Question Need For Speed Shift 2 Plugin
Discussion in 'SimTools Plugins' started by Travis, Dec 5, 2017.
  1. Travis
    Travis New Member
    Melbourne
    132Coins
    JRK, Motion platform
    I was looking for a Need For Speed Shift 2 Plugin, but can't seem to find one. Does anyone have a link to a plugin for the game thankyou.
  2. yobuddy
    51,529Coins
    @Travis
    I believe you use the Need for Speed shift plugin for both games buddy.
    (Shift 1 and Shift 2)
  3. value1
    14,237Coins
  4. Travis
    Travis New Member
    Melbourne
    132Coins
    Ok thankyou. I will try it out on the weekend.
  5. Travis
    Travis New Member
    Melbourne
    132Coins
    I have tried the plugin for Need For Speed Shift. But it does not detect in Shift 2. Any ideas?
  6. Travis
    Travis New Member
    Melbourne
    132Coins
    I have tried a plugin that only supports Shift 1. If I go to the link provided. And download the plugin that supports both shift 1 and 2. The file downloads and it is called do not download. lol. Anyway I try to install the plugin do not download. And well nothing is added to the list of games in game manager.
    Does anyone have a link to a plugin file that supports Shift 2 please.
    153,770Coins
    +11,150 / 57 / -2
  8. Travis
    Travis New Member
    Melbourne
    132Coins
    I just had a look. Sorry my mistake it was a old link in the downloads section that has that file (don't download). But yeah that is the file I am using you listed. It works on Shift 1. But Shift 2 there is no movement in-game.
    153,770Coins
    +11,150 / 57 / -2
    What patch path are you using for Shift 2 and did you recapture Tuning Center values once patched?
  10. Travis
    Travis New Member
    Melbourne
    132Coins
    I just hit patch game and that is all I have done. How do I change the patch path to Shift 2 directory?
      441.6 KB
      779
      398.6 KB
      763
      326.1 KB
      796
      462.8 KB
      758
  11. Travis
    Travis New Member
    Melbourne
    132Coins
    Game manager doesn't say Game running when opening Shift 2. But it does for Shift 1
    153,770Coins
    +11,150 / 57 / -2
    If it does not give you the option to select the patch path then try doing it manually by editing the relevant file here: C:\Users\YourUserName\AppData\Local\SimTools\GameManager\GamePathSaves
  13. Travis
    Travis New Member
    Melbourne
    132Coins
    What do I have to do to the files? If I open them with notepad. It just says Game Patched.
      21.8 KB
      688
    153,770Coins
    +11,150 / 57 / -2
    Perhaps @value1 can advise if adding the Shift 2 path manually works or not.
  15. value1
    14,237Coins
    What is the exe name of the game?
  16. Travis
    Travis New Member
    Melbourne
    132Coins
    The game exe is: shift2u
    I changed it to SHIFT, the same as Shift1 exe name. The game manager detected it.
    But then the game doesn't load and origin thinks the game is then not installed. Changing it back to shift2u the game then loads but then simtools doesn't dectect the game again. Tried making a shortcut named SHIFT hoping that'd work maybe. But still nothing.
