Tutorial How to write an Interface Plugin for SimTools 2.0 - API documentation
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Jul 16, 2016.
  1. Simal
    Simal Member
    Solar System, Earth, Ukraine, Kirovograd
    - 144Coins
    2DOF, DC motor
    @yobuddy, hi.
    As far as I understand, "Network" interface type in the SimTools is UDP? Can I download the Plugin Interface example somewhere? I want to rewrite the plugin for TCP support.
  2. yobuddy
    51,563Coins
    @Simal
    All of the Interface examples will be posted with the release of SimTools 2.2.
    It should not be to long buddy.
  3. SvenRS2
    SvenRS2 New Member
    Cologne, Germany
    - 235Coins
    AC motor, SCN5, SCN6, Arduino, Motion platform, 4DOF
    Hey guys! I'm searching for the interface plugin examples, but I can't find them. Where do I have to look? Or are they not available yet?
    153,986Coins
    +11,162 / 57 / -2
    You may need to let @yobuddy take a slight breather before finishing these, as SimTools 2.2 has only been released for a couple of days.
  5. yobuddy
    51,563Coins
    @SvenRS2,
    I will get them posted soon guy's.
    I have been working on GameVibe so long, I was eager to try a few new ideas out.
    I feel the core of SimTools is plenty solid enough for me to start actually playing with the apps I have been building for so long.
    And seeing what all I can make them do.
    The one idea I am playing with now, well lol, I got so excited by how the project is working i got a bit sidetracked.
    I really was not expecting such results. (for 2 or 3 days worth of work anyway)
    I got a feeling that a lot of you guys are going to be pretty excited with this "Secret Project". ;)
  6. SvenRS2
    SvenRS2 New Member
    Cologne, Germany
    - 235Coins
    Hi @yobuddy! Thanks for your reply! It really wasn't my intention to speed things up. I just wanted to make sure that I didn't miss something. So, when the time has come, do I have to look here in the thread for the interface plugin examples, or somewhere else?
  7. yobuddy
    51,563Coins
    It will be posted right here buddy!
    Take Care,
    153,986Coins
    +11,162 / 57 / -2
  9. lioxacydak1
    lioxacydak1 Member
    rescuer
    - 256Coins
    And how can I download it Example Plugin? The link is not active.
  10. yobuddy
    51,563Coins
    Example Interface Plugins Posted! :thumbs
  11. lioxacydak1
    lioxacydak1 Member
    rescuer
    - 256Coins
    Thank you very much
  12. Frank1999
    Frank1999 New Member Gold Contributor
    48Coins
    4DOF
    Hi, @yobuddy , I am going to build a 4 axis simulator with 4 BLDC motor actuators. The actuator driver(controller) has RS485 interface and can communicate with PC using modbus-rtu protocol to control the actuator action. I don't know how to custom this interface plugin for sim engine. Is it possible to enclose a modbus-rtu protocol support? Could give me some helps? Thank you!
  13. yobuddy
    51,563Coins
    @Frank1999,
    If you can make a small vb.net app that can:
    1) allow you to select a com port and then open a connection.
    2) move the axis around by setting a target location.
    3) shut the connection down
    With a small app like this I could roll it into a interface plugin for you.
    Let me know what you think.
    Take care,
  14. Frank1999
    48Coins
    4DOF
    @yobuddy ,
    Thanks for your reply.
    I will try to do this after built my rig.
    Take care,
    Frank
  15. Alessio Galliazzo
    Alessio Galliazzo New Member
    5Coins
    Hi guys,
    I'm a developer working on a custom interface. I actually cannot make any "build" interface works properly. PluginValiator tell me that the plugin is a valid plugin but once loaded in game engine it fail to load the plugin telling me that it is invalid and that it cannot find a file. Firstly I was supposing that was due to my developed plugin (I use C#) but the same happen also with the 3 examples in the first post.
    You can see in the attachment the 4 errors:
    - Error 1: My developed plugin in C# - first message error
    - Error 2: My developed plugin in C# - It's saying that it cannot find a dependence or a file
    - Error 3 and 4: Same as before but compiling the NetworkInterface plugin downloaded from here (changing only author and plugin name)
    Anyone can help in some way?
    Running Win10, VS2019 and compiling using .NET Framework 4.0 (as the example)
    Best
    Alessio
  16. yobuddy
    51,563Coins
    I can help.
    It's probably just a naming convention problem.
    If you change the plugin name, then you need to change the compiled name.
    I may be wrong, but try taking a look at the bottom of my post where it says
    https://www.xsimulator.net/communit...ugin-for-simtools-2-0-api-documentation.8813/
    I think it may be the problem.
    (btw, this naming step has been removed from v3)
    Chat soon,
  17. Alessio Galliazzo
    5Coins
    Of course, that solved the problem... I miss that part... I'm sorry!
    Best
    Alessio
  18. yobuddy
    51,563Coins
    No problem at all buddy.
    I just recognized the problem is all.
    C# is just fine to write the plugin in btw, I think there is even a couple of examples somewhere around here.
    Anyway, take care! :thumbs
  19. Frank1999
    48Coins
    4DOF
    Hello @yobuddy,
    I have previously re-written a RS485 serial interface plugin using "Serial - Example Interface Plugin" and it works fine. But recently I tried to upgrade my interface hardware to a CANBUS device, I encountered a problem: the rewrite plugin can be installed normally and the new hardware can be started normally, but when I test, simtool will automatically detect the serial port,since the new hardware (CANBUS) is not transmitted through the serial port, the new plugin cannot work .
    It seems that there is no way to fix this inside the plugin, could you please help me with this problem? Or can you provide a new "Example Interface Plugin" for reference, similar to the JRK plugin.
  20. yobuddy
    51,563Coins
    I don't understand buddy.
    How does it detect a port if it does not use serial?
    Feel free to PM me and we can discuss a fix to the problem.
