SilentChill
EliteDangerous Horizons Plugin (OLD Archive Thread) Version 3.3.0.2
EliteDangerous Horizons Plugin (VR Version)
Thread Status:
Not open for further replies.
  1. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    Anybody out there ?
    Is there anybody who can help ? To get an updated elite-plugin?
    -Kermit
  2. SilentChill
    20,601Coins
    • Winner Winner x 7
  3. cedric33
    cedric33 New Member
    - 118Coins
    wow !! this is wonderfull ! thanks so much !
  4. kermitkong
    1,240Coins
  5. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,977Coins
    Thank you so much for doing this (again) SilentChill! We really appreciate your time and effort. I'm going to harass Frontier CS about this again, could you maybe PM me some kind of direct contact info in case I get a hold of the Dev who was sympathetic to our cause again? I won't use it for myself, just to give to the dev if he is willing to listen to what it is you need done on their end.
  6. George Dobransky
    Hungary
    - 43Coins
    Thank You again and again, Craig! We have come back to life now... Now I can see what differences are
    between joystick plugin and this one.... Thanx again! going back to play!!!!
    Cheers,
    George
  7. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
  8. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Great! Thank you SilentChill. You are the best. :thumbshug::thumbs
    I just tryed ist out. Its working. However, I only get data from Roll, Pitch and Yaw with the Ship. There ist no speed/boost-motion / no Heave, Sway and Surge. Is that correct or am I doing something wrong? :roll
  9. kermitkong
    1,240Coins
    I have all motions with it. Plugin seems to be ok !
  10. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    OK. Thanks for the feedback. Do not know what I could do wrong, but then I have to check the problem with my config.
  11. kermitkong
    1,240Coins
    Hi, please check whether you have the right values in the tuning center ....
  12. reko19
    reko19 Active Member
    electrical engineer
    usa
    38Coins
    Default values in the tuning center work very well for me.
    For some reason getting this error message, any suggestions?
  13. SilentChill
    20,601Coins
    I have no idea to be honest, Urghhh maybe @value1 can help ?
  14. reko19
    electrical engineer
    usa
    38Coins
  15. SilentChill
    20,601Coins
  16. reko19
    electrical engineer
    usa
    38Coins
    Yes, the file is inside the simtools folder . My simtools are installed under "Program Files (x86)", not under "Program Files" but i don't think t should make a difference.
  17. yobuddy
    51,521Coins
    From the error thrown, my guess is somewhere there is a variable of type wow64ext.
    Where "dim example as BaseAddress" needs to be "dim example as New BaseAddress".
    But I'm just throwing out ideas to check here.
  18. GeneralDiDi
    GeneralDiDi Member
    Deutschland
    347Coins
    Everything works fine now. Not sure what was wrong yesterday, but now everything works as it should. Thank you very much guys. Elite and VR is now wonderful with the plugin :thumbs
  19. Ultimate
    Ultimate Member
    - 653Coins
    Thank you for the plugin, it's great fun to find elite with the simulator, thank you for the work.
  20. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Is it necessary to have the Horizons DLC in order for the plugin to work?
    I say it because it's on Steam with a 75% discount.
Thread Status:
