2DOF project started
Discussion in 'DIY Motion Simulator Projects' started by Elias, Dec 7, 2017.
  1. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Hi everyone,
    i have started my 2DOF project based on the one found at this link
    http://www.xsimulator.net/2dof-motion-simulator-truck-wiper-motor-playseat/
    I would thank the author for the amazing job he made it too easy for a rookie in electronics like me.
    I am using:
    1. Arduino Improved MEGA2560 R3 Development Board Module for Arduino - Blue (Cheap Chinese version)
    http://www.dx.com/p/368279
    2. Moto Monster shield
    http://www.dx.com/p/161274
    3. HP DPS600PB
    4. Some Jumper wires.
    5. 2x 10K potentiometers
    6. Still waiting for my DC wiper motors.
    To start and in order to understand how wiring should be done without burning anything i have started working with 7.2v batteries and 2 tiny DC motors.
    After several trials VOILA the motors are moving and controlled manually with the potentiometers.
    Now i will be waiting for the motors to arrive to move to another step.
  2. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
  3. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Thanks Marc
  4. Max Stanford
    Max Stanford New Member
    Student
    Malaysia
    101Coins
    hey there, ive done my 2dof seat! can you update your frame equipment and design?
  5. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Dear Max,
    i haven't reached that phase yet, i m still waiting for my motors that i expect to receive today to start my design.
    i ll let you know when i develop something
  6. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Guys,
    i have tried the moto monster shield and everything works fine knowing that i am still simulating using tiny motors.
    i bought 2 single H-bridges IMS-2A that are supposed to handle 30A each with the purpose of using more powerful motors.
    http://www.ekt2.com/products/productdetails/412_ARDUINO_DC_MOTOR_DRIVER_30A
    i have noticed that i had to disconnect the R1 because The V + pin is by default a direct connection with the B + pin (refer to attachment).
    wires connection as follow:
    Arduino H bridge 1
    pin 2 IN1 (supposedly ENA) motor1
    pin 9 IN2 (supposedly PWM) motor1
    pin 3 EN (supposedly ENB) motor1
    Grnd Grnd
    5v V+
    H bridge 2
    pin 4 IN1 (supposedly ENA) motor2
    pin 10 IN2 (supposedly PWM) motor2
    pin 5 EN (supposedly ENB) motor2
    Grnd Grnd
    5v V+
    A1 Pot 1
    A2 Pot2
    I used SMC3 v1.0 with mode 2
    Nothing moved, on the other hand i have noticed that even without external power supply connected i am getting 5.08V coming from the Arduino on the B+ and Grnd of the H bridge.
    I would appreciate if anyone can help.
  7. Max Stanford
    Student
    Malaysia
    101Coins
    Goodluck on building your 2dof bro.
  8. MarcNSF
    MarcNSF Marc
    Lebanon
    - 97Coins
  9. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Dear Max,
    i know i m late but this is what i have reached
  10. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Help
    I have reached the phase where i m sending orders via arduino serial monitor
    Everything works great.
    I have downloaded SimTools and followed the directions but nothing is moving i m stuck can anyone help
    153,764Coins
    +11,149 / 57 / -2
    What code are you using with the Arduino, SMC3 or something else?
  12. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    I am using this one
    Arduino code for dynamic playseat 2DOF
    Created 24 May 2011 by Jim Lindblom SparkFun Electronics https://www.sparkfun.com/products/10182 "Example Code"
    Created 24 Apr 2012 by Jean David SEDRUE Version betatest26 - 24042012 http://www.gamoover.net/Forums/index.php?topic=25907
    Updated 20 May 2013 by RacingMat in english http://www.xsimulator.net/2dof-wiper-motor-playseat/ in french : http://www.gamoover.net/Forums/index.php?topic=27617
    Updated 30 April 2014 by RacingMat (bug for value below 16 corrected)
    #define BRAKEVCC 0
    #define RV 2 //beware it's depending on your hardware wiring
    #define FW 1 //beware it's depending on your hardware wiring
    #define STOP 0
    #define BRAKEGND 3
    #define pwmMax 255 // or less, if you want to lower the maximum motor's speed
    // defining the range of potentiometer's rotation
    const int potMini=208;
    const int potMaxi=815;
    #define motLeft 0
    #define motRight 1
    #define potL A0
    #define potR A1
    // DECLARATIONS
    /* VNH2SP30 pin definitions*/
    int inApin[2] = {
    7, 4}; // INA: Clockwise input
    int inBpin[2] = {
    8, 9}; // INB: Counter-clockwise input
    int pwmpin[2] = {
    5, 6}; // PWM input
    int cspin[2] = {
    2, 3}; // CS: Current sense ANALOG input
    int enpin[2] = {
    0, 1}; // EN: Status of switches output (Analog pin)
    int statpin = 13; //not explained by Sparkfun
    /* init position value*/
    int DataValueL=512; //middle position 0-1024
    int DataValueR=512; //middle position 0-1024
    // INITIALIZATION
    void setup()
    // serial initialization
    Serial.begin(115200);
    // initialization of Arduino's pins
    pinMode(statpin, OUTPUT); //not explained by Sparkfun
    digitalWrite(statpin, LOW);
    for (int i=0; i<2; i++)
    pinMode(inApin, OUTPUT);
    pinMode(inBpin, OUTPUT);
    pinMode(pwmpin, OUTPUT);
    // Initialize braked for motor
    digitalWrite(inApin, LOW);
    digitalWrite(inBpin, LOW);
    ///////////////////////////////// Main Loop ////////////////////////////////////
    void loop()
    int sensorL,sensorR;
    readSerialData(); // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
    // the previous order will still be used by the PID regulation MotorMotion Function
    sensorR = analogRead(potR); // range 0-1024
    sensorL = analogRead(potL); // range 0-1024
    motorMotion(motRight,sensorR,DataValueR);
    motorMotion(motLeft,sensorL,DataValueL);
    // Procedure: wait for complete trame
    void readSerialData()
    byte Data[3]={
    '0','0','0' };
    // keep this function short, because the loop has to be short to keep the control over the motors
    if (Serial.available()>2){
    //parse the buffer : test if the byte is the first of the order "R"
    Data[0]=Serial.read();
    if (Data[0]=='L'){
    Data[1]=Serial.read();
    Data[2]=Serial.read();
    // call the function that converts the hexa in decimal and that maps the range
    DataValueR=NormalizeData(Data);
    if (Data[0]=='R'){
    // call the function that converts the hexa in decimal and maps the range
    DataValueL=NormalizeData(Data);
    if (Serial.available()>16) Serial.flush();
    void motorMotion(int numMot,int actualPos,int targetPos)
    int Tol=20; // no order to move will be sent to the motor if the target is close to the actual position
    // this prevents short jittering moves
    //could be a parameter read from a pot on an analogic pin
    // the highest value, the calmest the simulator would be (less moves)
    int gap;
    int pwm;
    int brakingDistance=30;
    // security concern : targetPos has to be within the mechanically authorized range
    targetPos=constrain(targetPos,potMini+brakingDistance,potMaxi-brakingDistance);
    gap=abs(targetPos-actualPos);
    if (gap<= Tol) {
    motorOff(numMot); //too near to move
    else {
    // PID : calculates speed according to distance
    pwm=195;
    if (gap>50) pwm=215;
    if (gap>75) pwm=235;
    if (gap>100) pwm=255;
    pwm=map(pwm, 0, 255, 0, pwmMax); //adjust the value according to pwmMax for mechanical debugging purpose !
    // if motor is outside from the range, send motor back to the limit !
    // go forward (up)
    if ((actualPos<potMini) || (actualPos<targetPos)) motorGo(numMot, FW, pwm);
    // go reverse (down)
    if ((actualPos>potMaxi) || (actualPos>targetPos)) motorGo(numMot, RV, pwm);
    void motorOff(int motor){ //Brake Ground : free wheel actually
    digitalWrite(inApin[motor], LOW);
    digitalWrite(inBpin[motor], LOW);
    analogWrite(pwmpin[motor], 0);
    void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
    digitalWrite(inApin[motor], HIGH);
    digitalWrite(inBpin[motor], HIGH);
    void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
    if (motor <= 1)
    if (direct <=4)
    // Set inA[motor]
    if (direct <=1)
    else
    // Set inB[motor]
    if ((direct==0)||(direct==2))
    else
    analogWrite(pwmpin[motor], pwm);
    void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
    // more readable function than Jim's (for educational purpose)
    // but 50 octets heavier -> unused
    if (motor <= 1 && direct <=4)
    switch (direct) {
    case 0: //electromagnetic brake : brake VCC
    break;
    case 3: //Brake Ground (free wheel)
    break;
    case 1: // forward : beware it's depending on your hardware wiring
    break;
    case 2: // Reverse : beware it's depending on your hardware wiring
    break;
    // testPot
    void testPot(){
    Serial.print(analogRead(potR));
    Serial.print(";");
    Serial.println(analogRead(potL));
    delay(250);
    void testpulse(){
    int pw=120;
    while (true){
    motorGo(motLeft, FW, pw);
    delay(250);
    motorOff(motLeft);
    delay(250);
    motorGo(motLeft, RV, pw);
    delay(250);
    motorOff(motLeft);
    delay(500);
    motorGo(motRight, FW, pw);
    delay(250);
    motorOff(motRight);
    delay(250);
    motorGo(motRight, RV, pw);
    delay(250);
    motorOff(motRight);
    Serial.println("testpulse pwm:80");
    delay(500);
    // Function: convert Hex to Dec
    int NormalizeData(byte x[3])
    int result;
    if ((x[2]==13) || (x[2]=='R') || (x[2]=='L')) //only a LSB and Carrier Return or 'L' or 'R' in case of value below 16 (ie one CHAR and not 2)
    x[2]=x[1]; //move MSB to LSB
    x[1]='0'; //clear MSB
    for (int i=1; i<3; i++)
    if (x>47 && x<58 ){//for xA to xF
    x=x-48;
    if ( x>64 && x<71 ){//for x0 to x9
    x=x-55;
    // map the range from Xsim (0 <-> 255) to the mechanically authorized range (potMini <-> potMaxi)
    result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
    return result;
  13. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    153,764Coins
    +11,149 / 57 / -2
    The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this L<Axis1a>R<Axis2a>
  15. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Thanks a lot
    it's working now, i tried the output test and it moved but wehn i ran LFS the simulator didn't behave as expected. when i tried again i got tis message
    what could be wrong?
  16. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Did you run a couple of laps in LFS before patching it, as that generates some necessary files. If not then un-patch LFS, run a couple of laps, then re-patch LFS.
    If you still get the error message after that the hot the Details button on the error message and post a picture of it.
  17. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    Thanks i ll do that
  18. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    I did it’s working now but can u please tell me how to reverse the axis when i brake it goes back and when i push the throttle it mives to the front.
    Thks
    153,764Coins
    +11,149 / 57 / -2
  20. Elias
    Elias New Member
    Architect
    Lebanon
    163Coins
    A big thanks now i got it it works perfectly thanks to everyone this community is the best
    Chears
