value1
pCARS2 Plugin 2.0.5.4
SimTools game plugin for pCARS2
  1. Andy Booth
    Andy Booth Active Member
    Malaysia
    430Coins
    If nobody else reports back, I'll have a look this evening.
    So whats in the update? I can't see any information on the net.
    Andy
  2. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Patch 1.3.0.0 is now live on Steam. Full Patch Notes below.
    Project CARS 2 - PC PATCH 1.3.0.0Online / Multiplayer
    New game mode - The Online Championship game mode is now available, allowing players to compete online in full championships, spanning multiple rounds.
    Fixed an exploit where some players could load custom setups in Community Events when Default Setups are enabled.
    Improved logging and syncing when joining online games already in progress.
    Fix for an online issue where players would be shown an incorrect error message when attempting to join a game session which was full.
    Online Reputation: When being kicked from a race, the system now checks your recent history to help decide if points should be deducted from your ranking score.
    Online Reputation: Fixed a bug where remaining players would not score for a win against disconnected players.
    Resolved a problem where a previously kicked player, joining back into a game after accepting an invite, would be auto-kicked.
    For players joining an active qualifying or practice session, there is now a 3-minute cut-off as the session approaches completion, after which it will no longer be possible to join the session.
    An error message is now displayed when an incorrect password is entered when joining a password-protected lobby.
    Career
    New Invitational Event - McLaren 720S VIP Challenge.
    Fix for career multi-class races, so that the finish position within the class is used for series progression, rather than the overall race position.
    Nissan Skyline Silhouette, Nissan Skyline BNR32, Nissan R89C, and Porsche 961 can now be used in Career mode.
    Fix for an issue where pop-ups for unlocking Invitational events were displayed in the wrong location.
    VR
    Improvements to the VR-specific replay camera system.
    Fix for screen dirt and rain drops not rendering correctly in VR.
    Fix for an issue when VR combined with NVIDIA Surround caused the game to attempt display of ultra-widescreen content in the VR headset.
    Changed the VR Gaze pointer behaviour to also hide when the UI is disabled in Photo Mode and Replays.
    Fix for VR Photo Mode initial FOV settings when switching camera mode.
    Fix for screenshots taken in VR Photo Mode not saving correctly to the <Documents\Project CARS 2\screenshots> folder.
    Controllers
    Logitech - Fix for G29 and G920 lock stops.
    Fanatec - improved anti-jolt and high-frequency anti-vibe on the CSWB series.
    Thrustmaster - Improvements for the 458 Italia.
    Improvements to various controller’s vibration effects.
    GUI and HUD improvements
    Session information such as race duration is now displayed on the pre-race menu.
    Changed the HUD colouring scale for race rain tyres.
    Added a dialog to show replay saving progress.
    Change to the way the Start Type is displayed on the Round dialog so that it matches the Race Settings dialog.
    Fix for an issue where a menu would become disabled when moving 'down' from the bottom of the menu.
    Updates to various buttons to better indicate when a button is selected/highlighted.
    Fix for buttons on online post-race results screen so that they only show when they can be pressed.
    Fixed cases where the RPM Gauge on the HUD was not matching the actual RPM of the car.
    Fixed loading bar to become invisible when local loading is complete.
    Added new Help Text for Menu Spring Strength in FFB settings.
    Added fuel estimation to Tuning Setup screen and ICM.
    Added auto-scroll to a number of info feeds to prevent overlapping text.
    Added the name of the car setup currently in use to the 'Setup' button on the Pre-Race screen.
    Fix for fuel being displayed incorrectly as mass, not volume.
    Improvements to the lap timing and visual-split timing HUD widgets.
    Fix for incorrect number of records being counted on Community Event screen.
    Fixed an issue in Time Trial where Loaded Ghosts and Options on the Pre-Race menu were highlighted at the same time if the player added multiple ghosts in Time Trial.
    Fixed an issue where an incorrect weather forecast icon is displayed for the client in the lobby details screen.
