Question Xplane 11 and Flyinside errors
Discussion in 'SimTools DIY Version' started by Lol4, Dec 7, 2017.
  1. Lol4
    Lol4 Member
    Australia
    - 115Coins
    I am using the Xplane plugin and it works fine when running Xplane. When I start Xplane through Flyinside I get errors (see attached) and crashes the game engine. I have checked the data output options in XPlane settings and they are the same as when not running via Flyinside (i.e only the recommended check boxes selected and no extra ones added) as I read this causes issue.
    For example if I try to turn on the virtual axis for testing I get errors (see attached).
    Code:
    System.OverflowException: Arithmetic operation resulted in an overflow.
       at SimTools_GameEngine.frm_GameEngine.tmr_VirtualAxes_Tick(Object sender, EventArgs e)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.7.2600.0 built by: NET471REL1LAST
    SimTools_GameEngine
        Assembly Version: 0.2.1.0
        Win32 Version: 0.2.1.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    EsuyIIlcSafeLCQmwjVfqQyNzsgT
        Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 14.7.2556.0 built by: NET471REL1
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
        Win32 Version: 4.7.2556.0 built by: NET471REL1
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Management
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Microsoft.GeneratedCode
        Assembly Version: 1.0.0.0
    Interface_PluginAPI
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Interface_PluginAPI.DLL
    AxisAssignments_PluginAPI
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/AxisAssignments_PluginAPI.DLL
    Default_InterfacePlugin
        CodeBase: file:///C:/Users/Dektop/AppData/Local/SimTools/GameEngine/InterfacePlugins/Default_InterfacePlugin.dll
    JRK_InterfacePlugin
        CodeBase: file:///C:/Users/Dektop/AppData/Local/SimTools/GameEngine/InterfacePlugins/JRK_InterfacePlugin.dll
    Jrk
        Assembly Version: 1.1.0.1
        Win32 Version: 1.1.0.1
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Jrk.DLL
    UsbWrapper
        Assembly Version: 1.5.1.0
        Win32 Version: 1.5.1
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/UsbWrapper.DLL
    Default_AxisAssignmentsPlugin
        CodeBase: file:///C:/Users/Dektop/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Default_AxisAssignmentsPlugin.dll
    Generic2DStandard_AxisAssignmentsPlugin
        CodeBase: file:///C:/Users/Dektop/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DStandard_AxisAssignmentsPlugin.dll
    Game_PluginAPI
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    AssettoCorsa_GamePlugin
        Assembly Version: 2.0.5.0
        Win32 Version: 2.0.5.0
        CodeBase: file:///C:/Users/TomDektop/AppData/Local/SimTools/GamePlugins/AssettoCorsa_GamePlugin.dll
    LiveForSpeed_GamePlugin
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.0.0
        CodeBase: file:///C:/Users/Dektop/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    pCARS2_GamePlugin
        Assembly Version: 2.0.3.3
        Win32 Version: 2.0.3.3
        CodeBase: file:///C:/Users/Dektop/AppData/Local/SimTools/GamePlugins/pCARS2_GamePlugin.dll
    XPlane_GamePlugin
        Assembly Version: 2.0.0.1
        Win32 Version: 2.0.0.1
        CodeBase: file:///C:/Users/Dektop/AppData/Local/SimTools/GamePlugins/XPlane_GamePlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    The issues are only when using through Flyinside.
    Is this a known issue and if so how do people who use the plugin with Flyinside get around it. Also the extra2 and Heave values when using in Flyinside are -999. Again fine when not using Flyinside
    On the times I can get it to work after a few minutes this is the error I get when it crashes. Untitled4.png
    Thanks.
  2. yobuddy
    51,563Coins
    Being that you got a "Arithmetic operation resulted in an overflow." error.
    It sounds like Flyinside alters the output data somehow.
    But let's wait to see what other are doing, as I'm not currently using this title.
  3. Lol4
    Lol4 Member
    Australia
    - 115Coins
    Updated X plane 11 last night and the data output settings in Xplane UDP speed was on 20 so changed back to 99.9 and it is now working without errors.
