  1. noorbeast
    152,553Coins
    +11,087 / 56 / -2
    When it is ready.
  2. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    Now THAT is the best news I've heard all day
  3. Mpmo
    Mpmo Member
    United Arab Emirates
    1,288Coins
    But what is it even...
  4. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    Can anyone share some presets for games like Project Cars 2, Assetto Corsa, Dirt, Elite: Dangerous, etc? It might not be perfect but at least it would give a good starting point for fine tuning, right?
  5. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    That was very helpful Andy, got me to a decent starting point in Project Cars 2 at least. One problem I'm noticing is that traction loss (and recovery) is extremely violent and jerky. Whenever I leave or return to the track I get a very sudden and significant yaw movement.
  6. Mpmo
    Mpmo Member
    1,288Coins
    agreed. I'd also like some presets for dofreality 3dof too
  7. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    Use yaw/sec and look into washout or smoothing. Washout gain determines how quickly a force takes effect and washout return is a speed of returning to neutral.
  8. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    would you be so kind to explain where i should adjust those values please?
  9. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    Do you mean how to adjust washout? If so, click the small square to the right of the tuning line. The one to the right of 100% in this pic. in the Flt column If you don't have the Flt column then there is another plugin mode. I think one's called Basic and I forget the other on. It might be interface settings - sorry I don't have access to my main PC now.
    In Aerofly Fs2 and probably as a convention in SimTools plugins
    Extra1 = roll/sec
    Extra2= pitch/sec
    Extra3=yaw/sec
  10. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    Thank you for your explanation! However i don't have such Flt option.. Just Dir, Force and % amount
  11. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    That's because you're using Basic mode and need to be in Standard
  12. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    oh i see, thanks! so i just swap to standard and apply all my settings from basic and technically i will get the same but with the ability to fine tune with Flt?
  13. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    That's how I understand it
  14. DOFreality
    DOFreality Member
    Montreal
    344Coins
    Pls use UDP plugin for PC1 and PC2 as it is more stable
  15. DOFreality
    DOFreality Member
    Montreal
    344Coins
  16. GTA
    GTA New Member
    Los Angeles
    - 0Coins
    I am not sure what you mean by tap it in the lever. I have this same issue of slack in the traction loss with mine. Seems like a product defect. Can you post a picture of the fixed motor where you did this.
  17. Jukkakamala
    Jukkakamala New Member
    Finland
    168Coins
    It is fully assembled and quite a work to disassemble and take pictures.
    However, with my excellent paint-skills i made you this.
    Views are top and side, the original retaining screw not drawn.
    https://pekkakaukalo.kuvat.fi/kuvat/dof/3dof_lever.jpg
    Hope this helps.
    I used 5.5mm hole, then tapped it to M6 and used a M6 bolt. It has to be short to clear the motors own mounting bolts.
  18. GTA
    GTA New Member
    Los Angeles
    - 0Coins
    Thanks that was useful. I am curious as to whether using an epoxy would be sufficient to solve this issue. Did the slack develop in the other motors or just the traction loss?
  19. Jukkakamala
    Finland
    168Coins
    Sorry, noticed afterwards you are not in the metric system, anyway, M6 bolt (and thread) is 6mm total diameter and thread pitch is 1mm. You have something very close so use those. The whole bolt type is "M6 x 1.0", your size might be something like 1/4-20 or 1/4-28, use drill and tap according to those and of course the bolt.
    In my eyes it is not necessary to use any larger bolt because there is not enough material on lever base.
  20. Jukkakamala
    Finland
    168Coins
    What?! I was not supposed to post that. It was a draft but anyway...
    No, epoxy is not enough if the slack is between the axle and lever. Been there, done that.
    Not with epoxy but with Loctite 660, industrial stuff supposed to cure such slacks.
    Nope, it lasted about 5 minutes and then gave away.
    Then i got angry and made it good the hard way.
    A bit of slack in the other motors but while i was on it, i disassembled them too and made the same mod in them too.
    There is a bit of slack in both of them anyway but unless your chair is 100% balanced it does not matter. And that slack is from the motor internals, a little more work to take care of. Meaning totally disassembling the motor, pulling the axle and cog out, cleaning and with hot flames, braze them together for good. Which i did to the traction loss because its slack is the most annoying.
    But if you correct all the motor internal and external slack, there will always be a little bit which multiplies at the end of the levers (the chair itself). The worm gear-contact to cog has always a bit.