    Handling/Damage
    Various tyre behaviour tweaks and improvements to the different tyre compounds.
    Altered the pre-heating temperatures of various tyres to prevent them from being outside optimum temp range at race starts.
    New rain tyre compound improvements for Group C, GTP, all Formula cars, GT1, and LMP900.
    Driveline improvements with increased synchro effect for Hewland-type gearbox
    Lowered the time to jam gears together after a missed shift for all gearboxes.
    Changes to Vintage Lotus treaded tyres to improve wet speed balance.
    Altered radiator damage to make it more progressive, and not accumulate damage from minor impacts.
    Fix for issues with radiator settings on the Toyota GT86 GT4, and Rocket Bunny versions, which under some conditions were causing engine overheating.
    Changes to downshift protection based on vehicle speed.
    Lowered minimum shift time for cars with H-pattern racing gearboxes.
    Improved physics setup and damage for Mercedes-Benz 300 SEL 6.8 AMG.
    Fixed missing radiator damage for Ford Escorts, and Ford Mustangs.
    Improvements to Formula Renault 3.5 default stable setup.
    Performance balancing changes to the LMP1, GT3 and GT4 Classes.
    Refinements to Vintage Low Grip tyre.
    Balanced performance for BMW M3 GT4, and Ford Mustang Boss 302 R1.
    Improved Modern Touring Car tyre compound.
    Road car tyres: Tuned the aquaplaning and more sensible behaviour in very deep water.
    Increased threshold for detaching front wings of Formula cars.
    Adjusted various default setups:
    – Aston DB11: Loose
    – Aston Vulcan: Loose, and Stable
    – BMW 320 TC: Stable
    – BMW M3 E30: Loose, and Stable
    – Chevy Camaro ZL1: Loose, and OEM
    – Ferrari 330 P4: Loose, and Stable
    – Ford Fusion Stockcar: Loose.
    BMW 2002 StanceWorks: Fixed tyre texture, better strut geometry for kingpin angle and scrub radius, improved drag centre of forces in the aero model.
    AI
    Improved AI in low- and high-speed cornering.
    Improved balance between player and AI in wet conditions.
    Improvements to general AI behaviour and racecraft across all tracks.
    Tweaks to how AI are affected by snow and ice.
    Improvements to the AI driving on slick tyres in wet weather.
    AI Practice and Qualifying grip levels rebalanced to better match expected behaviour.
    Better balanced AI speed on corner exit.
    Generally improved the AI racing balance and ability across many tracks.
    Audio
    Update to various AI car sounds.
    Added new sounds for lower pitch skidding.
    Improved AI audio levels in replays.
    Improvements to Lamborghini Huracán engine audio.
    Reduced the skid sounds for the McLaren 720S.
    Modified falloff curves for surface and skid sounds.
    Updated sound mix for replays, with improved reverb settings for tunnels and bridges.
    New tyre skid sound effects for treaded tyres.
    Fix for an issue with audio not panning to all speakers in 7.1 under certain conditions.
    Tracks
    California Highway Stage 3 - Added an alternate start line to clean up occasional start line issues.
    DirtFish (all) - Fixed an issue with render flickering on main building.
    DirtFish Mill Run - Fix for an exploit to prevent unrealistic lap times (This includes a leaderboard reset for Time Trial and Community Events on DirtFish Mill Run to remove bogus lap times).
    Fuji - Fixed an issue with some render flickering on the front of the pit buildings.
    Indianapolis Motor Speedway Oval - Updated dynamic marks, updated AI alternate start line for better cleaner starts.
    Circuit de 24 Heures du Mans - Fix for render flickering issue on the fence left of start straight, and in the curve entering the long straight.
    Lohéac - Fix for an issue on one kerb where the physics would didn’t behave correctly.
    Oulton Park - Fixed floating white lines near entry to pit lane.
    Red Bull Ring—National: Changed some dynamic barriers and fixed LODs.
