Fanatec V3 to diy handbrake
Discussion in 'DIY peripherals' started by PiaMan, Sep 6, 2017.
  1. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    Has anyone done this? I found voltage between pins 2(ground) and 6(3.3v) which I thought would leave the output on pin one but I'm not getting anything through the fanatec control panel.
    Thoughts or ideas?
  2. donovan
    donovan New Member
    169Coins
    2DOF, 3DOF, Arduino
    The fanatec v3 pedals doesnt have the port for ebrake?..
  3. PiaMan
    607Coins
    Yes it does have a phone jack style port. I just cant find a connection to it that works.
  4. donovan
    donovan New Member
    169Coins
    2DOF, 3DOF, Arduino
    i have a friend with v3 pedals i will see if i can find something to help with...
  5. PiaMan
    607Coins
    Awesome thanks
    I did test with both the bodnar load cell amp and a standard pot from another joystick. I eneded up running a pro micro instead but id love to not have the extra device fir that one axis when i have a port on the pedals right there
    Thanks again for any insight you discover
    Cheers
    153,703Coins
  7. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Thank you for your reminder, because I am also using FANATEC, I really want to know, I will pay attention, very sorry.
