Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    51,190Coins
    SimTools does not use the registry.
    Just so everyone knows, you can reinstall SimTools over and over on the same PC without it costing you another activation.
    Its only when you install it on different machines (or a possible PC upgrade) that it would cost another.
    And if you ever have any problems, we can help you out with a message from here:
    https://simtools.us/contact-us/
    Take care all,
  2. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    wooow i didn't know that! thank you for such possibility - this is how license should work:D
    so do i understand correctly, in case i want to upgrade from win 8.1 to win 10/install fresh win 10 i shouldn't activate the license once the new os is installed?
    but if i change the pc i should buy another licence for this brand new pc?
  3. yobuddy
    51,190Coins
    @moaale,
    did you send a message to support?
    btw,if you reformat the PC or install a new HDD, then yes you would need to re-register.
    As the reg file has been removed from the PC.
    Take care,
    152,541Coins
    +11,085 / 56 / -2
    Did you contact @yobuddy as suggested here: https://www.xsimulator.net/communit...on-software-simtools.4872/page-24#post-147067
  5. yobuddy
    51,190Coins
    • Friendly Friendly x 2
  6. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    well... simvibe its done. tks. somebody have a profiles for test?
    152,541Coins
    +11,085 / 56 / -2
    So far it will work with Live For Speed, other plugins will need to be updated.
  8. paulopsx2
    brasil
    647Coins
    First of all... you run simtools soft in ENGLISH format on windows?
  9. cruzebabuze
    cruzebabuze Active Member
    135Coins
    Hi everyone, I just finished a three axis motion sim, and everything and all axis works great in smc3 but in the xsimulator software I can't move only two axis and not the third one? Anyone has any idea why?
  10. paulopsx2
    brasil
    647Coins
    off corse rs.. solved problem... its a new version plugin to VR or NON VR. for now all its fine
    152,541Coins
    +11,085 / 56 / -2
  12. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    621Coins
    2DOF, 3DOF
    Bonsoir
    je viens de telech
  13. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    Good evening
    I just downloaded the update of SimTools 2.2 and I can not uncompress corrupt archive.
    I downloaded it 2 times.
    someone would have it in proper condition.
    thank you.
    bonsoir
    je viens de télécharger la mise a jour de SimTools 2.2 et je ne peut pas le décompresser archive corrompu.
    je l'ai télécharger 2 fois.
    quelqu'un l'aurait en état correct.
    merci.
  14. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    ok it's good everything works thank you
    ok c'est bon tout fonctionne merci
  15. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hello @yobuddy and thank you for your great SimTools!!!
    I was wondering: is it possible to temporarily disable some effects to perform fine tuning of others?
    For example, once you find the right balance for Pitch & Roll, is it possible to temporarily disable it (for example by clicking on a check box...) to dedicate yourself to the Sway and Surge setup? ... Or is it necessary to put the values back to 0 on Pitch & Roll?
    Thank you again!!!
  16. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    You can use the drop down to temporarily set Pitch & Roll to none, but leave the values so they are easily re-enabled.
  17. ilbiga
    Network Engineer
    103Coins
    Ok, sorry for the silly question ... it was trivial but I had not tried ... :think
    Thanks again!:thumbs
    P.S.
    A checkbox of "Enabled/Disabled" could be practical, I think ... ;)
  18. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    I am running Iracing and every time I launch iracing game engine crashes. I can start it back up after iracing is already running, but i'm not sure if that is allowed. I am trying to get motion working and I get no value in the game data output of tuning center when running iracing. I dont know if that is due to simtools crashing when iracing starts or if that a whole other problem. Dash is still working even with a late startup.
    game engine also seems to be crashing whenever I enable and disable the game manager.
    any help is appreciated, I am so close to getting everything working.
  19. yobuddy
    51,190Coins
    It's easiest to select "-" for force to temporarily disable the output.
    @Hoddem
    I don't recognize the interface settings at all.
    What are you running buddy?
  20. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    Hey @yobuddy, I am using @vthinsel's XPID for arduino mega and sabertooth. The interface settings are working great, I have everything moving when I have output testing turned on, but nothing coming through when I am in iracing.
