Faulty Moto Monster? Is this a Valid test?
Discussion in 'SimTools compatible interfaces' started by mariano68, May 18, 2015.
  1. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    Hey guys!
    I did this test yesterday, and my Moto Monster gave an error, 3 of the 4th test gave me 12v/-12v and the 4th gave me 4,96v, is this test known here and valid?
    MOTOR 1. Unimos el pin D5 de la "Monster" al positivo (5v) y su pin D7 también al positivo (5v) verificamos con un multímetro que efectivamente arroja un resultado del +12v/12v indistintamente en la salida A1B1. Luego veremos que al usar los pines D5 y D8 el resultado debe darnos su sentido opuesto.
    Un error "algo común" es que una de las cuatro combinaciones arroje un volaje nulo (cero) o que no llegue al maximo de lo que tiene que dar. Por ejemplo 9v.
    Tendríamos ante nosotros una pieza defectuosa de fábrica.
    English:
    Connect pin D5 and pin D7 ( 5v ) of the "Moto Monster " to the positive ( 5V ), check with a multimeter that effectively gives a figure of + 12V / 12V output in A1B1 . Then we will see that by using the D5 D8 pins the result should give us the opposite direction. A common error is one of the four combinations voltaje throw a null (zero ) or does not reach the maximum of what to give. For example 9v . We would have then a defective Factory part
    153,770Coins
    +11,149 / 57 / -2
    There have been repeated reported cases of Monster Motor boards being DOA, @SilentChill is just the latest: http://www.xsimulator.net/community...otors-mms-and-arduinos.6948/page-7#post-81233
    Can someone who is knowledgeable about the Monster Moto, like @Pit, @RufusDufus, @eaorobbie or others, determine if @mariano68's test is valid, or if there is some other simple way to test Monster Motor boards, so we can add it to the FAQs and encourage people to test their Monster Motor boards when they arrive, rather than trying to troubleshoot when a sim does not perform as expected.
  3. wokcz
    wokcz New Member
    Argentina
    232Coins
    Hope an experienced user can confirm is the test is valid, I'd like to test my mm before building anything.
  4. SilentChill
    20,601Coins
    I would say no not a valid test as you need to put the MM under load with something that's going to draw some current from it.
    I had a few that showed 12v and -12v but as soon as I connected a motor it just dropped to zero and the motor didn't turn.
    153,770Coins
    +11,149 / 57 / -2
    So, lock the motor in the vice would do it @SilentChill ?
    I gather the MM wold have some built in current overload, so is there a risk it won't cut in fast enough and hence you could cook the MM?
  6. SilentChill
    20,601Coins
    No I just used a rc motor from my fans to test . Probably using a light bulb may work also
    • Useful Useful x 2
  7. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    I hope I'm wrong but in the datasheet the VNH2SP30 shows that the PWM needs to have a minimum off time so as not to go into fault mode as it might see the constant voltage as a short circuit. The test shown here has the PWM pin clamped high. The datasheet also provides a diagnostic truth table so that the fault can be diagnosed. My knowledge in this area is limited and the datasheet isn't particularly clear on how to properly interpret these fault conditions.
    http://cdn.sparkfun.com/datasheets/Dev/Arduino/Shields/10832.pdf
    Page 10 has the reference to the PWM protection shown under Table 9
    Page 14 has the normal and fault truth table
    Page 20 explains a little bit about how the fault protection works
    Page 21 has the fault clearing method
    I suppose my biggest concern with the test is if the PWM protection does kick in or not after applying a constant voltage to the PWM pins.
  8. SeatTime
    I hook mine up just like I would in a sim with a ARD + pot to supply the enables/PWM to run it, except the motor is just sitting on the bench. As per @SilentChill s video.
  9. Alexey
    Adelaide, Australia
    8,066Coins
    Yes I think that is the best way to test them, as you would actually use them in the simulator.
  10. ruba
    ruba Member
    Engineer
    Krasnoyarsk
    5Coins
    2DOF, 3DOF, Arduino
    In my case near 50% MM from alibaba have problems.. Tested with motor with ~1A no load current.
