DOF Reality platforms presets, profiles and tips
Discussion in 'Commercial Simulators and Peripherie' started by Mpmo, Dec 9, 2017.
  1. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    or any presets that work with the 3dof p3 version of dofreality's simulator would be fine
  2. Radioproffi
    Lviv
    1,677Coins
    in archive you can find some basic presets for DOFReality, pls import files in GameEngine.
    Also in attachment you can find some Tuning Center screen, pls make same parameters in your Tuning Center.
    PCars 1/2 UDP plugins.
    1) in PCARs game settings set UDP -> 1 and exit the game
    2) for manual run open SimTools Game manager and select Project Cars UDP plugin and patch the game
    3) press plugin start (play triangle button to the right)
    4) start the game and enjoy
    5) as you did manual plugin start before using motions in another game you will need to stop this plugin by pressing square button to the right of plugin in Game manager)
    6) if you have more then one of our platform with SimTools in the same local network you need to disable outgoing UDP traffic in windows firewall in order to prevent game movement information collisions.
  3. Mpmo
    Mpmo Member
    1,289Coins
    ahh thanks, btw, where are the axis 1, 2, and 3? these look like the old version of simtools
  4. Radioproffi
    Lviv
    1,677Coins
    There is screen of Tuning Center (not Axis Assignments).
    https://www.xsimulator.net/tuning-centre/
  5. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    Thank you for sharing these! Can I ask why you use basic instead of standard? Doesn't standard offer the option to adjust filtering?
  6. Radioproffi
    Lviv
    1,677Coins
    There is Basic profiles, but you can make Standard with same parameters and add some filters.
  7. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    The acceleration and braking effects seem to be backwards me in Project Cars 2 with settings. I adjusted them so that they work correctly in the output tester but whenever I go into the game they are still backwards. The whole SimTools axis assignments and presets is confusing to me...they never seem to save correctly and I always lose everything when I load a different set of presets so I feel like this is user error on my part. How do I make sure the correct presets are loaded before starting a game?
  8. Radioproffi
    Lviv
    1,677Coins
    did you apply preset for each game?
  9. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    There's a bunch of other presets showing up but I haven't messed with any other games yet.
  10. Mpmo
    Mpmo Member
    1,289Coins
    hey radioproffi, do you have any flight sim presets? like for DCS, elite, or aerofly 2? could you PLEASE share it? the presets for project cars 2 that you posted worked perfectly
  11. DOFreality
    DOFreality Member
    Montreal
    344Coins
    Below is a picture how to get the NoLimits 2 Roller Coaster on Steam to work....
    In your steam client library right-click on the NoLimits 2 Roller Coaster Simulation, select Properties and click on Start Options and add --telemetry
  12. Mpmo
    Mpmo Member
    1,289Coins
    hey man, do you have any presets for ANY flying game..? If you have, could you please post it?
  13. DOFreality
    DOFreality Member
    Montreal
    344Coins
    To get SimTools talking with X-Plane, start XP and Click on Settings > Data Output
    Now that you have the screen with all the checkboxes, check the following items in the last column "Network via UDP"
    3 Speeds
    4 Mach, VVI, g-load
    16 Angular velocities
    17 Pitch, roll, & headings
    37 Engine RPM
    38 Propeller RPM
    Check the box, 'Send network data output' and enter IP Address 127.0.0.1 and Port 4123.
    Set the UDP rate to maximum (99.9 packets/sec)
    153,716Coins
    These are already covered in the FAQs and it is useful to encourage people to check there first when looking for information:
    https://www.xsimulator.net/community/faq/x-plane-11-setup.288/
    https://www.xsimulator.net/community/faq/no-limits-2-v2-2-and-higher-how-to-activate-telemetry.198/
  15. Radioproffi
    Lviv
    1,677Coins
    In attachment settings for iRacing.
  16. noorbeast
    153,716Coins
  17. Mpmo
    Mpmo Member
    1,289Coins
  18. noorbeast
    153,716Coins
  19. Mpmo
    Mpmo Member
    1,289Coins
    btw, i've noticed that heave in almost EVERY game is set at 5%. Why is that..? isn't heave important when the car jumps from a cliff or something (to stimulate up and down movement)..?
  20. Petrus_SM
    Petrus_SM New Member
    Hotel Night Manager
    Melbourne, Australia
    276Coins
    Hi, I also have P3. Do you have presets for No Limit 2 and Elite Dangerous with tuning parameters?
