vthinsel
F1 2017 UDP Plugin - Manual plugin start 1.0
Usefull for consoles, but also PC
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,037Coins
    Arduino, 4DOF
    vthinsel submitted a new resource:
    F1 2017 UDP Plugin - Usefull for consoles, but also PC
  2. Leandro Kemp
    Brasil
    - 10Coins
    Hi.
    There is no max min file in the package
  3. Leandro Kemp
    Brasil
    - 10Coins
    Hi.
    Solved max min.
    What IP and port should I configure in the game?
  4. Leandro Kemp
    Brasil
    - 10Coins
    Work Fine.
    Tanks
  5. vthinsel
    FRANCE
    6,037Coins
    Arduino, 4DOF
    If you would read/search instead of posting the same messages several times in different threads you would have probably found the adequate plugins. This is F1 2017 thread, not Project cars. PC2 supports the PC1 plugin, but provides also a new format and there is also a plugin for the new format.
  6. Bami Salami
    Bami Salami New Member
    161Coins
    Thanks will show my setup a.s.a.p.\
  7. domenik84
    domenik84 New Member
    saldatore
    Italia
    - 25Coins
    Hello Where do I find the Plugins for Formula 1 2020 for consoles
    151,985Coins
    +11,061 / 56 / -2
  9. vthinsel
    FRANCE
    6,037Coins
    Arduino, 4DOF
    If the UDP format hasn't changed and if telemetry is fine, then the F1 2017 plugin should work. Otherwise, as @noorbeast says, a new one lust be developped.
  10. domenik84
    saldatore
    Italia
    - 25Coins
    how do you suggest me to try with ethernet cable connected ps4-pc, ethernet cable connected ps4- rooter- pc or crossover ethernet cable sp4-pc?
    151,985Coins
    +11,061 / 56 / -2
  12. domenik84
    saldatore
    Italia
    - 25Coins
    problem solved everything works with both wifi and ethernet cable
    simtools receives upd data from sp4 game f1 2020
    now buy
    arduino uno
    Pwm driver BTS7960B 43A
    stepper motor
    to make sure everything works
    where can i download an arduino code to do this?
    can I use an arduino nano for the first bench tests?
    thank you very much for the help you are giving me
  13. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    In F1 2020 and 2021, the operation is interrupted at each change of lane or the advance of a stage over the weekend.
    It is necessary to press stop and play for it to work again.
    Does anyone know the reason and if there is any solution to solve this problem?
    Thank you.
  14. Pascal75
    Pascal75 New Member
    germany
    16Coins
    2DOF, Motion platform
    Hi Leandro,
    have you found a solution for the interrupt after changing something.
    I have got the same failure.
    BR
    Pascal.
