL
    118Coins
    So Zed, I think you got it... I went through the JRK setup process from scratch, and all the numbers lined up much better now, Mins and Max Mins are correct. Been driving for about a hour and so far zero issues as before.
    Hope it continues!
  8. Brett Horton
    Tampa FL
    118Coins
    Nope... son of a bitch, still doing it... Im getting tired of this
    153,758Coins
    Did you reset the JRKs to their default factory setting and then do the setup from scratch?
  10. Brett Horton
    Tampa FL
    118Coins
    so... reset to default no. How do you do that?
    I just reentered and reran my motor centers and such
    153,758Coins
    The option to reset to default is in the Pololu menu.
  12. Brett Horton
    Tampa FL
    118Coins
    possibly getting motor errors causing this?
  13. Brett Horton
    Tampa FL
    118Coins
    It just happened in PCars2 in the 69 camero, going over a steep hill at the same time I stomp on the gas and when (Surge) was added the rig went to full "back" position for about 3 seconds until I got down the hill
  14. Zed
    USA
    5,845Coins
    Hey Brett, not sure but I’ve had a similar issue in PC2. It’s not quite the same but your comment about the 3 seconds makes me mention it. For me it’s sway. I can’t run with sway in PC2 or else I have places in the tracks where my sim kicks over to the side and stays there for about three seconds then straightens up. It’s dead repeatable for me and doesn’t matter how fast I transition where it happens. I’ve inched through and when I hit the point, hard kick. At Indy it’s even on a straight. It also doesn’t seem to happen on every track. If I take sway out of the forces, it doesn’t happen. I don’t have any explanation but it could be I have something not set right. Also, where I had wind at first, it quit working in PC2. No idea if related. But other than no wind, as long as no sway, no problem whatsoever.
    I haven’t added filtering yet. You running with any filtering?
  15. Zed
    USA
    5,845Coins
    Forgot to mention, AC works perfect for me too. Wind, sway, etc. But I also see the sway effect in No Limits 2 but wind works there as well.
  16. noorbeast
    153,758Coins
    That sounds like it is game generated, perhaps there are a few bugs loose.
  17. Brett Horton
    Tampa FL
    118Coins
    Yeah, I was afraid of it being game related. But for me it does not always happen. On nordsleife, through the first carasel, it happens in roll 1 in 10 times, then not again the entire race....
  18. Brett Horton
    Tampa FL
    118Coins
    Norbeast, Is there a good step by step setup for the entire JRK process by chance?
    Still would not hurt to go through it again I think.
    153,758Coins
  20. Brett Horton
    Tampa FL
    118Coins
