Question Just bought homemade sim and cannot connect
Discussion in 'DIY Motion Simulator Projects' started by Mark DOWSETT, Dec 24, 2017.
  1. Mark DOWSETT
    Mark DOWSETT New Member Gold Contributor
    173Coins
    Im a bit of a newbie and I bought I brilliant homemade sim. The bloke I bought from built from scratch and I saw it all working before I bought it. When I get it home I can't get the machine to run. I have connected to the Arduino which becomes com3 and I can't seem to get the Monster Moto to function or match up to Simtools. Any help on getting this thing setup would be awesome thanks
    Specs
    2DOF motion rig.
    Arduino & Monster Moto controller.
    Custom housing for Arduino & MM
    33A Power Supply.
    200W 50:1 Motion Dynamics Industrial 12V Motors.
    Steel frame.
    Easy to move, front castors & rotating rear locking castor wheels.
    Autotechnica Seat,
    Laser cut potentiometer mounts.
    I want to run fix and project cars, plus eventually build an enclosure
    Any assistance would be greatly appreciated
    Photos attached.
    Thanks in advance
    Mark
    23845653_834947936684129_3569140425318667275_o.jpg 23826161_834948066684116_7632845863148138986_o.jpg 23783875_834948063350783_6769263833076137703_o.jpg 23737856_834948006684122_8467524282580875686_o.jpg 23737884_834947996684123_2032202282531226349_o.jpg 23783798_834947993350790_5778276797017810472_o.jpg 23755627_834947950017461_6298525619031238667_n.jpg
    153,728Coins
    Can you please post picture of all of your SimTools settings
  3. pchelka
    pchelka New Member
    Craków
    52Coins
    I have to say this seems to be well thought out layout - simple and clean seems like you got yourself a good package, congratulations.
  4. ruba
    ruba Member
    Engineer
    Krasnoyarsk
    5Coins
    2DOF, 3DOF, Arduino
    Looks very good!
    Have you installed drivers for arduino? (may be you need CH340 drivers for chineese arduino)
    The only I can suggest more - better fixate wires near "Motor feedback", if one of them will come off the connector the feedback resistor may be damaged.
  5. Mark DOWSETT
    173Coins
    I have paid the full price to access this site, but seem to only have a demo of simtools. Attached is the settings from simtools. Thanks for responses thus far. Getting a bit frustrated as I know it works byut Im just a bit of a numpty haha
    153,728Coins
    A license is required for SimTools 2 to utilise any plugins other than the LFS one, which is included for testing purposes.
    See here re the commercial relationship and revenue sharing arrangements between SimTools (motion Software) and Xsimulator (plugin access and community support), as each has its own costs: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    While DIY sim builders are eligible for a free DIY license someone buying a DIY rig is required to purchase a Professional License, which can be found here: https://simtools.us/license/
    The upside of a Professional license is that it also covers all the additional SimTools companion apps: https://www.xsimulator.net/community/marketplace/categories/official-companion-apps.32/
    The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
    In your case for a 2DOF the Interface settings will be <Axis1a><Axis2a>
    What code is the Arduino running, as that will affect some other settings?
