SimTxus Motion Simulator
Discussion in 'DIY Motion Simulator Projects' started by el_txus, Mar 4, 2009.
  1. el_txus
    el_txus Member
    Las Palmas de Gran Canaria - España
    421Coins
    Hi
    After being developing for some time my simulator project, here I show some photograf's of it.
    I have not finished yet the mounting process of all the peaces, but I have them all.
    I hope to finish soon. Thank's to all the guys from x-simulator that have helped me in the consturction of my simulator.
    Best regards
  2. tronicgr
    tronicgr
    Is this going to be moved from pneumatics? :eek:
    And another thing. I think you have raised a lot the seat, and most likely you will be getting false cue movements. For example if you press the brakes you will be pushed on the seat while the exact opposite should happen!
    I would advice you to lower the seat 20-30cm if possible. It will also improve the balancing stability of the platform with the driver on it. BTW how you are going to climb in that thing??? :?
    Regards, Thanos
  3. el_txus
    el_txus Member
    421Coins
    Hi Thanos
    Thanks for your coments!
    Yes is a pneumatic system
    I already tought putting down the seat, but for the moment I can´t do it because the cilinder I have is too long (400mm). I have been thinking of reducing it to 300mm or less because I don't need so much lengh. Your example is not valid, because by pressing the brakes the effect is correct though the movement is too long.
    What it's true is, that I have a problem with the x-axis, because of the position of the seat the GC is to high, and this makes that the x-axis movement does not end when it has to and it keeps on moving till the end of the cylinder. But I'm working on it. This is only the beginning of the work, I still have to install the 3 monitor system to compense the balance of the machine.
    Yes, that thing is my Simulator :mug1:
    http://www.youtube.com/watch?v=ifOCyU1K_fI
    Thanks again and best regards :cheers:
  4. el_txus
    el_txus Member
    421Coins
    Hello
    More photos.I hope you like it
    Regards
  5. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Thanos is right. You have to balance it out! The seat is in a too high position. This becomes obvious, as it moves quickly to the sides, but has much trouble to get back to center position.
    Regards
    Christian
  6. el_txus
    el_txus Member
    421Coins
    Hi Christian
    as I told Thanos, I reducing the vertical axis motion of the simulator, to be able to put it down , and so improve the horizontal movement.
    I will put some photos in short time.
    Best Regards
  7. el_txus
    el_txus Member
    421Coins
    Hello
    I have reduced the hight for about 20 or 25cm, now I have a cylinder with a range of 250mm. I hope with this change it's enough. I also have reduced with cushion of the x-axis with buffering.
    Regards
  8. el_txus
    el_txus Member
    421Coins
    Hi
    Two videos with the advances of my simulator. in the firts video I don´t use G-Efects, and in the second one I use two G-Efects
    http://www.youtube.com/watch?v=XXlH9LGFBtE
    http://www.youtube.com/watch?v=nEmqCKYenQ0
    Best Regards
  9. RaceRay
    Hamburg, Germany
    23,876Coins
    Can you show us a video with a look on your screen to see how syncron the movements are?
  10. R-eng
    R-eng Member
    San Diego, CA, USA
    28Coins
    Watch the feet and arm movements.
  11. RaceRay
    Hamburg, Germany
    23,876Coins
    ok, needs a lot of finetuning ;)
  12. el_txus
    el_txus Member
    421Coins
    HI
    I need more time for the adjust of the simulator. The video only shows that I have finished the sim mounting
    Best Regards
  13. el_txus
    el_txus Member
    421Coins
    Hi
    I have to stop testing with the simulator. I have a serious electrical problems with the main power supply of muy house. By the time the project is stopped
    Best regards
  14. pointer4
    pointer4 Member
    Hungary
    276Coins
    :hi:
    Good work, like this keep moving! :clap:
  15. el_txus
    el_txus Member
    421Coins
    Hi to All
    Even I could not solve my electrical problems, but I'm using a mini compressor that provides at least some air to be able to move the sim. I know I need to refine the movements and effects. I leave with you this if anyone wants to crucify me.
    pointer4 I like your sim, very good work How are you going to the settings of movement?
    http://www.youtube.com/watch?v=-sNKjN654i8
    Best Regards
  16. egoexpress
    421Coins
    Honestly, I am not able to see which effect is triggering which movement.
    Why dont you try to cofigure just the accell/brake axis at first. Try to fine-tune it with 3 speeds.
    When you are satisfied with the result, then save the profile, and work out another profile with lateral movements.
    Though it is obvious that you wont get perfect movements with 3 speed pneumatics, you will be able to get alot better movements than you have currently at least.
    Btw, you should use X-Sim1 for pneumatic valves with matrix control. It is easier to get used with it.
    Post your profile here, please. Perhaps I will be able to tweak it a bit.
    Regards
  17. el_txus
    el_txus Member
    421Coins
    Hi
    My problem is I do not know how to create the correct profile. I do not know what meaning to assign to each value captured by the pluging of the force-Sender
    I am simply use the Efect 21 of the pluging (Local x velocity) and assign the x-axis with 100% intensity, the effect 22 on the Y-axis and also with a 100%. The effect 24 (local accel X) assigned to the x-axis with 100% intensity and the effect 25 on the axis Y.
    I need a little help to learn how to successfully create the effects.
    Best Regards
  18. el_txus
    el_txus Member
    421Coins
    Hi Ego
    In this profile I use the efects 21 and 22.
    I have improved a little in the speeds, but I need a bit more work soon upload a video.
    Best Regards
    Txus Rfactor 2.rnr
  19. el_txus
    el_txus Member
    421Coins
    Hi
    Well, I have been working a bit at the effects and with the velocities. In this profile used the local velocity and local Accel. effects. Which effect should I use to add the colissions? How can I link the name of each effect with the movement that is making the car. (How can I now which name of which effect is the one that corresponds to the movement of the car)
    http://www.youtube.com/watch?v=cM3iUzmXRtw
    Txus Rfactor.rnr
    Best Regards
  20. egoexpress
    421Coins
    You are using the wrong effects.
    You have to use effect 25 for lateral movements (left/right g-forces), and effect 27 for longitudinal effects (accell/brake g-forces)
    Regards
