2dof playstation 4
Discussion in 'DIY Motion Simulator Projects' started by ludo22420, Dec 21, 2017.
  1. ludo22420
    ludo22420 Member
    206Coins
    hi.apres have read a long time on the forum I embarked on the construction of a simulator 2dof a wiper motor for my ps4 I already gathered the necessary equipment card motorcycle monster, arduino, cardan, seat bucket etc.
    I send you photos of my progress.
  2. ludo22420
    ludo22420 Member
    206Coins
    my simu advance slowly think you must I put cogs for but potentiometers
    the bucket seat 40 euros used
  3. ruba
    ruba Member
    Engineer
    Krasnoyarsk
    5Coins
    2DOF, 3DOF, Arduino
    Good luck with your project! Post more pictures.
  4. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    using with ps4 discourages me a little, because the telemetry is very poor, almost no game has the correct information and the responses in UDP are slow ... I've tried a few times. I'll follow your project to see how it goes.
  5. ludo22420
    ludo22420 Member
    206Coins
    I know that with udp it will not be easy. If it does not work I invest in a pc gamer
  6. ludo22420
    ludo22420 Member
    206Coins
    good I received my arduino and moto monster first tests the engines answered but I think the one on the left has a bit of male I'll try to settle this
  7. ludo22420
    ludo22420 Member
    206Coins
    Je suis à la fin de ma construction cela m'a pris beaucoup de temps mais je suis finalement arrivé. Le simulateur se comporte bien avec les démo lfs et simtools. Plus pour moi cas pour recevoir la licence gratuite pour essayer assetto corsa en udp sur mon ps4.ces longtemps à attendre J'espère que j'aurais la licence. voici quelques photos désolées pour la qualité.
  8. ludo22420
    ludo22420 Member
    206Coins
    d'autres photos
  9. baxbax
    baxbax New Member
    135Coins
    Great work!
    How is the response of UDP, from PS4 and motors?
  10. ludo22420
    ludo22420 Member
    206Coins
    for now I can not run on ps4 I did not have the license I must wait (it's long)
  11. ludo22420
    ludo22420 Member
    206Coins
    that's it i received my activation key for simtools unfortunately i did not have enough corner to download the plugins if someone could be generous and make a donation would be cool
    151,991Coins
    +11,061 / 56 / -2
    Done, have fun and please post an update when you have the plugins installed and sorted.
  13. ludo22420
    ludo22420 Member
    206Coins
    thank you:thumbs:thumbs
  14. ludo22420
    ludo22420 Member
    206Coins
    hello after a moment in stand-by I resumed my project. I download the plugins assetto corsa udp but it does not work I do not understand if someone can help me. Here's the problem:
    Consultez la fin de ce message pour plus de détails sur l'appel du débogage
    juste-à-temps (JIT) à la place de cette boîte de dialogue.
    ************** Texte de l'exception **************
    System.ComponentModel.Win32Exception (0x80004005): Le fichier spécifié est introuvable
    à System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
    à System.Diagnostics.Process.Start()
    à System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
    à ASSETTOCORSAUDP_GamePlugin.GamePlugin.GameStart()
    à SimTools_GameManager.Mod_Lib.GameStarted()
    à SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    à System.Windows.Forms.Timer.OnTick(EventArgs e)
    à System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Assemblys chargés **************
    mscorlib
    Version de l'assembly : 4.0.0.0
    Version Win32 : 4.7.2600.0 built by: NET471REL1LAST
    CodeBase : file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Version de l'assembly : 0.2.2.0
    Version Win32 : 0.2.2.0
    CodeBase : file:///C:/Program%20Files/SimTools/SimTools_GameManager.exe
    UECVpOtREaDqwhniYBZgBdhPlol
    Version de l'assembly : 0.0.0.0
    Microsoft.VisualBasic
    Version de l'assembly : 10.0.0.0
    Version Win32 : 14.7.2556.0 built by: NET471REL1
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Version Win32 : 4.7.2556.0 built by: NET471REL1
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Version Win32 : 4.7.2612.0 built by: NET471REL1LAST_B
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Version de l'assembly : 1.0.0.0
    Version Win32 : 1.0.0.0
    CodeBase : file:///C:/Program%20Files/SimTools/Game_PluginAPI.DLL
    System.Management
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Version de l'assembly : 2.0.0.1
    Version Win32 : 2.0.0.1
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/ASSETTOCORSAUDP_GamePlugin.dll
    Dirt4_GamePlugin
    Version de l'assembly : 2.0.1.5
    Version Win32 : 2.0.1.5
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/Dirt4_GamePlugin.dll
    F12016UDP_GamePlugin
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/F12016UDP_GamePlugin.dll
    F12017UDP_GamePlugin
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/F12017UDP_GamePlugin.dll
    LiveForSpeed_GamePlugin
    Version de l'assembly : 2.1.0.0
    Version Win32 : 2.1.0.0
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    NoLimits2_GamePlugin
    Version de l'assembly : 2.0.0.4
    Version Win32 : 2.0.0.4
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/NoLimits2_GamePlugin.dll
    PROJECTCARS2UDP_GamePlugin
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/PROJECTCARS2UDP_GamePlugin.dll
    PROJECTCARSUDP_GamePlugin
    CodeBase : file:///C:/Users/hp/AppData/Local/SimTools/GamePlugins/PROJECTCARSUDP_GamePlugin.dll
    Microsoft.GeneratedCode
    mscorlib.resources
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
    CodeBase : file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Débogage JIT **************
    Pour activer le débogage juste-à-temps (JIT), le fichier de configuration pour cette
    application ou cet ordinateur (machine.config) doit avoir la valeur
    jitDebugging définie dans la section system.windows.forms.
    L'application doit également être compilée avec le débogage
    activé.
    Par exemple :
    <configuration>
    </configuration>
    Lorsque le débogage juste-à-temps est activé, les exceptions non gérées
    seront envoyées au débogueur JIT inscrit sur l'ordinateur
    plutôt que d'être gérées par cette boîte de dialogue.
  15. yobuddy
    50,994Coins
    There is no reason you should get less resolution from the PS4 version of games that support telemetry.
    It should work just fine buddy.
    Before you try connecting games thou, please setup Game Engine and make sure you can use output testing without issues.
    The error above looks like it is complaining of a file missing, but I can't tell what exactly is missing.
    I'm sure we can find what is going on thou!
    Take care,