    Red Bull Ring GP and National layouts - Fixes for various Replay and Pre-Race camera issues.
    Sakitto - Fixed various render popup issues.
    Fixed issues with the race start at various tracks.
    Adjusted the pit lane placement of Pit Limiter Entry and Exit boards at several tracks.
    Improvements to track cut settings at various tracks.
    Vehicles
    Audi A1 Quattro - Rebalanced the AI in rain vs. dry.
    BAC Mono - New wet tyre compound.
    BMW 320 TC - Fixes for gaps in the rear of cockpit, and fixed cockpit display clipping.
    Caterham Seven 620 R - Improved wet tyre.
    Chevrolet Camaro 1969 - New suspension geometry to better match the Hotchkiss design at the rear and SLA up front.
    Chevrolet Corvette C7 Z06 - OEM setup differential opened up.
    Dallara DW12 Road - New player rain compound, and new AI wet grip adjustments.
    Formula X & Dallara IR-12 - Adjusted engine lifetime model.
    Ferrari 488 GT3 - Reduced extra slip allowance at low speeds for better stability.
    Ferrari F40 LM - Fixed various cockpit detail issues that were visible in VR.
    Ford Escort RS1600 - Adjusted dry and wet speeds for AI to match latest physics changes.
    Ford Falcon V8 Supercar - New rain compound.
    Ford Falcon V8 Superca -  Added a new tyre carcass and made some minor improvements to car handling.
    Formula Renault 3.5 - Increased rolling drag and friction torque to AI to balance their speed on straights.
    Ginetta G40 - Improved AI tyre stiffness, grip and rolling resistance, to better match player, added new Junior tyre.
    KTM X-Bow GT4 - Changed spring and damper data, and added optional final drive ratio.
    Ligier JS P - Fixed exhaust positions.
    Ligier LMP3 - Fixed rear 3rd bump stop having no range adjustment.
    Lotus Type 51 - Increased players wet grip to better match the AI.
    Mazda MX-5 Radbul - Engine cooling and durability adjustment to prevent engine from blowing after one lap. New drift setup added.
    McLaren P1 GTR - Updated the differentials for Stable, and Loose default setups, for more stability and ease of driving.
    Mercedes-Benz AMG GT3 - Improved default setup to improve stability.
    Nissan Fairlady Z GTS - Various fixes enabling radiator damage, texture fixes, better drag balance, and bigger set of gear ratios.
    Nissan Fairlady Z GTS-II - Raised shift light RPM-trigger to 8,000 RPM.
    Nissan Skyline Super Silhouette - Boost adjustment for default setup to make the car more competitive with other Group 5 cars.
    Porsche 936/77 - Added a wider set of gear ratios.
    RWD P20 LMP2 - Changed shift lights to better match engine peak-power.
    Toyota GT86 - Altered aero positioning, and fixed an aero-lose problem without changing the setup.
    GT4 cars - Change to the tyre carcass model.
    LMP1 Cars - Fixed an issue where the AI weren't using the hybrid system, causing an imbalance with the player.
    LMP2 cars - Reduced aero drag by 35lbf @ 150mph.
    Various road cars - Changed OEM tyres to the correct ones.
    Kart - Disabled differential setup adjustments, new tyre carcass construction.
    Improved dirt texture on various cars.
    Fixed mud and snow textures on various cars.
    Other Improvements
    Fixed an issue in Time Trial where the player could load a ghost’s setup for a different car from the player’s car if the selected ghost was in the same class as the player’s car.
    Improved the rendering of the edges of LiveTrack puddles for off-road/off-track areas.
    Fixed an issue with mud and dust particles being visible inside cockpits.
    Improvements to the wet track darkening render effect.
    Much-improved motion blur and bokeh effects.
    Fix for an issue where, in certain cases, LiveTrack conditions could be carried over from one game type to another.
    Improved the synchronisation of clouds and rainfall, and the effects on cars.
    Fix for a red/yellow graphical glitch sometimes appearing on track surface.
    Fix for an occasional crash when switching shadow detail level.
    Fixed an intermittent crash when entering text for a new pit strategy.
    Fixed an issue where occasionally some AI cars would not move on the first viewing of a replay.
    Fix for an issue that would reset the player’s tuning setup to default when Pausing and choosing to return to pits.
    ...and many other small tweaks, improvements and performance enhancements.
    *Hot fix for crash when starting the game in certain scenarios in non-English installations.
    • Informative Informative x 4
  3. Andy Booth
    Malaysia
    430Coins
    Just found it but thanks for posting
    Andy
  4. Zed
    USA
    5,845Coins
    Fingers crossed this means I get wind back in PCars2!
  5. Andy Booth
    Malaysia
    430Coins
    Ran Project Cars 2 last night after installing the patch. Only running a few hot laps with the Lotus 49 on Hockenheim and a couple of GT3 cars on Silverstone but was pretty happy with the results of the update however I wouldn't say I saw a massive difference.
    Haha....looking again at the implemented changes and its clear that I'm not going to see any improvement. Bit of a wasted opportunity. Stupid me.
    One thing I did notice, and maybe its placebo, but I did seem to be able to change gear quicker and a lot less miss gears when running the Lotus 49 using the Thrustmaster TH8a H pattern shifter. You can read quite a few posts regarding really poor shifting for cars with manual gearboxes and I really had to slow down my gear changes in comparison to the same car in, lets say Assetto Corsa. But last night I seemed to be able to shift a lot sweeter. Still got some miss shifts but they were less frequent and the gear was found quicker than previously.
    Will run some AI races and see if what they all say is true. Generally the patch seems to be a +ve change.
    Love to hear from others on their thoughts post update.
    Andy
  6. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    I have about 5 hours into the new patch and it has fixed many many issues. I race online some but also a lot of AI races and this alone has been improved tremendously.
  7. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    I found that the gear shifting problem was basically only a problem with the older model cars and is better after this last patch but not quite up to where I would like it. Maybe they're just trying to replicate what it was like to drive these cars without a synchronized gear box. Only guessing!
  8. value1
    15,076Coins
    • Winner Winner x 3
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
  10. STEELJOCKEY
    STEELJOCKEY New Member
    AUSTRALIA
    441Coins
    Quick question.
    I remember quite a while back I was discussing with someone about PCars 1, and possible making a plug-in that would allow a PC to read the output telemetry from the game on console and try to use that on the PC the provide motion.
    Unfortunately I stopped following the conversation and whether this eventuated.
    Now I am into PCars 2, and play on both PC and Xbox, and was wondering if the previous “console” plugin was made, was one made for the latest game, or could it be adapted for it?
  11. yobuddy
    51,197Coins
  12. STEELJOCKEY
    AUSTRALIA
    441Coins
  13. paulopsx2
    brasil
    647Coins
  14. yobuddy
    51,197Coins
    UDP is used for all of the plugins at some point.
    So no, its not just for consoles.
    But i think some plugins marked as UDP are for consoles.
    (although i see some got re-named manual and console now, which is a better naming system i think.)
    Take care,
  15. paulopsx2
    brasil
    647Coins
    maybe you have expressed me poorly above ... I did not say it was only for consoles, but that UDP was for consoles ... in the sense of "too." I even used UDP for PC1 at the time, to play on PC. thanks
  16. value1
    15,076Coins
  17. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
  18. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    No data in GameVibe Tuning Center. Rpm, Gear Shift, Collision L/R, Collision F/B, Road Detail all zero.
    After switching Off and On in GameManager, GameVibe will stop with error "Suspension_Rr_VibrationID.cfg net found?"
    Using plugin pCARS2_GamePlugin.2.0.5.1
  19. paulopsx2
    brasil
    647Coins
    Ill try now and return here. Wait a minute
  20. DoubleM
    Amsterdam
    - 23Coins
    Using GameVibe-B37
